Will this Fakra cable work for the Kenwood backup Camera?
Old Sep 6, 2009 | 11:09 AM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
it is a fakra female to female rca plug?
will this work, or do i need a fakra male plug to plug into the back of the command unit????
http://cgi.ebay.com/GPS-antenna-Exte...d=p3286.c0.m14
Old Sep 6, 2009 | 06:29 PM
rb23lb's Avatar
what is the command fakra connector required to plug into the back of the commend unit, male or female? are their male and female FAKRA type plugs or are they all the same???
Old Sep 7, 2009 | 04:49 PM
rb23lb's Avatar
anybody installed the backup cam or an aux video source that knows if this is the right cable???
thanks in advance
Old Sep 7, 2009 | 06:08 PM
aprince2die4's Avatar
08-C350 black/black
I would also like to know if this cable will work...seems like a good price and its better than trying to make one myself
Old Sep 7, 2009 | 09:17 PM
cbcharlie's Avatar
2009 C300 4Matic Sport P2/MM/Steel Gray
I'm not 100% sure but I don't think 'that' cable will work. That cable is a fakra C (gps) cable, I THINK you need a fakra A (radio) cable. The connectors are slightly different. Hopefully somebody else can confirm if I'm right or wrong.
Old Sep 7, 2009 | 10:40 PM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
I believe it is the FAKRA A you are looking for. They sell it at Best Buy as a FAKRA to a antenns plug, just cut the antenna plug off and soldaer on an RCA.
Old Sep 8, 2009 | 11:50 AM
theinmoe's Avatar
C350
Looks like this will work.
http://cgi.ebay.com/Radio-antenna-Ex...d=p3911.c0.m14
Old Sep 8, 2009 | 01:18 PM
rb23lb's Avatar
Originally Posted by theinmoe
see my new thread, delete this thread
https://mbworld.org/forums/c-class-w...7-shipped.html
Old Oct 3, 2009 | 05:54 PM
cbcharlie's Avatar
fyi this cable took about 20 days to receive and a standard rca cable wouldnt connect to it . I would stay away.
Old Oct 4, 2009 | 09:39 AM
mirage15's Avatar
c300 4matic
Well that sucks. I am still waiting on mine. What do you mean by a standard RCA not fitting? Is their a different RCA that I don't know about?
Old Oct 7, 2009 | 12:08 PM
cbcharlie's Avatar
Not sure if there are different RCA types, but I couldn't fit an rca cable into the connector. The hole was way to small. I tried to make the hole bigger and ended up breaking it. If you want a solder free easy cable I would just order one from midcity enginerring, although I hear they are expensive.
Old Oct 7, 2009 | 12:32 PM
08-C350 black/black
If I remember correctly midcity was 21.00 shipped or 21.00 plus shipping
Old Oct 7, 2009 | 06:55 PM
mirage15's Avatar
c300 4matic
I got it today. The connector that they are calling an RCA really isn't. I forget the name of it though. I ended up cutting that end off and soldering RCA ends on from radio shack. Everything works great now.
Old Oct 8, 2009 | 02:36 AM
JasonHu's Avatar
2012 C300 4MATIC, 2014 Tesla Model S P85
This may be offtopic, but do you DIY rear-view camera guys wire the ACC power and the reverse sensor wire into the same reverse light power?
Old Oct 8, 2009 | 11:31 AM
white46's Avatar
08 C300
that's how I did mine.
Old Oct 8, 2009 | 06:56 PM
cbcharlie's Avatar
$32 shipped, I e-mailed them.
Old Oct 9, 2009 | 03:27 AM
Nuru's Avatar
S350 BT 4MATIC
The MidCity cable has the correct right angle connector. So it will fit behind the COMAND HU without putting weight of the unit on the cable.
Old Oct 15, 2009 | 08:40 AM
mario.ts's Avatar
W204
Exact cable is this one :
http://www.car-interface.com/product_detail.php?id=226&mode=14
18 bucks plus shipping I think. Expensive but perfect.
On ebay you can find a FAKRA A type. This will fit the Comand, but the proper cable is a FAKRA E type. For video signals. Green color like the Comand connector.
You can buy both A and E and it will work but if you want the perfect fit you need an E type. The one of the link. Ciao
Old Oct 21, 2009 | 07:46 PM
cbcharlie's Avatar
I ordered the cable from midcity, didn't wanna take the chance at getting the wrong cable AGAIN. Don't feel like waiting another 15 days for a second cable. Midcity told me i'll have it in 2 days.
Old Oct 23, 2009 | 10:02 PM
cbcharlie's Avatar
Well guess what happened, midcity sent it to the WRONG address! Luckily someone in my town called the number on the package and I was able to pick it up. The world doesn't want me to have it.
I finally replaced my crappy home-made cable with the correct cable, finally 100% done with my rear camera installation!
