Get VIM by doing a Hard Drive Hack
Old May 13, 2010 | 12:11 PM
  #101
matthew121170's Avatar
2012 E350 - Cabrio; 2017 GLS 450
Originally Posted by Krytech
VIM would be a cool thing I'd probably use once just to do it. However it would be nice to be able to manually enter addresses in to the GPS while driving. Sucks that even my wife can't do it while I'm driving - stupid "save us from ourselves" mentality... It would also be nice to be able to upgrade the HHD to a larger size. But in reality, I haven't even half filled my current drive - the SDHC cards are just too convenient - and you can't RIP a CD while listening to something else. It would be nice if you could copy from the memory card to the HDD directly.
I just updated to Version 6 of the Nav and I can now enter address, change song names, and upate my phone book on the fly. Maybe someone got the hint and enabled those features. I have not tried watching a DVD though.
Old May 13, 2010 | 01:05 PM
  #102
wanchu83's Avatar
C300 Sport LOADED
try it and let us know.
  #103
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
Wow, so the new nav update removes those lockouts?? That's nice! I would imagine that WIM is still locked out since I think that's the law here in the states. But just being able to enter addresses while the car is moving would be a welcome feature!
Old May 14, 2010 | 05:43 PM
  #104
mirage15's Avatar
c300 4matic
No need to over-think this entire thing. It can absolutely be done in a firmware update w/ auto update disk... Just like a firmware upgrade from MB. The COMAND in these are MELCOs. They are almost identical to the Mitsu's.
At one point I am pretty sure that we found the field that needed updated but all of us got busy with work and didnt have the time to pursue the auto update disk.
Old May 18, 2010 | 12:27 PM
  #105
Draz's Avatar
2012 MB E350 Coupe
So are you close to cracking it Mirage?
Old May 19, 2010 | 12:17 PM
  #106
iatacs19's Avatar
axe muderer with headlights
I updated to the latest maps and I cannot do any of the things mentioned above. Everything is still locked. I have an 09 c63.
Old May 19, 2012 | 08:01 AM
  #107
robert4713's Avatar
SLK R172
VIM for Mercedes
Hi,
i just bought my brandnew SLK 250 CDI with command online and dvd-changer and i am trying to unlock video in motion.
This thread sounds very interesting, i have also read the complete mitsubishi thread. But the last post is exactly 2 years old. It says, it can be done - but - is there any result for vim?
Did you get it work with an update stick or cd/dvd or can you patch the hdd?
Thanks a lot
Old Feb 1, 2013 | 07:55 PM
  #108
stosoorok's Avatar
w211, s204
Originally Posted by robert4713
...the last post is exactly 2 years old. It says, it can be done - but - is there any result for vim?
Almost a year again... What about larger HDD? Anyone done it successfully?
Old Feb 10, 2013 | 04:01 PM
  #109
stosoorok's Avatar
w211, s204
HDD replaced. Everything works but music register shows still 6GB. HDD2 is actually 46GB. Strange.
Old Feb 11, 2013 | 07:37 AM
  #110
ltcinf's Avatar
2010 C350, 2011 BMW 328xi
Could this be a partitioning issue then? Also how did you do what you did with the new hard drive? I would l Think that if you could replace the current hard drive with a solid-state drive you would have better performance with navigation? Lastly there's got to be some really supersmart computer guy On this forum that can figure out how to crack the VIM.
Old Feb 11, 2013 | 12:38 PM
  #111
stosoorok's Avatar
w211, s204
I think this 6GB limit is in comand firmware like VIM. You can see on the first image that comand actually sees right size (HDD2 - 46GB).
Same in computer:
This hdd mod was only for testing that it can be done. Samsung hdd working temperature is +5...+50 degrees C, but our winter is way colder and summer in car temperature may be over +50 degrees C. SSD working temperature is like -50....+80 degrees C.
To do:
1. Copy more than 6GB mp3s to hdd and see what happens
2. Find PATA SSD.
Old Feb 12, 2013 | 08:55 PM
  #112
theinmoe's Avatar
C350
Same in computer:
To do:
2. Find PATA SSD.
Are you able to see the content of hdd1, VIM setting is in Windows CE I think. Otaku_tta from http://www.takingthingsapart.org/ help Mitsubishi guys with same MELCO head unit.
Also how did you unlock and clone the HD ? Did you use Otaku code? dont keep us hanging, thanks.
the two codes for the 204 are :
B2 BA B3 BC B0 DF AC BE B1 BB BE DF B1 AD D2 CD CF CB DF B1 9E 89 96 DF AA 8C 9A 8D DF DF DF DF
and
B2 BA B3 BC B0 DF AC BE B1 BB BE DF B1 AD D2 CD CF CB DF B1 9E 89 96 DF B2 9E 8C 8B 9A 8D DF DF
same as for the 261, one is a user code, the other is a master code.
Old Feb 13, 2013 | 12:09 PM
  #113
stosoorok's Avatar
w211, s204
Yes it's a laptop HDD (automotive grade) with FAT32 file system.
HDD1 - 1GB partition with some screen backgrounds and I didn't dig any deeper. But maybe there's something more, have to double check.
HDD2 - 7GB Music register with cd database info.
HDD3 - 1GB Phonebook, business cards and some log files.
HDD4 - 28GB Navi partition with maps and voice guidances
I didn't see any windows files there. I think windows files are in comand flash because comand works fine without HDD.
Yes I used Otaku's first code and it worked great.
Passwords:
http://www.takingthingsapart.org/ind...d=72&Itemid=92
ATA password unlock:
http://mitsubishiforum.com/forum/mit...ck-mmcs-25583/
Some guy who unlocked it in windows:
Hiren's bootcd for cloning and partition resize:
http://www.hirensbootcd.org/
I did a raw cloning and then just resized hdd2 to max available space. If anything still unclear, then just ask!
I've heard that you can enable VIM with MB Xentry Vediamo Factory Software. About €1000 + multiplexer hardware hack and you can make some money.
Old Mar 1, 2013 | 08:45 AM
  #114
stosoorok's Avatar
w211, s204
Little update. I got some good news and bad news. So the good news is that my Samsung hdd works great even in very low tempereatures like -10 degrees C. No error codes at all checked with Xentry. Also I found some interesting features like VIM but all settings were greyed out. So this "Xentry (Vediamo) with developer mode" rumour may be true after all.
And the bad news. I burned two mp3 discs one Verbatim DVD-R DL and 2nd DVD+R DL so about 8,5GB + 8,5GB of data for the HDD2 expriment. The file manager starts fine and then it starts coping. After couple of minutes "Coping failed" and the disc is unreadable. Same story with the 2nd disc. Then I burned two regular DVD+R 4,7GB. First one copied successfully. Then checked music register memory it showed 1,3GB free. Inserted second dvd and it started coping. Then suddenly this appeard:
There is no point to add bigger hdd to the comand. Music register size is limited to 6GB in the comands windows ce 4.2. Only thing I recommend to do is the image of the original hdd. If the original hdd fails you have a backup and with couple of bucks you can add "new" hdd. I rather not say how much the dealer asks for it.
So what now? Cheap PCMCIA SDHC card readers here I come with 32GB micro SD from my phone.
https://mbworld.org/forums/c-class-w...ory-works.html
Old Apr 10, 2014 | 09:15 PM
  #115
nhoj_yelbom's Avatar
sorry to ask, but anyone crack ntg4 w212 2010 E the same way?
Old Feb 15, 2019 | 10:55 AM
  #116
JLourenco's Avatar
C220
Hi
Someone please can help me? I know that is one old thread but I have one W204 with HDD 30GB, and would like to upgrade to HDD 40GB to get the lasted MAPS that can only be upgraded to 40GB HDD.
I purchase a few HDD 40GB to do this, already use 2 without any luck.
1 - Format to FAT32 all in one, 40GB and put in car hope that we created the partitions, nothing lock the HDD and the radio only see HDD1 with almost 40GB (+- 38GB) and could not upgrade from DVD the maps, also now its lock so cannot see on Windows or reformatted.
2 - Format to FAT32 with these 4 Partitions (bellow): HDD1 - 1GB, HDD2 - 7GB, HDD3 - 1GB, HDD4 - 28GB. Nothing lock the HDD and the radio only see HDD4 with almost 40GB (+- 38GB) and could not upgrade from DVD the maps, also now its lock so cannot see on Windows or reformatted.
Can someone please help me to know how to format the HDD, or how can upgrade my HDD.
Step by step please...
Read all the info up, but still no idea.
Thanks guys,
JOSE
Passwords:
http://youtu.be/ExxehCRBQ4I
Old Feb 15, 2019 | 05:08 PM
  #117
mirage15's Avatar
c300 4matic
Jose -
I would try cloning your current HDD to the new one first... then try the upgrade and/or resize the partition appropriately.
Originally Posted by JLourenco
Hi
Thanks guys,
JOSE
Old Feb 18, 2019 | 07:01 AM
  #118
JLourenco's Avatar
C220
Hi Mirage
Thanks, but to do a clone I must see the HDD on my Windows and I could not.
The original 30GB I cannot see even with the RST (Intel Rapid Storage Technology)l, like the video above.
Any idea?
Old May 20, 2019 | 05:21 AM
  #119
mobilman's Avatar
c220 w204
HDD replace problem
New HDD
New HDD
New HDD
New HDD
Old HDD
Old HDD
Old HDD
Please Help!!
Change HDD 30GB to 64GB KingSpec SSD PATA/IDE/ not work navigation and update error .Please look atached photo and please help. Old HDD not complet update only 43%.
Old Oct 30, 2020 | 02:46 AM
  #120
lopezaguirrej's Avatar
c250
Hi do you have files from video in motion I have c250 2017 (w205) If you have please shared pleaseeee
Old Oct 30, 2020 | 02:55 AM
  #121
c250
There has been a software hack on C63s?
The VIM kit is way overpriced in my opinion. I also do not like how it integrates. I would prefer that the entire system works as it does now but not kill the video while rolling down the road.
Old Dec 22, 2020 | 12:57 PM
  #122
stosoorok's Avatar
w211, s204
There are only one PATA/SATA adapter that work I have heard. I recommend to stay with automotive grade HDD and DO NOT UPDATE MAPS with old laser! I bricked my comand.
