How to change number plate lights on w204?
You need to open the trunk and pull out the liner in order to gain access to the number plate lights. Yes, a ****ty way of getting there.
I heard that you are working for ESP. Is there any trick how to switch off ESP completely in w204?
ESP can be turned off completely.
CAUTION! THIS TURNS OFF ESP,ABS,BAS AND ALL RELEVANT ELECTRONICS SYSTEMS! DO NOT TRY THIS AND DRIVE IN PUBLIC ROADS!
Get in the car, turn the ignition switch to position I. Before the SRS (airbag) LED goes off, press the green button "Accept Call" on the Radio Unit and one second later press OK on the steering wheel , still holding the green button.
Keep both buttons pressed until you see the hidden menu on the tachometer screen which looks like that
Vehicle Data
Roller Test
Assyst Plus
Choose Roller Test, OK and then you see "Roller Test ESP: Off When Ignition is Off". Press OK once more and you get "Roller Test ESP: ΟΝ" on the tacho screen, plus all SRS/ABS etc. indicators light up!
That's it! I've had to do it on mine to get it dynoed.
Repeat the same sequence until you reach the "Roller Test ESP: Off When Ignition is Off" to activate all systems again.
http://www.youtube.com/watch?v=3tLta...eature=related
check out this link and u will be able to switch it off.
https://mbworld.org/forums/c-class-w...te-lights.html
Thanks!
Vehicle Data
Roller Test
Assyst Plus
