Lamin-X headlight/fogs, a personal review
Old Oct 23, 2009 | 08:52 PM
imboom's Avatar
Hey all,
Decided that many people are quite confused about the differences between Gunsmoke and Tint Lamin-X headlight protection and still are not yet set on what they should get. I picked up tinted version for the headlights and the gunsmoke versions for the fogs. Feel free to post their results of lamin-x also,
Couple things I noticed about Lamin-X
a) These are extremely thick films. I can see how it protects really well.
b) You will need considerable amount of patience for this, applying and reapplying to get things right.
c) A hairdryer and heat makes things much more easier. I had no place to plug in hairdryer(apartment ftl), so I did this at noon(90 deg in Hawaii) and let my headlights(bi-Xenons) to heat up the housing a bit before I went ahead and did it.
d) Do not let the film touch anything. My dog sheds alot and he was nearby while I did this. Somehow some strands of fur got into the back of it. He wasn't even next to me when I took it off it's backing. It isn't totally noticable though.
e) Removing the fog light covers makes things easier. Alternatively, you can leave them on and tuck the lamin-x film between it, but I highly recommend removing it first.
f) You would think the headlights are easy. They are not that easy. I won't even going to bother doing lamin-x for rear lights.
Comparison between P2 BiXenon(right) and Lamin-X Tint(left)
Also, with the bulb of the fogs being yellowish, the gunsmoke film creates copper light from the foglights. I like.
21mp resolution: http://farm3.static.flickr.com/2435/...effd4eec_o.jpg
Side view:
21mp resolution(to see bubbles): http://farm3.static.flickr.com/2748/...f25c3b82_o.jpg
Old Oct 24, 2009 | 03:51 AM
Peabody's Avatar
I'm definitely switching my headlights to tint when winter is over. You've really got to get rid of those orange markers though.
Old Oct 24, 2009 | 09:11 AM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
I already removed my Gun Smoke headlight tints and most of the tail light films (I left the clear center tinted). They were alot darker than I thought they would be and definitely not accurately represented on the websites color comparison chart. I had the Tint version before and it is much better.
BTW- lamin-x is sending me a new set of tail light films because of a problem with the film not adhering to the odd contours of our lenses.
Old Oct 24, 2009 | 09:48 AM
MBreezy's Avatar
'09 C300 6spd MT
Nice post...any feedback on whether the tint affects the light output of the headlights? Does it darken/reduce it at all?
Old Nov 5, 2009 | 06:55 PM
weehyung87's Avatar
09 C350 4M/ 09 ML350 4M
Did you end up cutting the sides of headlight lamin-x films?
Old Nov 5, 2009 | 07:59 PM
imboom's Avatar
MBreezy: No noticeable headlight difference.
weehyung87: You mean tabs? You can actually tuck them in. Makes removing much easier. If you meant by the headlight film being too big, I never had a fitment problem of it being too large. There are actually some parts of the headlight film that falls short(2mm or so) from the top. You won't even notice it though.
Old Nov 5, 2009 | 09:02 PM
rh71's Avatar
'10 C300 Sport
why no rear lights? Because of time consumed? Was it trouble getting the bubbles out? I'm going to attempt it tomorrow in the warm garage + blowdryer. If your flat surface was difficult, I don't know about my tails because it curves out in the middle. Also worried about this thick film sticking outward making it look weird.
Old Nov 6, 2009 | 12:07 AM
Mike_2011's Avatar
2009 C300 Sport
Are the Sport and Non-Sport Headlights the same size only the fog light size changes right?
Old Nov 6, 2009 | 09:41 AM
TB5...'s Avatar
2009 C300 4Matic
wtf camera are you using!
21 mp!!! damn!
Old Nov 7, 2009 | 05:34 PM
dalazernet's Avatar
2020 GLC300 4MATIC
21 mp!!! damn!
Looks like a Canon EOS 5D Mark II... F8 with exposure of 1/125...
Nice camera btw :-)
Old Nov 7, 2009 | 08:11 PM
imboom's Avatar
The biggest concern I have is the fact that the Lamin-X headlight set, although it is the same outside shape of the headlamps, it did not compensate exactly for the three ridges we have towards the sides. This made it much more difficult to install than it seemed and thus with the bigger and more pronounced ridges, it actually might not come out looking good at all.
The bubbles as of today are almost all gone. I have 1 bubble that is noticable left.
Nice camera btw :-)
You are right. Good observation of EXIF! Thanks!
21 mp!!! damn!
Dalazernet got it right. Canon 5D Mk II 24-105mm f/4L IS.
Some of my work is at www.flickr.com/photos/john_ng
Best work imo is at http://www.flickr.com/photos/john_ng...7615469306413/
That is correct. Keep in mind while ordering Lamin-X, to pick out the Sport set if you have the C350/C300 Sport.
Old Nov 7, 2009 | 09:59 PM
rh71's Avatar
'10 C300 Sport
Well I did it last night on the X taillights and while the flat parts (2 of 4 pieces) were simple, the 2 curving & raised lights on each side were a real pain. It was 70F in my garage, barely, and I used a blow dryer. I can see how it would help if it were much warmer - it wouldn't be as hard to bend around. It left some space at the end of the curve, top and bottom - less than a half inch but it's still there if you look closely. I've got a few bubbles here and there that I hope the sun will take care of after a few days. Thanks for confirming it should.
Old Nov 9, 2009 | 05:51 PM
w204maniac's Avatar
c200 kompressor
if someone wants to take off the films,is it easy?in what way we could take it off?
is a self adhesive material?
what about a glue after uninstalling?
is it worth the money and the time?
Old Nov 9, 2009 | 07:46 PM
imboom's Avatar
To remove the film, simply mix a solution of alcohol and apply on it and peel. Finish by apply goo-gone or similar safe solution to the left over residue.
The material is self adhesive and will require some patience of the installer. Is it worth the money? In my opinion, yes. It looks much more aggressive and protects the headlamps from yellowing and chips.
Old Dec 20, 2012 | 08:17 PM
Titus's Avatar
'16 C300
Back from the dead!!!
Those look great! I love the tint.
What kind of prep work has anyone done to the lenses before applying the Lamin-X?
I was thinking clay bar the lenses to remove any tiny particles stuck to the lens, then alcohol to remove any chemical residues.
Thoughts, suggestions?
Old Dec 20, 2012 | 08:42 PM
snowmuch's Avatar
C63 AMG
Man that looks so good, I messed up mine...
Old May 17, 2013 | 07:08 PM
aznmode's Avatar
2010 c300
Found this tread googling for lamin x headlight tint. Awesome job and looks great. Planning on doing this once I get my tints done.
