"pssh" or whoosing from dashboard??
Old Dec 12, 2009 | 04:45 AM
akbro93704's Avatar
2014 C250 sport
My car has recently developed an odd noise..some sort of whooshing, or "psssh" air-like sound. Its not overly loud but its noticeable with the radio off. It seems as if its coming from the drivers side of the dash or engine compartment.
weird part is...it ONLY happens when my foot is off the brake pedal...the more pressure I apply to the brake pedal, the more the sound disappears. It will do it in park, drive, reverse, doesn't matter.
Any ideas??
Old Dec 12, 2009 | 04:59 AM
08w204's Avatar
2008 MB C300 Sport (Mars Red)
I've noticed the same thing.... Not quite sure what to make of it.
Old Dec 12, 2009 | 03:21 PM
charliele729's Avatar
09' E350 AMG Sport, 09' C300, 03' Honda S2K
Isnt that normal when pumping on the brake pedals, does it also do it while your driving? or only at certain times.
Old Dec 12, 2009 | 03:31 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Your C is jut opening a can of Bud. !!
Old Dec 12, 2009 | 03:35 PM
Savage c-300's Avatar
C300 Sport, MM, P1
its your twin turbo spooling up =)
maybe one of the fluid lines got clogged up. happened to me to and they had to change it out. WARRANTY!
Old Dec 12, 2009 | 07:00 PM
albert101's Avatar
W204 C280
I have the same problem on my S class. Took it to a shop. They said it was the pedal that was causing it. The shop said they lubricated the pedal (honestly not quite sure what they mean by that) and the sound went away... but only for about a month. The sound came back after. Still have yet to find the cause of the sound and eliminate it totally.
Old Dec 12, 2009 | 11:45 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Sssss
Any ideas??
Probably related to the power brake diaphragm and sounds like a vacuum leak. With the engine running, raise the hood and listen for the sound from the round black unit (against the firewall) which is next to the fuse box and behind the brake fluid reservoir.
Old Mar 11, 2014 | 06:39 PM
Eickecc's Avatar
C350/'08 w204
Hilarious.
Old Mar 12, 2014 | 02:13 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
Brake Vacuum leak. This is a common problem. Try going into a underground parking or anywhere without too much outside noise and while the car is running and in neutral press the break and it will disappear then when you release the brake it will slowly start to make that sound. If under warranty get it fixed as it is covered. I do not think there is a patch-up job which is stupid as the seal is the only problem and you can't replace just that seal as you need to replace the entire assembly.
