Get VIM by doing a Hard Drive Hack
I have been working on this with Kurosen and Otaku for a little while now. Vic hooked us up with the firmware disk (Thanks Vic!) and I may have found something in there. I have an email out to the other guys to see if it is real or not... We will keep you posted
I practically dreamed about a software VIM hack. You know what we should do. Let's all chip in $10 each and get Geohot (http://en.wikipedia.org/wiki/George_Hotz) a new W204. It shouldn't be hard to find 4000-5000 interested W204 owners, should it? He seems to be pretty good at hacking everything and would probably appreciate this offer. Being that he just hacked the "Unhackeable" PS3 that is considered to be the most secured consumer electronic device on the market to date, VIM for W204 should be a piece of cake for him.
I could hack VIM in about 15 seconds if I had an emulator, but I'm not going to put in the year of development it would take to write a working emulator. Also, George Hotz didn't hack the PS3, he exploited one layer of security using the same technique that was used to hack the Gameboy. He can't however, run so much as a "HELLO WORLD" because his exploit completely crashes the system and the PS3 has layers of security in both hardware and software while the Gameboy had only one in the software.
EDIT: Is there a guide for removing the COMAND unit?
And yes, maybe George Hotz did not completely write custom firmware for PS3, he did find and released the exploit which gave him read/write access to the entire system memory, and HV level access to the processor. Nobody else done this to this date. He broke one of PS3 security levels. The rest will follow. Taking into consideration his contributions to the community, his is certainly one of the planet's most prominent reverse engineers and this would be a pretty easy task for him.
I should check what it costs around here.. i was thinking about installing it myself, but then again.. i'm a bit afraid to damage the dashboard..
Did anyone do this installation by himself?
Somebody before mentioned that it was possible for a technician to manually remove the 5mph speed limit for the command system... Is this possible or was it just a joke?
Maybe Vic can confirm?
Just a couple issues with this:
The W204 is *not* the same as the mitsubshi unit... On the W204 the firmware, settings and VIM code resides in flash... I have sitting in my lab right now a W204 command that has no nav, no music server, and most importantly no hard drive... (base W204s are available with DVD but no nav or hard drive) and the vim and settings all still exist and are changeable... Why? because they dont reside on the hard drive...
The DVD map update disc does not have the VIM code on it.. You need the telematics update disc.
If you want to be able to enter nav/voice/data while in motion you dont need to hack the command, our VIM/programmer (shameless plug) performs recoding of all the data lockouts as well so that they always allow data entry... even if the VIM module is turned off.. you can see how that works here:
http://www.youtube.com/watch?v=F6s40YpjhZo
The reason I know this is because a few colleagues and I perfected many of these attacks against secure smartcards 8 years ago...
Anyway, if you guys *really* want to try to attempt a software hack of the comand, Ill be glad to help and point you in the right direction and even provide some support but you are going to have to put in the work on this... A good place to start with this is for someone to pull their command and open it up and get pics of the motherboard so that we can ID the processors and memory chips...
