Wheel Information Thread
Old Aug 20, 2016 | 12:52 AM
  #101
Josh.A.Hussey's Avatar
2017 C43 AMG, 2010 C350 4Matic, 9 Motorcycles
20's are hard to do on these cars. Do you have a 4Matic? If so, it's near impossible.
Old Aug 20, 2016 | 09:49 AM
  #102
Colin G's Avatar
2008 C-230 4Matic Sport
Hello everyone.
I'd like to know if this offset will work on my 2008 C230 4matic. If the offset will work, will a 255 be too wide on the rear? They are 18" AMG rims.
OEM Merecedes rims off a new E550. wrapped in Yokohama YK58 near-new rubber.235/40R18 fronts and rears 255/35R18 with offsets ET45 and ET48.
Any help would be very much appreciated as I need to act fast on the wheels. I don't think they will be for sale much longer.
Old Aug 20, 2016 | 10:33 PM
  #103
Colin G's Avatar
Originally Posted by Colin G
Hello everyone.
Looks like they may work but am unsure if they will work with a 4matic but I am assuming that is more of a larger diameter restriction rather than offset. Rears would be an offset difference of 10mm wider if I am correct.
I did some digging and found this:
My car currently has:
Front tire Size: 225/45 R17 Wheel Size: 7.5J x 17 ET 47
Rear tiire Size: 245/40 R17 Wheel Size: 8.5J x 17 ET 58
C300/C350 (non 4Matic) Wheel Information
Diameter Range
17" - 20"
Width Range
Front: up to 8.5"
Rear: up to 9.5"
Offset Range
+40 - +54
Bolt Pattern
5 x 112
Old Nov 24, 2016 | 02:22 PM
  #104
askaz's Avatar
Mercedes Benz C220 CDI Sport
Input on this set up
Hi fellow enthusiasts, hope I can get some help with this.
I have a C220 CDI sport model with stock staggered 17" wheels.
A friend of mine has a set of 19's off his audi wagon that im looking to buy.
They are
19x8.5 +42 front 245/35/19
19x8.5 +42 rear 245/35/19
My current wheels are 225/45/17 front and 245/40/17 rear.
Will this set up work/does anyone else have this set up?
Cheers!
Old Mar 6, 2017 | 02:46 PM
  #105
psbenz12's Avatar
2006 E350
The wheels I'm going with are 18x8 +42 || 18x9.5 +48... TireRack suggests this tire size: 225/40/18 and 255/35/18
I wanted to have a little more tire to protect the wheels and maybe a little smoother ride-
Will I be able to run this setup without rubbing?
Front: 18x8 +42 245/40/18
Rear: 18x9.5 +48 265/35/18
Old Nov 1, 2017 | 06:23 AM
  #106
Manton's Avatar
Mercedes C300
Front:225/40R18 on 8.5 wheel Rear: 255/35R18 on 9.5 wheel
Old Mar 26, 2018 | 08:03 PM
  #107
Mce22Usa45's Avatar
2008 C300 Sport 4MATIC
Wheel/Suspension Setup ????
Looking to do the following setup on my W204 C300 4Matic Sport... Will I have any issues? Should I get spacers for the rear wheels? Ideally, I would like the wheels to sit flush with the fenders with a minimal tire to wheel well gap..... and of course have no rubbing!
Front:
18x8 w/48mm offset
Bilstein B6 Performance Strut
H&R Sport Spring Set
Rear:
18x9 w/45mm offset
Bilstein B6 Performance Shock
Old Jan 18, 2022 | 01:35 AM
  #108
amro_0098's Avatar
2007 c230 #w203
Is this the same for 2007 C230 #W203...?
Old Aug 24, 2022 | 02:56 AM
  #109
ericjhen's Avatar
2008 Mercedes C300 Luxury and 2012 Mercedes C350
I have a 2012 C350 coupe with 19 inch wheels, when I hit some bumps the outer wheel well lip rubs the tire, how can I stop this without dropping to 18 inch wheels?
Old Aug 3, 2023 | 05:05 PM
  #110
usmaan99's Avatar
c250 coupe 2011 204
Do w205 rims fit a w204
Will these rims fit a w204?
