How do I get songs to show up on Navi from iPod?
2009 Merc Benz c350 palladium silver
I get a blank screen. I can only see the songs where you see the gas gauge and mileage etc.
1 Post
'08 C350, '05 Mazda 3 HB, '07 330i
If you have the Command System and the Ipod integration kit it should be displayed in the HU and the dashboard.. I think if you have the non-MM .. it will only display in the dashboard display...
Nothing to do with 08 or 09.
If you have ipod integration system will show on your cluster only.
If you dont have it but have the jack input on the glove box will not show any were except on the ipod it self.
If you have factory installed media interface will show on the command.
Not sure if media interface is availleble without command.
I'm not sure if I have the iPod integration, but I do have the iPod cord in the glove department.
My 09 w/o MM or COMAND shows the songs in both places.
Actually, I don't know if I have MM or COMAND or not, but I don't have the pop-up screen. That's for sure.
The iPod integration kit in MY 09 and 08 cars with Audio 50/COMAND is operated solely via the instrument cluster. In MY 10, however, cars can be equipped with the optional UCI (universal connection interface) in lieu of the old iPod integration kit. iPods connected via UCI can be controlled via the HU.
iPod integration on cars with Audio 20 and UMI/Nav +4 regardless of model year can be operated via the HU.
This is wrong.
I`ve got an 09.
Sorry, I should have been more clear. I was only addressing the 08 and 09 part of your post. COMAND in 08 and 09 was not available with UCI and as a result, the iPod control was only available via the cluster.
You are correct about the media interface being able to control the iPod. Technically, however, it's not necessarily a factory installed option. It's readily available as a retrofit for Audio 20 systems.
Edit: I see you're in Canada. In the US, UCI was only available starting in 2010. Apparently Canadian vehicles have been shipping with this for a while. That explains the confusion.
media interface (only factory installed).
uci (dealer installed on audio 20) i`ve done 4 of them on glk`s with audio 20
1 Post
I have this very same setup guys!..
...although they did some updates that were in order with my integration kit the last time i brought it to the dealer.. they charged me like 200$ for that.. i even think they changed the cable and took off the old one.. i honestly don't know!.. but i wil check the worklist if i can see anything that abunds or explains the work they did
2009 C300 SPORT
