Bent rims?
Old Jan 12, 2010 | 11:19 AM
Royce118's Avatar
15 E200CGI SPORT
Bent rims?
Is there anyway to tell if the wheels are bent? It was raining heavily just now and I happen to drive over a pothole. I don't seem to notice any difference in ride quality after i hit the pothole though. Any help is appreciated. Thanks.
Old Jan 12, 2010 | 02:26 PM
Sportstick's Avatar
Another round of ICE
The easy first steps are to sense any vibration at different speeds and monitor tire pressure. If those are all nominal, then you're probably fine. However, you should unbolt the wheel and closely closely inspect the tire sidewall, facing out and facing under the car, for signs of damage which could lead to a sudden decompression.
Old Jan 12, 2010 | 08:21 PM
Royce118's Avatar
15 E200CGI SPORT
I've tried driving at higher speed but there is no vibration at all. Tire pressure also seems to be normal. I will try unbolting the wheels later on today. Thanks for helping out.
Old Jan 12, 2010 | 10:51 PM
Sportstick's Avatar
Sounds promising, but it's not just higher speeds...carefully go up and down the speed range. You don't know at what speed a vibration might appear, depending on the type of damage, if any.
Old Jan 12, 2010 | 11:06 PM
Royce118's Avatar
15 E200CGI SPORT
I'll try driving at lower speeds again. Its raining again. Sigh raining season now. Was planning to wash my car later on in the afternoon.
Old Jan 13, 2010 | 12:33 AM
alexlev's Avatar
C204
What are you complaining about? . . You just got a wash for free
I think I've been hearing my girlfriends excuse of not washing her car for too long now.
Old Jan 13, 2010 | 12:58 AM
Royce118's Avatar
15 E200CGI SPORT
Haha! It's more of like my habit. Usually get my car washed every week but it has been 2 weeks ever since the last wash and the car is looking awfully dirty.
Old Jan 13, 2010 | 02:30 AM
JimPap's Avatar
2008 C300 Sport, RWD, US
Kind of hard to get fired up to hand wash your car when its below freezing outside.
Old Jan 13, 2010 | 03:22 AM
Teck's Avatar
C 320 CDI 4M W204 / C43 AMG (W202) / C 220 CDI T (S203) / ZX-10R Ninja
Same here. It's snowing since two weeks so no chance to get a proper car wash. So my car was palladiumsilver...right now I got dirtsilver mixed with palladium
Old Jan 13, 2010 | 05:02 AM
Royce118's Avatar
15 E200CGI SPORT
It doesn't snow here in Brunei. Its a tropical country so pretty much hot and wet all the time. Teck not only dirtsilver but the brake dust on the wheels as well..
Old Jan 13, 2010 | 12:09 PM
Teck's Avatar
nah I call that gunmetal
Old Jan 13, 2010 | 07:40 PM
Royce118's Avatar
15 E200CGI SPORT
+100 LMAO!
Old Jan 14, 2010 | 06:00 PM
kevink2's Avatar
2004 Mazda6, 1993 RX7
I agree with visual check for tire or rim damage. I'd also jack up that corner, and use a dial indicator or just stationary reference ( 1/4" rod clamped to jack stand to make an air gap to wheel ID ) , and slowly rotate to check for run-out.
When I brought rims to local repair shop, 1st thing they do is spin them in a balance machine, and look for any run-out/wobble. Any trusted shop could do the same. Helps if you take it off car and bring it in. That way you know it goes back on with proper hand torque of 96 ft-lbs.
Old Jan 14, 2010 | 07:59 PM
Royce118's Avatar
15 E200CGI SPORT
Thanks for the detailed info. I will bring my car into the dealer for the tyre check-up program they have here. Hopefully nothing is wrong with the wheels. Car is only having 5000km mileage =x
