Ideal Tire Pressure
Old Sep 4, 2009 | 04:15 AM
supacrazykev's Avatar
GLE 450 2021, SLK 350 2013, Honda Civc Type R 2019, Suzuki GSXR 750 2014, Ducati Diavel 2018
Ideal Tire Pressure
I just purchased a C350 Sport Package with 18'' AMG rims... The recommended PSI for front is 33 and the 38 for the back tires. Does anyone recommend any other tire pressure settings based on performance or comfort. I'm currently using 32/35. Should I just use the factory settings.
Old Sep 4, 2009 | 04:26 AM
jturkel's Avatar
02 C32 AMG
when you say recommended, is that what is recommended on the tire? or recommended in the driver side door jam of the car?
and shouldnt you post this in the CLK section?
Old Sep 4, 2009 | 04:41 AM
The recommended PSI on the gas door. I have C350 as well now.
Old Sep 4, 2009 | 05:06 AM
jturkel's Avatar
02 C32 AMG
oh musta missed that, my bad
you mentioned it is a different rim size. is the width/height of the tire the same as those without those rims? if so, i'd go with the stock recommendations on the gas door.
if not, i'd go with the recommendations on the tires since the gas door specs will be specific for the stock tire size
Old Sep 4, 2009 | 03:49 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
i run the recommended 100mph+ pressures...
35 & 40 f/r..
takes away some of the squatting under braking and improves responsiveness and predictability in the turns...
Old Sep 4, 2009 | 04:53 PM
Cools thanks
Old Sep 4, 2009 | 05:30 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
There is no recommended pressure printed/embossed/etc on the tires. That is max. And that takes a lot of different factors into consideration.
Old Sep 4, 2009 | 05:37 PM
JimPap's Avatar
2008 C300 Sport, RWD, US
Two variables that need to be taken into consideration.
Top speed and weight.
Heavy foot and/or usually loaded(not alchohol related), use the figures in the gas cap.
More reasonable driving and mostly just yourself, use the figures in the door jam as a starting point and experiment. I found that the pressure I used for my front tires needed to go up as I put miles on the tires.
Old Sep 4, 2009 | 11:16 PM
I'm not going to "heavy foot" this car. I just desire something with comfort and good control for some unpredictable events. I'm up for any suggestions and then i'll try them out.
Old Sep 4, 2009 | 11:37 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Druck
I've been using 35psi in the rear because it softens the ride a bit and I never have any backseat passengers or much in the trunk. Tire wear is normal.
You can play with the pressures a bit to make up your own mind.
The TP shown on the sidewall is max allowable, not running pressure.
Old Sep 5, 2009 | 01:21 AM
C300Kid's Avatar
2015 Carrara White Metallic Porsche Cayman
35 & 40 f/r..
sweet..im gonna try this tomorrow
