Harman Kardon L7 Rear Bass Speaker Rattles
My bass setting is at 4 and I get serious rattles even at normal listening volume. I could stop the rattles by pressing really hard on the plastic grille with my hand. It's really annoying, do you think the dealer will be able to fix that?
Check in the trunk area, underneath where the speaker is mounting, and look for loose mounting bolts. I had a similiar issue when my quick park got installed.
My rattling varies, sometimes it starts after a particularly bassey (not sure if that word exists) song and then all other songs will rattle even if the bass on them is not particualrly high.
I'm considering taking it to the dealer to see if they can sort it out.
ok well in that case u have the remember that the good comes with the bad, if u turn up the base its gonna rattle some, u gotta remember that although the L7 system is a nice stereo system i really doubt that they built this car to handle the base as loud that u want it to, so in essence its gonna rattle some, yeah could maybe tighten the screws but either way unless u get a pro to soundpoof ur trunk its gonna rattel. I mean people r all saying the same thing meaning there probably isnt anything wrong with ur base.
I'm not into very loud music or extremely heavy bass - I like to listen to music at above average levels and just feel the bass, I used to listen to music much louder on my Opel Zafira with Pioneer stereo and factory fitted loudspeakers and not one single rattle!!
I agree that the sub-woofer is not the problem there must be something loose in the rear deck and that is what Winter230 and myself want to find out.
The rattle I have in my car should not be there because the volume is not that high, expecially if you consider the cost of the MM package...
Just wondering if anyone had any luck getting their dealer to fix this or find a DIY solution for it.
well if thats the case then u should probalby just go to the dealer and have them mess with it.
As far as the rattles, I am sure that the dealer can/will fix it without too much trouble.
fyi...If anyone here has the song Amazing - Kanye West ft. Young Jeezy; pop it in & you will hear some serious rattling - even at low volume levels (& bass @ 0).
Well, except for my car which doesn't have the rattles. Yet.
the I relized it was the rear sunshade
Play the music until you hear the rattle then "lift" the shade rattle stops
It only just started to do this for me. Have not looked yet to see what the problems is.
I left the car with them for a few hours and when they finished with it the rattle was GONE!!!
I have tested the fix by listening to really heavy bass music quite loudly and no rattle!
Apparently the mechanic put extra padding under the speaker grille.
