Cost of transmission and sun roof service???
I already did the oil change service and would like to know how much others are paying for the transmission and sun roof service.
I'm likely to get the MB dealer to do these and would like to have a ball park idea of how much it cost so I don't go into cardiac arrest when they pass me the bill.
Thanks in advance.
Thanks in advance.
Cleaning and relubricating the contact points.
I really want MB to do the tranny service. If it goes out, I'd have a better case against MB. By the way, isn't 39K a little on the low side for getting a transmission serviced? Thought it was a bit strange as most cars its higher.
Thanks in advance.
I haven't opened the sunroof once since I bought the car, I'll be skipping that.
nyca, I asked him about me needing the sunroof maintenance given that the car is only 2 years old. He said that the lubricant still dries out and that I'll still want to lube it. Since he isn't pushing that they do it and is going to show me which lube they use so that I can do it myself, I think he's probably right about the car needing it.
Having thought about it for a few days, you're pretty much at MB's mercy about this. If you follow their recommended maintenance on the transmission and it later breaks, you can at least claim that you followed their recommendation. If you don't, you can bet that they'll tell you that its your fault and they can't help you.
My MB mechanic who I have no reason at all not to trust, recommends that I change the oil in the 5 speed box at 60,000 km. I plan keeping the car for 15 years or until I fall off the perch so will comply.
I noticed that there is also a brake fluid replacement at 2 years.
If you don't mind, please check with your MB mechanic to see what he says about that.
