new rims...
Old Jan 9, 2010 | 02:27 AM
Red_Demon08's Avatar
08 C350, mars Red, Pano, PII, M.Media, Ipod. 18" AMG rims
Exclamation new rims...
i just got these rims but im having a hard time trying to decide wat tire size will go well on my car....i have 19"in 8.5 in the front and 9.5 for the rear......my question is wat is the best tire size?
Old Jan 9, 2010 | 02:46 AM
SGTzAMG's Avatar
Veteran: Army
02 C32 AMG, 05 SL55 AMG, 09 SL63 AMG, 14 E350, '18 G550, 92 300ZX & 15' GL63 AMG
woo hoo! Euro63RS! one of my fav wheels! congrats! go Falken!
Old Jan 9, 2010 | 04:57 AM
but size thooo ?? for the front got this 235/35-19 and for the rear 255/30-19 but i dont really wanna bad ride i still want a kinda stock ride....but i need help
Old Jan 9, 2010 | 05:27 AM
Nik_Ind's Avatar
2018 S350 D, 2011 E350 Coupe, 2017 G63 AMG, 2017 Ford Mustang
The size of rims that you've gone with can never give you a ride comparable to stock! You need to compromise on that as the sidewall size of the tire has been cut down to 30 as compared to the stock sidewall size of 45/50 depending upon the size of your stock rims. I hope this helps
Old Jan 9, 2010 | 05:34 AM
Nik_Ind's Avatar
The cushioning effect of the tires decrease with decrease in sidewall size!
Old Jan 9, 2010 | 10:07 AM
i was wonderin if i could but on 235 / 40 19 in the front and 255/35 19 in the rear without rubbing
Old Jan 9, 2010 | 10:22 AM
jtpmedic's Avatar
2010 C-300 Sport
Good luck with that...
Just to compare, I'm using the OEM size off mine:
225 45 17 = 24.97"
235 40 19 = 26.40"
increase: 1.47" height
increase: 10mm width
decrease: profile
245 40 17 = 24.72"
255 35 19 = 26.03"
increase: 1.31" height
decrease: profile
JP
Old Jan 9, 2010 | 10:43 AM
sy1616's Avatar
2005 E55
255 on a 9.5" rims sounds too narrow. 275 in rear no???
Old Jan 9, 2010 | 11:32 AM
andrusha's Avatar
C250 12 / CLK63 BS / ML63 09 / GTR 2012
lets see some pics when you put them on
Old Jan 9, 2010 | 12:12 PM
Nik_Ind's Avatar
For the rears you might need to go a little further like 265/35 as the the rim width you will be using is 9.5". Personally, i would go in for an 18" diameter because driving with 19" on Indian roads is a torture. Having said that, i would like to tell that my tire configuration is going to be the same as 235/40/R18x8 for the front and 265/35/R18x9 for the rear. You might also want to try 275/35 for the rear but i think that would rub the inside of the fender. For such wide tread widths you either need to increase the arc width of the fender or add spacers! The latter is NOT RECOMMENDED!
Old Jan 9, 2010 | 04:37 PM
Richard2011's Avatar
2015 BMW M235i 6MT
Those are the rims I want. How much did you pay for them?
Old Jan 9, 2010 | 05:45 PM
ChrisBrown's Avatar
2005 C240 4MATIC, 2020 GLC300 4MATIC
Like em!
Old Jan 9, 2010 | 06:38 PM
jmsspratlin's Avatar
Very FAST!
Still have those 18" AMG's? If so are you thinking about selling?
Old Jan 9, 2010 | 08:52 PM
Boggi's Avatar
08 c300
Will they fit
Heres my question i own 08 c300 i got 17s but i found 07 broad 5 spoke s550 rims and want to slap them on. My question will i have to modify qnything or shave any bolts. Thank you in advance.
Old Jan 9, 2010 | 10:50 PM
Royce118's Avatar
15 E200CGI SPORT
If you're talking about the OEM s550 rims I doubt that would fit.
Old Jan 9, 2010 | 11:32 PM
Boggi's Avatar
08 c300
Yea oem 18 inch they call them broad five star
Old Jan 10, 2010 | 12:49 AM
imboom's Avatar
It really depends on the tire you picked and how low are you going later on if you are going to drop it.
I have the wheels in 235/35/19 for fronts and 265/30/19 in the back. The tires are Vredestein Ultrac Sessantas and it will cut very close to rubbing in the rears if I installed SuperSports. Not entirely sure about the other springs that are not as aggressive. I've seen a few others running 255/35's in the rear and it might help even if it is a bit taller because they will be stretched.
Old Jan 11, 2010 | 12:05 AM
Spec_Davis's Avatar
W204 Color: 090 / 1999 Honda Civic EX / 2003 Acura TL
i have 235/30/r19 and 255/30/r19 with no rub but with full load i rub
Old Jan 11, 2010 | 01:56 AM
NJBNZ's Avatar
'09 C300 4Matic Sport
Are you selling the 18" AMG rims you had on originally? Let me know...I'm in NJ
Old Jan 11, 2010 | 02:33 AM
Rick Hunter's Avatar
'08 W204.081; M 272.948 KE30; Colour Code#792
Wow... sick wheels!
Now read the Tyre & Wheel Bible: http://www.carbibles.com/tyre_bible.html
It'll help you with your decision on tires.
Old Jan 11, 2010 | 06:02 PM
alexlev's Avatar
C204
Originally Posted by Rick Hunter
Wow... sick wheels!
Interesting article.
Old Jan 12, 2010 | 02:03 AM
got_thang?'s Avatar
2008 C350
Boring!
