External change AMG (with DRL)
Modifications made: AMG front bumper, rear bumper diffuser AMG more than double output, side sills, wheels 17 "multirradio, new DRL.
Before the change
[RIMG] http://i46.tinypic.com/2q0u92p.jpg [/ RIMG]
After
[RIMG] http://i45.tinypic.com/2vrssif.jpg [/ RIMG]
[RIMG] http://i50.tinypic.com/v7w8sy.jpg [/ RIMG]
[RIMG] http://i50.tinypic.com/bezm2r.jpg [/ RIMG]
[RIMG] http://i49.tinypic.com/fn9tvp.jpg [/ RIMG]
[RIMG] http://i47.tinypic.com/2mws8wk.jpg [/ RIMG]
I have problems with the LEDs, if I could turn back I would not buy them. The original parts which sells Mercedes (internal media) doesn't fit well, but the real problem is when the LEDs are connected. Now I've connected them by a cable directly to the focus position, and when I turn on my car THEY BEGIN TO BLINK AND TO LOWER THEIR INTENSITY! What can be the cause??? How would you make the installation of the LEDs? I need urgent help!
Thank you.</SPAN></SPAN>
Before the change
After
I do like the looks, where did you buy them? Part numbers and price please.
The pieces are original Mercedes Benz. Cost: 450 euros (15 dto)
Necessary components for the modification:
(Support of property) of the Internal Support
A2048852814
A2048852914
(Grille) Grid
A2048850053
A2048850753
(Outer seat) External adjustment
A2048852774
A2048852874
(Lamp unit) Lamp unit
A2218201756
A2218201856
IMPORTANT THESE REFERENCES ARE VALID ONLY FOR THE AMG SPORTS PACKAGE
Before the change
After
I saw a new Audi today with the LED lights and they were off and the headlights were on. And in the daytime the Audi LEDs I have seen are very bright, too bright for night use.
And by installing LEDs, your fog lights are gone, then?
1) the problem with this car is that it does not have intelligent lighting with bixenons, just simple xenons so he should upgrade to bixenons before upgrading to DRL LEDs.
2) Foglights have different current than drl leds, so this causes the car to recognise an error to the DRLs, this is why they blink, or they dim.
3) you need new lighting facelifted switch which has extra section for drls
4) you need new wiring harness installed from lighting switch all the way to the fusebox and all the way up to the headlights and folights
Alternative just buy amg foglights and all problems sorted. No other way possible. Dont ruin your mercedes by chopping cables.
I hope this helps.
In your case you still need
lighting facelifted switch + lighting facelifted wiring harness plus some coding to enable DRL LEDS. Plus of course the parts mentioned above:
A2048852814
A2048852914
(Grille) Grid
A2048850053
A2048850753
A2048852774
A2048852874
A2218201756
A2218201856
A 2048852814 €16.01 EX
A 2048852914 €16.01
A 2048850053 €17.16
A 2048850753 €17.16
A 2048852774 €32.03
A 2048852874 €32.03
A 2218201756 €147.26
A 2218201856 €147.26
Before the change
After
