sprint booster
What does it do ... improves the throttle vs pedal response curve. Put the car on a Mustang dyno, and measure steady state power or torque at 1/4, 3/8, 1/2, or 2/3 max throttle, and the wheel power values will be much higher than w/o the booster.
From a stop, in an atx, snap throttle to any of these pedal positions, and the car will accellerate quicker with the booster.
Some like more power at lower pedal displacements, giving the feel of a higher powered car. Before DBW, GM used eccentric cam pulleys on the carbs to give the same high gain at small pedal motion, and the feel of a larger engine, but little added power was available above 70% pedal stroke, like the Booster.
I might like the fact that the Booter negates the need to use the last ~15% of pedal stroke which has high resistance to motion .... nothing spoils a nice gas pedal feel like a step function change in resistance to travel.
"What does this mean? Basically, the Sprint Booster makes the accelerator pedal
about 30% more sensitive. A side effect, which can readily be seen in the graphs
in Figure 3 and Figure 4, is that the accelerator pedal becomes dead beyond about
two thirds travel with Sprint Booster.
It is important to note that any accelerator signal into the ECU using a Sprint
Booster can be duplicated exactly by a driver without a Sprint Booster, merely by
pressing the accelerator pedal a greater distance."
I would suggest the SB simply improves part throttle response.
This is because the SB is simply telling the computer that I pushed the throttle further than I actually did. You can just press the throttle further without the SB and achieve the exact same result, with the exact same lag.
The downside to the sprint booster is that since it is "lying" about the throttle position, once you get past 70% throttle, your gas pedal isn't actually doing anything - you are already at full throttle and have a huge dead spot. What good is this? Look at this graph from the sprintbooster website SHOWING the dead area that it creates in your throttle -
The device does not reduce lag. I honestly wish there were a device this simple that could reduce the horrible lag that Mercedes engineers into their cars.
The white paper showed true lag, with or w/o Booster, as minimal ( Fig2, Fig4, and Fig5 )
Fig1 shows lag by design, as the %throttle position curve is well below the % pedal position curve. This lag in expected reponse is fixed by clever use of op-amps.
Experience tells me that true lag is not negligible & is programmed in - as with the TCU & many other Benz devices including the aircon.
It also tells me that that all ECUs are not set up the same dependent on market where the car is sold.
The first thing ECU tuners do in this country is delete the lag. I've sat down with a young Prof. at one of our local universities & watched him do it on a Benz V6 ECU. It is also interesting that the ECU tune on a Merc is pretty much optimised. It's difficult to improve on. You gain in some areas & loose in others. Some tunes can threaten engine longevity.
acr - I want out of this thread. It bores me to death. That's it.
otherwise we have to baklei
So dont be so befoeterd
about the kappie, in The Netherlands we dont have a kappie on the e
We also havent a deurtrekkertjie here, we call it string
Enjoy your naweek
I love those south african words...
The power throttle is ready to order, Euro 399,00 + shipping costs
If you want to know more pm me.
Geen bakleiery of geskreeuery of slanery/aanranding nie.
because i am about to install to my C63 2008 AMG and i not sure should i do it or not? after reading what you wrote i am now having second thought?
Seems like the thread was titled something about free sprintbooster.
