Front end lift at 100mph +
Old Jul 20, 2009 | 10:59 PM
evanswan's Avatar
2010 E350 SP / Honda Crosstour / prior vehicles - C32 modded / C300 modded / Lincoln LS modded
Has anyone noticed the front gets light feeling and looses a bit of solidity at 110 mph or higher. should these cars have sufficient aerodynamics for high speeds. My c32 was great all the way to 155mph. freaks me out.
Old Jul 20, 2009 | 11:13 PM
clover168's Avatar
c300
need to add 4 more psi on to the tires when you are going 100+ mph
Old Jul 20, 2009 | 11:59 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
Get a front lip that should help then tested by San Onofre Nuclear plant, plenty on highway and no cops.
Old Jul 21, 2009 | 01:05 AM
JM's Avatar
JM
W204
wait, C300 goes how fast max?
Old Jul 21, 2009 | 07:43 AM
RickP330's Avatar
2019 GLA 250 - I am in purgatory right now...
I think we are electronically regulated around 135? I've only been up to 120...
RP
Old Jul 21, 2009 | 08:27 AM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
When you put those big 19s on there did you also drop the suspension? If you dropped the rear a bit more than the front, that could cause a bit more pressure underneath the car. A deeper lip spoiler would help but it may be more wheel/tire related that aerodynamics.
Old Jul 21, 2009 | 08:59 AM
Mr Enigma's Avatar
MB W204, VW Polo, Audi R8 V10 - SOLD.
Wouldn't a rear spoiler also increase the tendency for the front to lift?
Old Jul 21, 2009 | 09:36 AM
WiseMax's Avatar
C250 CDI
Hmmm, good question.
Old Jul 21, 2009 | 11:08 AM
Glyn M Ruck's Avatar
Super Moderator
Have you messed with the suspension? - These cars are designed to be nose down - On all these forums I see people dumping the tail of the car too far. This allows too much air under the car at speed & messes with high speed stability. The 203s & 204s don't get light at speed if set up correctly. i.e. attitude = nose down tail up! Might look good with the tail dumped but it wrecks stability.
Old Jul 21, 2009 | 02:17 PM
Aachen1989's Avatar
08 C300
it is still very solid when i hit 120.. pretty impressive for an entry level car
Old Jul 21, 2009 | 03:34 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
c300 4m tops out at 132 - 1mph faster than e350 4m...
AMGTTV8's Avatar
2026 AMG GT63 Pro
+1!
Old Jul 21, 2009 | 03:38 PM
RabbitDad's Avatar
C
Must be something wrong with the car, my C200 CDI is rock solid stable at 120 mph on the Autobahn. Actually feels like it was designed to drive like that all day (and it probably was). Strange in fact how this car seems rather noisy at 80 mph, but then stays exactly the same when running at 120 mph.
Old Jul 22, 2009 | 01:34 AM
JM's Avatar
JM
W204
RP
Wow thats pretty good hahaha
Old Jul 22, 2009 | 04:11 AM
08w204's Avatar
2008 MB C300 Sport (Mars Red)
No problems that I've noticed at upper speeds... Check out your PSI. Top speed for me was right around 133, then the electro-mommy took over the throttle for a few seconds...
Old Jul 22, 2009 | 06:20 AM
WiseMax's Avatar
C250 CDI
German fast cars (excl. Porsche) are regulated to a max. of 250 Km/H (155 MpH).
So you should be getting at least 155 mph
Last edited by WiseMax; Jul 22, 2009 at 06:21 AM. Reason: (edited to correct a typo)
Old Jul 22, 2009 | 06:30 AM
08w204's Avatar
Nope.... This is a US-spec C300. I believe C350 might have a higher speed limiter.
Old Jul 22, 2009 | 09:03 AM
C300Sport's Avatar
That was a sort of "Gentlemen's Agreement" for many years but a lot of the high end models have jumped well above. As far as I know, most "regular" but still stout cars are relagated to 155MPH.
Old Jul 22, 2009 | 10:05 AM
TRauppius's Avatar
2009 C350W on EDP
Ditto ....
Yep, this was my experience during my post factory delivery trip on the autobahns. My 2009 C350W cruised effortlessly at 110 MPH, totally composed and very quiet. Other cars I have owned may have been a bit quieter a moderate speed, but the Benz stays quiet as the speed builds up.
I also noted that steady speed MPH actually increased (per the onboard consumption display and actual miles/fuel used measurements) and peaked around 90 MPH.
Old Jul 24, 2009 | 12:23 AM
kevsc350's Avatar
'08 C350
And "nope" to that too! 133 is the limit for the US spec C350 as well. And with the tire pressures correctly increased for the higher speed, it's rock solid with no front end lift or hint of instability.
