Fuses Location and diagram?????
C350 2008
Yesterday, when I tried to replaced the front signal lights with LED's, a fuse was blow out (I assume because not power), for my surpraise not fuse legend is available, how it is possible? In a MB, The owner manual show only the block fuses location, not each individual fuse. HELP !!!!
2011 E350 4 Matic
2012 C300 4Matic
the fuse maps should be located within the fuse compartments, stuck to the
lid(s): fuse compartment on left end of dash (must have door open to access),
engine compartment (driver's side I believe), and very possible in the trunk
as well (less sure, depending on model)
C350 2008
The problem is not fuse map in the fuse compartments, either engine or trunk compartment, can you verify if you have same issue, my car is C350 2008.
The problem is only in my car? or maybe is all the 2008 has same problem, because I saw another W204 with missing fuse map.
2012 C300 4Matic
the owner's manual identifies that the map(s) is located in these places.
if your car does not have them, it has been removed by someone, or,
a huge conspiracy by MB to deprive you of this important item.
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
FOOZES
There are two fuse panels. Under the hood at the left rear, a lift off black cover. In the trunk on the right side behind the door.
There is no fuse box at either end of the dash in US models because the items those fuses serve are not US equipment. Whether cars sold in Puerto Rico are configured the same is unknown to me.
The fuse layout is a folded sheet of paper stored with the tools on top of the spare wheel in the trunk, not in either fuse panel location.
According to my fuse sheet, the turn signals are served by fuse 13 which is in the front fuse panel.
'09 C300 Sport 4Matic Arctic White
I had the same problem this weekend when changing out my passenger-side low beam bulb. Thought it was a blown fuse but it was the computer not sending any power to the light. The bulb was fine.
This may sound elementary but after swapping bulbs, try turning the car off completely and take the key out, then turn it back on. Do this each time you plug/unplug a new bulb. Hope this helps!
C350 2008
Lot of bad info posted.
Again this case was only to replace a bulb, but in the future can be more critical thanks again.
I was having the same issues (no fuse layout for any panel and drivers side headlamp that wouldnt light even after replacing). I tried what fattysnax posted above and it worked for me. With the car off, turned lights to off position, turned the car on, turned the lights to the ON position and they worked. Tried auto and DRL and they worked too.
"This may sound elementary but after swapping bulbs, try turning the car off completely and take the key out, then turn it back on. Do this each time you plug/unplug a new bulb. Hope this helps!"
