DIY for removing all wood trim pieces?
Old Feb 22, 2010 | 07:45 PM
NJBNZ's Avatar
'09 C300 4Matic Sport
I'm gonna have a friend of mine wrap all my wood dash trim pieces with the CF vinyl...does anyone know if there is a DIY for how to remove all the trim pieces? I think a few people on here have wrapped/swapped their trim pieces.
Thanks in advance for the help!
-Pat
Old Feb 22, 2010 | 07:58 PM
ldtCapitan's Avatar
C300 Luxury
There's a guide for the door trim somewhere, but I'm curious to see how the console pieces are removed
Old Feb 22, 2010 | 08:34 PM
Will38's Avatar
2008 C300
hmm i should have taken picture when i did it. It's not as hard as you think, but I think putting on the CB was a pain..
Old Feb 22, 2010 | 09:37 PM
NJBNZ's Avatar
Yea I remember seeing instructions for the door trim. If I remember correctly there are screws and clips that hold the door panel on. Once you get the door panel off there are clips that hold the door trim on.
But I have no idea how to get the center console pieces off...that's what I really need help with.
Anybody?
Old Feb 23, 2010 | 04:30 AM
Will38's Avatar
2008 C300
first u take off the ash tray, remove the panel covering the ash tray, pop out the center console from the bottom right or left with a flat while pushing the back. That how I did it. well just to make sure you talking about this piece right? the one where you can move the a/c etc?
Old Feb 23, 2010 | 03:04 PM
NJBNZ's Avatar
Actually I need to remove the AC trim, ash tray cover and the trim around the shifter.
How do you get the ash tray door off? Once that is off do the other 2 pieces just pop off by using a screwdriver?
Old Feb 24, 2010 | 07:13 PM
HakkinenL's Avatar
2009 C200K
If i have not forgotten, first push open the ash tray cover as you do normally. Then press it down hard and push it towards you, the cover should come off. After that just pull out the A/C cover from the bottom first.
Hope this helps.
Old Feb 24, 2010 | 09:40 PM
NJBNZ's Avatar
Hope this helps.
Great thanks alot man.
Any idea how to take the trim around the shifter off?
Old Feb 24, 2010 | 10:46 PM
Boris0126's Avatar
2009 C-300 Sport
Can you put some pics after you get your car done?
Old Feb 25, 2010 | 02:47 AM
HakkinenL's Avatar
2009 C200K
You have to open/remove the ashtray cover first. Then the shifter trim can easily come off if you lift it up starting at the the edges near the ashtray.
BTW, here is my post about changing the interior trim. But not quite detailed on the astray & shifter part.
https://mbworld.org/forums/c-class-w...lots-pics.html
Old Feb 25, 2010 | 07:56 AM
NJBNZ's Avatar
Awesome...that's perfect...thanks again!
Boris I'll definitely post pics when it's all done
Old Feb 25, 2010 | 12:35 PM
HakkinenL's Avatar
2009 C200K
Good Luck.
Looking forward to see pics !
Old Mar 9, 2010 | 05:28 PM
NJBNZ's Avatar
Ok so I was able to get the trim pieces off the center console...but cant get the door panels off to unscrew the door trim. I unscrewed the 2 torx screws but I'm guessing there are clips also holding the panel on. I tried just pulling on them but they won't budge. Do you remember what else is involved besides taking off the 2 torx screws?
Old Mar 10, 2010 | 02:40 AM
tls1212's Avatar
A45 AMG Edition 1
there is a clip on the side window cover,i just did mine with CF vinyl attached with the pic alo will take the door trim pic
Old Mar 10, 2010 | 08:21 AM
NJBNZ's Avatar
Yea that's what I figured. So how do you undo the clips?
Where are you located?
Old Mar 10, 2010 | 09:25 PM
tls1212's Avatar
A45 AMG Edition 1
you can use flat screw driver to undo the clips ,i m from Malaysia also attached picture for my door panel picture after done cf vinyl
Old Mar 14, 2010 | 06:20 PM
Boris0126's Avatar
2009 C-300 Sport
Hey NJBNZ did you finish putting all the CF stuff?....Tls1212 the pictures of ur car with the CF looks great congrats!
Old Mar 14, 2010 | 11:09 PM
NJBNZ's Avatar
No not yet. Tried to get all the trim off but couldn't figure out how to take the door panels off to remove the wood trim on the doors. Been raining all weekend here so I'm gonna give it another try when it stops later this week
Old Mar 15, 2010 | 08:27 AM
racetested's Avatar
08 MB
There was a great write-up and plenty of pictures in the C63 forum a few months ago about removing all the trim.
Would have been great if the post was made a sticky as I can't find it anymore. You may have better luck searching.
Old Mar 15, 2010 | 11:12 PM
NJBNZ's Avatar
Thanks for the heads up! I'll definitely try looking it up there
Old Mar 16, 2010 | 06:17 PM
NJBNZ's Avatar
Just an FYI. I made a post on the C63 board and someone was able to find the link for the very detailed DIY for removing all the interior trim. I added it to the sticky DIY thread but here's the link...
https://mbworld.org/forums/c63-amg-w...ment-long.html
Old Mar 23, 2013 | 03:30 AM
J__'s Avatar
J__
2012 C200 CGI
anyone know how to remove the wood piece on the dash in a '12 facelift c-class?
