Service Specials & Coupons Thread!
Old Nov 20, 2010 | 11:27 AM
  #126
Oh Cool's Avatar
2021 GLB35, 2007 E350, 2014 ML350 4Matic, 2008 C350 Sport
Originally Posted by omgitselaine
Sorry i honestly do not believe any of our NY/NJ dealership has any sort of coupons or discounts. They have more than enough customers coming to them daily where they do not feel a " need " to offer discounts. Simple Eco 101 with supply and demand ??
+1
Old Dec 2, 2010 | 01:15 PM
  #127
TaxEsq's Avatar
2013 BMW 528Xi; 2010 C300 SportW4 - sold; 1964 230SL
Another set of A and B coupons from SilverStar MB - LIC, NY: A-Service is $169 and B-Service is $349. I do not know if either of these are reasonable prices but you can judge for yourself.
Link: http://mbdealerus.com/tms_olv/Online...=T1_ONL&A=1007
Old Dec 2, 2010 | 06:34 PM
  #128
joshg1001's Avatar
2017 E300
A service seems reasonable, B does not
Old Jan 20, 2011 | 08:54 PM
  #129
jam3s05's Avatar
c350
Anybody know of any coupons for the service B in Southern California?
Old Jan 21, 2011 | 01:05 AM
  #130
steveb9771's Avatar
2007 CL550
Best deal is Foothill Mercedes
http://www.mbfoothill.com/foothill-r...pons/imageOnly
"A" service for $109.95
"B" service for $239.95
valid until Jan 31, 2011
Only difference between "A" and "B" is replacement of cabin filter. This is not absolutely necessary. You can replace it yourself for less.
Only additional item to consider is replacement of brake fluid every two years. This is not usually included in "B" service price.
Several dealers will price match if you bring in the ad from another dealer.
Old Jan 21, 2011 | 02:03 PM
  #131
jam3s05's Avatar
c350
Thanks for the info!
Old Jan 25, 2011 | 05:44 AM
  #132
shad0w24's Avatar
c300 sport
Any recommendations for oil change/service at 36k mi. Recently moved to La Jolla/San Diego Area. Thanks
Old Jan 27, 2011 | 09:19 AM
  #133
NickCats's Avatar
2018 E300 4MATIC Sedan
Just got an email from Knauz Continental Autos in Lake Bluff, IL ( about 35 miles North of Chicago ) :
Synthetic Oil and Filter Service
Includes up to 9 quarts of Mercedes Benz approved synthetic oil, genuine Mercedes Benz fleece oil filter, oil filter seal, top off under-hood fluids and set tire pressures to factory specified levels.Includes complimentary Knauz Deluxe Vehicle Wash.
New Price $79.95
Scheduled Service "A"
Change oil and filter with synthetic blend oil and a genuine Mercedes Benz fleece oil filter, inspect tires as required, measure and record tread depth, check for damage and splits, reset tires to proper inflation, check condition of brakes and thickness of pads, test horn, lights, windshield wipers and washers, refill all under hood fluids, check battery condition using Midtronics tester, check catch, safety catch and hinges on hood for proper operation, reset instrument cluster maintenance counter. Includes complimentary Knauz Deluxe Vehicle Wash.
New Price $179.95
Scheduled Service "B"
Flush and replace brake hydraulic fluid in accordance with Mercedes Benz requirements. Change oil and filter with synthetic blend oil and a genuine Mercedes Benz fleece oil filter, replace cabin pollen filter. Rotate or inspect tires as required, measure and record tread depth, check for damage and splits, reset tires to proper inflation and correct spare tire pressure to proper inflation. Check condition of brakes and thickness of pads, function test parking brake and check condition of poly V belt. Inspect driveshaft flexible discs as applicable. Check suspension components for play, inspect rubber boots. Check for underbody fluid leaks. Test horn, lights, windshield wipers and washers. Refill all underhood fluids, check battery condition using Midtronics tester, and check catch, safety catch and hinges on hood for proper operation. Reset instrument cluster maintenance counter.Includes complimentary Knauz Deluxe Vehicle Wash. The applies to most vehicles, see your service advisors for model specific recommendations.
New Price $389.47
Old May 4, 2011 | 08:53 PM
  #134
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
It's about to be that time for me. Post 'em if you got 'em!
M-B Long Beach has a $141 special for A Service, and $241 for B Service 'till May 31.
Old May 4, 2011 | 09:34 PM
  #135
hitokiri89's Avatar
2010 c350
Any for long island / ny area
Old May 20, 2011 | 06:41 PM
  #136
MB4tronic's Avatar
2008 E550
Just called, this is till the going special, best deal in the area from a dealership.. they also have $299 tranny special.. normally $385 from a private shop or $425 from a dealer.
Old Sep 8, 2011 | 03:40 PM
  #137
Pete7874's Avatar
'08 C300 4Matic Sport, '02 530i
Any recent service specials out there? Our service B is coming up in about a month and our dealer says they'll match any other dealer's special, but he himself is not offering any.
EDIT: I just found this, valid until 9/30/2011:
http://www.montereymercedes.com/specials/service.htm
That 7-speed trans service at $419 still seems expensive though. Has anyone been able to get it done for less at an MB service dept?
Old Sep 10, 2011 | 09:50 AM
  #138
rh71's Avatar
'10 C300 Sport
glad to see this thread still going...
I found this one showing basic oil change for $119. The only other things Service A really does is replace the "dust filter" (I assume air filter?), top off fluids, and reset the service indicator... maybe they can do the reset for you anyway...
http://www.mynewbenz.com/Mercedes-Service-Specials.aspx
Old Sep 26, 2011 | 04:44 PM
  #139
GHAZAN's Avatar
MBUSA
Any A1 service coupons in Socal?
Old Sep 30, 2011 | 10:43 AM
  #140
IGB's Avatar
IGB
'08 C300 MM Pano
That Foothill Ranch special seems to be the best I've seen for Service A...
If that dealer is too far for you, contact your preferred dealer and ask them if they'll match a price.
Old Sep 30, 2011 | 10:47 AM
  #141
IGB's Avatar
IGB
'08 C300 MM Pano
^^THAT^^ is some good info right there... I am going in to an indy today for the transmission service, he quoted $350 and I was wondering how much is too much... So his price seems to be BETTER than the average indy, but I'm still going to print that coupon to see if he'll match it.
Thank you very much MB4tronic...
AND
Thankyou very much to steveb9771 for posting the Foothill Ranch info to begin with
Old Sep 30, 2011 | 02:38 PM
  #142
Pete7874's Avatar
My local dealer does the trans fluid/filter change for $299, and that is their regular price. See if your dealer will price match:
http://www.mercedeshoffman.com/service/service-menu.htm
Old Oct 15, 2011 | 12:54 AM
  #143
rizwanmakani's Avatar
c300 sports
My dealer is charging me $515 tax included for my service B. Does anyone have a coupon for a dallas dealership. Please help. Thank You.
P.S. MB service special website does not work.
Old Oct 15, 2011 | 02:15 PM
  #144
joshg1001's Avatar
2017 E300
MB dealerships in my area have completely stopped giving specials to service A and B. All they have is lame specials like air conditioning service and tire deals that give you a GPS (which is straight from tirerack)
Old Oct 23, 2011 | 01:35 PM
  #145
2010_C63_OMG's Avatar
2011 C63 AMG
Caliber Motors (Anaheim) always has specials on their website:
A service $149 B service $289, etc:
http://www.anaheimmercedes.com/calib...ls_service.cfm
Old Oct 23, 2011 | 11:51 PM
  #146
Doctodd33's Avatar
ML350
the more i thought about it, the more i realized that an oil change, reset service nag, and filter replacement was not a justifiable cost at the dealership. So i went to a local place that services European cars and they did it for $100. Even at that price i think its steep for an oil change. Anybody just go to Jiffy Lube for the oil and filter change and then do the rest themselves?
Old Oct 24, 2011 | 12:39 AM
  #147
Pete7874's Avatar
$100 is reasonable, IMO. Materials alone will cost you about $70-75, so that leaves $25 for labor. My local MB dealer actually charges $90 if all you want is a basic oil/filter change and not the whole Service A or B.
Jiffy Lube is not going to have proper 229.5 oil in stock, so you'd have to BYOB and BYOF probably, too. Then you'll have to watch their hands to make sure they actually used the materials you supplied and that they did the job right. Watch them struggle trying to get the underbelly off and lose half of your fasteners plus potentially strip the top of your oil filter housing. I've seen way to many horror stories to ever take a nice car to Jiffy Lube. The only car I'd ever take there would be a company car.
Old Oct 24, 2011 | 08:21 AM
  #148
Doctodd33's Avatar
ML350
The Jiffy Lube "what if" would prevent me from ever going there....it was more of an open question. Prestige in Miami took care of my ML....they even washed it. Total price for service C was $110 and I was done in 90 minutes. My paranoid self made me check the oil dipstick and it was new oil....lol
Old Nov 5, 2011 | 12:50 PM
  #149
jecarlja4ms's Avatar
Merzedes Benz c300
Here's for SOCAL guys. $269.95 B Flex service.
http://www.penskemercedes.com/service-specials-1.aspx
Old Nov 16, 2011 | 07:14 PM
  #150
tivoboy's Avatar
2016 C450 AMG, 2009 C300, 2001 C320 2001 CLK430, 95 E500
Is there a detailed list anywhere that spells out what is included in the A and B services? (other than what is in post 133)
It seems that maybe the filter adds the 100$ to the B service?
My local dealer has a 299$ special on the B but says I can choose to not do the filter and it would be less.
Also wondering if the 7-speed tranny service needs to be done after 2+ years and 16K miles
You have already rated this thread Rating: Thread Rating: 13 votes, 5.00 average.
