08 rear turn signal bulb
Old May 28, 2009 | 11:59 AM
ulovemybenzo's Avatar
99 W210 E55
anyone change these out?
Old May 28, 2009 | 12:03 PM
ctgilles's Avatar
S204 C220 CDI, VW Scirocco III 1.4TSI 160
No I have LEDs. But they are the same bulbs as the stop and rear lights. Open the trunk and you'll have easy access to them.
Old May 28, 2009 | 12:08 PM
Maximo7's Avatar
C350
Where can you get these bulbs but regular clear coated? i want to change the ones that i have on the front bumper that are amber....I checked with the dealer at parts but that guy looked more confused than me
Old May 28, 2009 | 12:09 PM
99 W210 E55
yea they're the same bulb but the stupid prongs are different.
Old May 28, 2009 | 12:54 PM
99 W210 E55
nobody have changed their rear blinkers everyones still using those ugly yellows?
Old May 28, 2009 | 01:39 PM
alexlev's Avatar
C204
I am planning on doing it when I get the chance. Anyone know if replacing them will throw out an error or hyperblinking?
Old May 28, 2009 | 02:04 PM
ctgilles's Avatar
Replacing with LED = error. And a 21W load resistor is dangerous!
The prongs are different? Well then get the other ones... Sold in all car shops.
Old May 28, 2009 | 02:28 PM
Derspeed's Avatar
X3 and 2012 C coming soon
I replaced the fronts with chromed ambers from ebay. The rears are the same, however, one member advised that they are difficult to see when installed in the rear. He indicated that people honked at him whenever he signaled to change lanes. They are not LEDs and they do not throw codes.
Old May 28, 2009 | 02:32 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
I've swapped mine out in the rear for white turn signals to match my front turn signal, but going to switch to red soon. They're easy to get to. You access it through the two rear side ports in the trunk. Remove the one wire connector to the gray plastic light assembly, then there's one press clip holding the assembly to the frame. Press it, and pull it out. You'll see all your lights and just swap what you want.
Old May 28, 2009 | 02:45 PM
Maximo7's Avatar
C350
What is the code for this chromed amber bulbs you bought?
Old May 28, 2009 | 02:55 PM
Derspeed's Avatar
I am pretty sure they are 3057 aka 3157.
Take yours out (it's easy) and see if it looks like this:
(I didn't buy form this specific seller. I'll have to check later to be sure.)
http://cgi.ebay.com/ebaymotors/3157-...Q5fAccessories
Old May 28, 2009 | 03:02 PM
TB5...'s Avatar
2009 C300 4Matic
2009 MERCEDES-BENZ C-class (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D1S
High beam headlamp
H7
H7SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
H7ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H7EB EcoBright - Your Environmental Choice
H7XV XtraVision Halogen - The Brighter Light
H7CB Cool Blue Halogen - The Whiter Light
Parking light
W5WB
Front turn signal
3457ALL
3457AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Rear turn signal
7507
7507AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
7507LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
7506
7506ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
7506LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
7506
High mount stop light
LED
Fog/Driving light
H11
H11ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H11XV XtraVision Halogen - The Brighter Light
License plate
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
7506
Front sidemarker
2825
Rear sidemarker
2825
Map light
2825
Dome light
6411
Step/Courtesy light
2825
Trunk/Cargo area
2825
from : http://www.sylvania.com/ConsumerProd...de/default.htm
Old May 28, 2009 | 03:10 PM
Maximo7's Avatar
C350
Low beam headlamp
HID-D1S
High beam headlamp
H7
Parking light
W5WB
Front turn signal
3457ALL
Rear turn signal
7507
Tail light
7506
Stop light
7506
LED
Fog/Driving light
H11
License plate
2825
Back up light
7506
Front sidemarker
2825
Rear sidemarker
2825
Map light
2825
Dome light
6411
Step/Courtesy light
2825
Trunk/Cargo area
2825
so its 3457.... lol its amazing how the smallest thing could be confusing for me...by bad guys
Old May 28, 2009 | 03:16 PM
TB5...'s Avatar
2009 C300 4Matic
if you're lookin for the front turn signal then yes...
just put that number into ebay search... you should get many lighting results.
Old May 28, 2009 | 03:38 PM
99 W210 E55
nvm problem solved... just made lil adjustments thanx for the feedback
Old May 28, 2009 | 04:24 PM
alexlev's Avatar
C204
In regards to the LED error, how annoying is it?
My brake light stopped working 2 weeks into purchasing the car and I would get a message letting me know that it's not functioning but I could exit out of the message. Is it similar to that?
