C300 2008
Old 05-20-2009, 02:28 PM
AHPO's Avatar
C300
C300 2008
I'm currently driving the C300 2008. now i realized the importance of having a 4matic (because during snowy weather, i simply cant drive on my C300).
is there any way i can add the 4matic now?
Old 05-20-2009, 02:31 PM
patrickkc's Avatar
E63S || C63 || E550 Coupe || Cayenne ||
trade this one in for a 4matic
Old 05-20-2009, 02:32 PM
AHPO's Avatar
C300
i must top up quite a huge sum of money isnt it
Old 05-20-2009, 02:36 PM
patrickkc's Avatar
yea, selling now you'd loose quite a bit. Is your car lease or did you buy it out?
AHPO's Avatar
C300
i bought it right out from the mercedes sales office
Old 05-20-2009, 02:37 PM
AHPO's Avatar
C300
so there isnt a way to add in the engine or gears of any sort to make it 4matic?
anyone down here who drives a C300 (no 4matic), can u guys drive on snow?
Old 05-20-2009, 02:39 PM
TB5...'s Avatar
2009 C300 4Matic
^ down here? where are you from boss
and it is probably ridiculously expensive and i would assume nearly impossible to put on a all wheel drive system onto your car.
like patrick said a trade might be your only option. or possibly winter tires.
patrickkc's Avatar
where are you from? I havn't driven my c300 in snow yet, but my old c230 non 4matic I can drive it in the winter fine
Old 05-20-2009, 02:41 PM
AHPO's Avatar
C300
im in indiana, fairly snowy season during the end of year
Old 05-20-2009, 02:43 PM
peabers's Avatar
2011 E350 4Matic Wagon, 2013 C350 4Matic Sedan
You just need a decent set of snow tyres -- that will be your best investment in the car. Even with a 4matic, it will only get you going.
(it's sad that we are having this conversation when it's over 25oC today)
Old 05-20-2009, 02:44 PM
AHPO's Avatar
C300
whats the use of a 4matic? can 4matic really gets u driving through snow?
Old 05-20-2009, 02:45 PM
TB5...'s Avatar
2009 C300 4Matic
i say get some winter tires and drive slower...
it's a much much much cheaper alternative.
4 matic means each wheel has power going to it... and they all spin at the same time... of course it helps gettin the car moving in snow and handles a bit better because there is usually contact between one of the tires and the ground
in a FWD system the front wheels are pulling the car... much more difficult to get the car going.
Old 05-20-2009, 02:48 PM
patrickkc's Avatar
yep, get really good snow tires and you're set. You should've thought about this problem before you purchased the car because getting a good set of 17 or 18" snow tires for your car can very much cover the cost of upgrading to the 4 Matic. I stuck with non 4 Matic was because so I can have fun in the winter
Old 05-20-2009, 02:54 PM
patrickkc's Avatar
I thought FWD cars are much better in snow than RWD
Old 05-20-2009, 03:00 PM
TB5...'s Avatar
2009 C300 4Matic
i was comparing any 2 wheel drive to 4 wheel, i just used FWD as a example...
but yea ppl say
fwd > rwd
i disagree tho i think i can handle a rwd car much better because i have the control of the back tires... which also means control in a tight turn (giving it a bit of gas) especially in snow.
one thing for sure... rwd is ****ty when starting from a stopped position.
Old 05-20-2009, 03:09 PM
patrickkc's Avatar
ooo yea, AWD > 2WD anyday. My old c230 was VERY VERY tail happy during the winter and I'd play around with it alot in parking lots, but my friend's camry seemed to be having a very hard time getting his tail out without pulling on the handbrakes.
Old 05-20-2009, 03:32 PM
len56's Avatar
C350
down here?
... like southern hemisphere (it's winter there now :P)?
Old 05-20-2009, 03:34 PM
peabers's Avatar
A lot of it depends on the tyres. I had an IS300 and without winter tyres, the car was completely useless in the winter. But with a decent set of winter tyres and a couple kilos of weight in the trunk, I got the traction that I needed.
The argument about FWD > RWD in the winter is because you can use the steering that help position the tyres to find some more traction. In cases FF layout, there is usually also more weight on the wheels that drive the car (i.e., 60/40 weight distribution).
I've owned FF, FR, and FA vehicles. The AWD definitely provides the most confidence pulling away in the winter. The FR was fun because I could break the tail loose like TB5 says -- and living in the city meant I rarely found unploughed streets or an alternative means of transport. FF is ok but given the amount of torque engines produce nowadays, wrestling with torque steer is no fun (the TL would be an example of that).
len56's Avatar
C350
so 4 18" winter tires cost $4000 (price diff. in 4 matic vs. non in CAD)?
or is it true
EDIT: I meant JUST tires, not new wheels. They swap em for you and it takes two hours, much better then having steel rims or buying new ones (the AMG's fit the car perfectly anyway =D)
Old 05-20-2009, 03:36 PM
AMGTTV8's Avatar
AMG
is this a serious question?
patrickkc's Avatar
well you have the $1500 of automatic which you don't have to add in for the 4matic. Assuming his C300 is automatic
The price difference, of 4Matic and non 4Matic is $3700. And if his c300 is auto then thats $3700-$1500...I got a quote for our c300 with 17" winters for $1500 but they weren't top of the line snowtires or anything so I'd assume that if he has the 18" or if he wants a good set of snowtires then they'd probably be in the $2000+ range
Old 05-20-2009, 03:38 PM
peabers's Avatar
LEN56 -- It is certainly possible to spend $4000 on winter tyres and rims if someone wants to. But why would anyone get winter tyres on 18" rims? Always go with the smallest rim you can for winter to maximize sidewall flex.
Old 05-20-2009, 03:42 PM
patrickkc's Avatar
yep, I'ma get 16" steel rims for the winter. Though ugly, I'm willing to give that up for my safety this coming winter
Old 05-20-2009, 03:50 PM
TB5...'s Avatar
2009 C300 4Matic
lol @ all the toronto ppl being the experts on snow driving...
Old 05-20-2009, 04:09 PM
patrickkc's Avatar
wellll we do get some snow, enough to know a bit about winter driving
Quick Reply: C300 2008
