Fuel Range
My fuel range gauge will honestly move 50 miles (plus or minus) on a two mile drive. It absolutely provides ZERO helpful information on how many miles I have left on a tank of gas.
Does anyone else have this problem?
A two mile distance, from start, is the wrong time to be trusting this predictor. The predictor works well after you've been driving a while (10 min to several hours) and will continue to drive in much the same circumstances.
If that two mile distance is not from start, but in traffic, then it can easily change based on current changes in your driving technique. Start and stop block by block, or a long straight on a boulevard.
In any case, you should watch the actual gas gauge. It's fairly accurate in telling you when you're nearly out of gas.
If I start slow with a full tank, get on the freeway and drive moderately between 62 and 78, my predictor gauge will easily suggest I can drive over 500 miles on the tank. Reality intervenes, though, when I stop, start, hit city streets, and etc. Even so, I often top 400 miles on a tank.
The only real fault I find with this predictor is that once the "feed me" icon appears, it no longer allows you to see the predicted distance available. Sure it was 45 miles a minute ago, but what it is now? Dunno, 'cause it wants to be fed.
And...comparing diesel fuel range to gasoline is like comparing apples to oranges. The big v8 Diesel on the Jaguar that was featured on Top Gear could go 900+ miles.
& I bet the Jag's fuel tank had a lot greater capacity than 66 litres as in the C Class. !!
