Fogs replaced with LED !
Old Nov 30, 2010 | 05:21 PM
  #76
Derspeed's Avatar
X3 and 2012 C coming soon
[QUOTE=BO Knows;4373098]This is from a different company:QUOTE]
I like the diffuser.
Old Nov 30, 2010 | 07:58 PM
  #77
Joearch's Avatar
2010 C 300
I am sure I would be in a minority, but I like the stock round fogs that came with the car. Seems to me that the LED's are incongruous with rest of the car.
Old Nov 30, 2010 | 10:38 PM
  #78
Rogwp's Avatar
2010 C300 4matic Special Edition
Red face My opinion
No you are not alone Joe. I bought my 2010 new because it had the fog lights, I could have waited, but, to me, the LED lights look tacked-on and not part of an overall design concept. I am sure that MB is capable of designing a car that incorporates LED DRLs in such a way that looks as if it were part of the original design and not an afterthought.
Old Dec 1, 2010 | 01:50 AM
  #79
Derspeed's Avatar
Yes. I previously commented that they look like an afterthought. Maybe they will look better with the facelift or the next C.
Old Jan 14, 2011 | 01:37 PM
  #80
s550 vellano's Avatar
2007 s550
I did facelift on my 07 s550. Mastertunning help me out but I'm having one. Problem when I turn headlights on led on bumper deems down. I put 2010 s63 led lights can anybody. Help please. Thx....
Old Jan 14, 2011 | 05:44 PM
  #81
jctevere's Avatar
2012 C250 Coupe
It is supposed to do that. My sister's OEM LED on her 2011 c300 does the same thing. This is because when the headlights are out the led's go to the dimmer setting because they would be too bright at night and blind everyone else on the road. It just means that the place you got it done did a proper and good job!
Old Jan 16, 2011 | 05:28 PM
  #82
2007 s550
Thx for ur reply.
Old Jan 17, 2011 | 01:15 PM
  #83
FLawless32's Avatar
c230
Looks really good. Found replicas but dont know if there worth getting.. Deff a nice mod to hook up the car. Nice job.
Old Mar 5, 2011 | 03:27 AM
  #84
step749's Avatar
w204 c250 cdi
Hi,
I start by saying that:
to mount your kit you must disconnect the fog lights.
This process automatically determines me the error "failure fog left and right. "
Proceeding with the connection of your kit, the plug of the fog light is disconnected.
The installation was done in two different ways:
1° MODE:
1° step :
The electrician has connected the "black wire" to the machine frame to create a ground circuit.
2° step:
The "red wire" has been linked to the ignition of my car so when I turn the key, the LEDs light up.
3° step:
The "blue / white wire" ,in the manual so called "A", has been linked to the positive pole of the fog light.
Because the controller is supplied with the kit allows different modes of operation:
1st: Only DRL
2nd: DRL + POSITION LIGHT
SPECIAL BRIGHTNESS 3 ° <300 CANDELA
I chose the second option, or DRL + Position light.
4° step:
To have this option, we have connected the wire called "D " (blue), which comes from the control unit supplied, with the thread called "F".
5° step:
We have connected the "orange wire" to the positive terminal of the tail lights
With the scheme that I listed above I get the following effect:
When I turn the key LEDs light up in DRL mode even if the system is turned offlights.
When I turn on the lights to position the LED DRL mode decreases the brightnessand turn lights.
When I turn on the fog lights, LEDs do not increase the brightness but remain in position lamps
2° MODE:
We connected the wires is different from the first only for the 4° and 5°step:
We have connected the blue wire / with the positive pole of the tail lights
while the orange wire to the positive pole of fog light.
This last procedure, however, does not allow the LEDs to function.
After having described how to connect the kit made by my electrician, can you tell me if there is any link wrong?
And if there were, can you tell me how to fix the wire connection?
MY ELECTRIC HAS DOUBTS:
Doubts about the connection of two WIRES:
1 wire:
THE LINE BLUE / WHITE CALLED "A" IN THE MANUAL
(My electrician has connected this wire to the positive pole of the fog)
The manual says that you must connect it to the light position, but in doing so, theLED flashes quickly.
2nd wire:
THE ORANGE LINE CALLED "B " IN THE MANUAL
(My electrician has connected this wire to the positive pole of lights)
The manual says that you must connect it to the "signal light" so as to convert light toposition light drl When signal light is on.
My electrician does not interpret what the user means by the term "signal light".
Please help me!
Uploaded with ImageShack.us
Old Apr 24, 2011 | 04:58 PM
  #85
calobrecity's Avatar
S204 220 CDI
Hello everyone.
Does anyone know where you can buy the cover for the LEDs?
Grettings
