HID cutoff after replacing OEM bi-xenon bulb
I just replaced the OEM bi-xenon bulbs in my C300 with 6000k bulbs. I turned them on, and the cut-off doesn't have the same shape it used to with the stock bulbs. The cut off is still there, but it doesnt go straight across, then diagnol up a bit, then straight again like proper cut off should have. Now it goes straight, then forms a little peak, then straight and then another little peak from the other bulb.
Are my new bulbs just not seated properly in the housing?
Ask the bodyshop guy that installed my HID bulb is it seal correctly, he said its sealed correctly and i told him about how it doesn't cut when projected he said he doesn't know.
If it's sealed it's fitted right (there is no other way)
also, try to readjust your projectors. try to go as far away from the way as possible- slight adjustments go a long ways- pretty much you want to line up the bottom part of the cutoff for each projector. it should almost vanish into the horizon.
http://lightwerkz.net/faq.htm#aiming
1) what make/model is the old bulb?
2) what make/model is the new bulb?
3) check your owner manual for mention of headlight adjustment control
(never mind....i see in the manual that it says to bring to dealer)
the cutoff can induce color into the projected beam. as such, the bulb
itself also can introduce a component of color into the beam and cutoff.
I would go with phillips if you are looking to upgrade-6k you are already losing some light output - visible light...
4.5k will provide most visible light, but will be yellowish still
in my case, i went with 5k- white like a **** and yet not compromising much visible light
they appear to simply be selling HID kits just like any cut rate aftermarket
vendor out there. my guess is that the products are from an offshore Asian
manuf plant.
if you carefully compare OEM v Luminex bulb, measure critical specs and see
if the are spot on. with an HID bulb, focal point is critical to a precision beam.
so the positioning of the 'arc' is important. since this company is hoping on
windfall profits on rebased HID bulbs and kits, i'm guessing that the assembly
of the bulb, the construction etc is off just enough to move the focal point
away from (or closer to) the projector lens than it should.
w/o see them side-by-side it's difficult to tell though. i echo spool's recommen-
dation though and see if the quality of your cutoff returns.
also the further awya you are, it is easier to see the subtle adjustments made. a small change goes a long ways.
it should look like this
from a closer look, you see that the 2 lower parts of the projected light need to be aligned- they represent the visible light that the traffic coming from the other direction would see and is much straighter (thus easier to align) than the peaks.
Acura's have always had an absolute razor sharp light pattern. Simply amazing.
