**HIDDEN: Compass and Side-View Cameras
actually, that's what they told me here in edmonton too. I had to send email to MB Canada to get local dealer to apply firmware update.
if you have any question, feel free to pm me.
Put the car key in Position 1 or 2 and on your Dash console, press and hold End call button + # + 1 all at same time. Keep them pressed for a few seconds and then you will see a new menu on your COMAND screen.
The go option 7 and again 7th and then look for "OFFROAD FUCNTION" or something and then change it from not installed to installed.
Now take the car key out and let the COMAND close. After 10 secs you can use the car key again to activate the COMAND and check out the new option "Compass"
Does the height thing work for anyone? Mine just stays at 0.
yes, you do need updated MM with audio fadeout.
I noticed a "Tail Gate Party" function in the Engineering menu, anyone have an idea what this is for?
Has anyone with a US model been successful loading the COMAND compass display?
My build date was 11/11/08 so I would imagine I have the latest update. I did not get a COMAND manual with the car and the dealer is sending me a copy.
Where in the eng screen did you fine the Off road function?
(spent some time in Brooklyn in the late 40's at Ebbets Field watching the Bums do their thing... :-)
RIZ signal Source = Reverse Gear
NAVI Retrofit:
both are grayed out, so i guess i need the updated Comand HU software too. i will ask for it all on my next appointment.
Hmm, maybe once the update is done, my NAVI RETROFIT will be Enabled?
