help needed on playing music with pcmcia card
Old Mar 19, 2010 | 11:01 PM
mbx84's Avatar
C300
I bought a PCMCIA card and a 2X speed SDHC card,everything is fine except when I play the music MP3 files,it skips once a while,I don't know what is the problem,every MP3 file has same problem,and it is random.skip like 0.1 second once a while.do I need a extrem speed SDHC card?help please,thanks in advance
Old Mar 20, 2010 | 01:48 PM
eminnet's Avatar
Audi A4 1.9 TDI 2002, MB C200 CDI 2004, MB C220 CDI 2009
I use 4GB Extreme IV and 8GB Ultra II Sandisk Compact Flash cards with Sandisk PCMCIA adapter and never had such issue.
Old Mar 20, 2010 | 02:16 PM
killacam7479's Avatar
2009 C300 Sport 4Matic, 1999 Jeep Grand Cherokee Laredo
I bought a no-name 16GB SDHC from eBay (Hong Kong), and no issues with skipping. Do you have another card you can try? Maybe you can isolate the issue.
Old Mar 20, 2010 | 02:48 PM
mbx84's Avatar
C300
thanks a lot,maybe I will try high speed SDHC,see what happens
Old Mar 20, 2010 | 09:12 PM
Robbio204's Avatar
C350
Yeah, I havent had a problem like that before. I would isolate what's wrong first like killacam said.
Old Mar 21, 2010 | 09:35 AM
Savage c-300's Avatar
C300 Sport, MM, P1
I use a SanDisk PCMCIA card and a 4gb kingston card and have never had an issue. try a different SD card.
Old Mar 21, 2010 | 04:01 PM
Diesel Benz's Avatar
High speed is need for digital SLR cameras an like, it also helps in the car when the card is first inserted but any slow memory card should be fast enough for MP3 playing. It could be your PCMCIA adapter or the memory card.
Old Mar 21, 2010 | 04:34 PM
mbx84's Avatar
C300
what SDHC card you use?should I change it flush compact card?
Old Mar 21, 2010 | 06:43 PM
BAPHA's Avatar
W204 2008 C350
I just received the Transcend CF 8gb Ultra Speed 133x card with the Transcend CF Adapter, no problems at all. Loading of music from the CF card takes no longer than a DVD. I am very happy with this method, pretty easy to replace songs on a whim without wasting/storing/maintaining of disks.
Old Mar 22, 2010 | 02:00 AM
I have tried SD HC cards without problems but I prefer to use Compact Flash cards because I have those for the digital SLR and the card connectors are more reliable in a car environment.
Old Mar 22, 2010 | 02:02 AM
Are you doing apples to apples comparison with the DVD and the memory card in the sense that you have the same number of titles on both? 133x is not the fastest possible memory card but should be way faster than reading a DVD.
Old Mar 22, 2010 | 07:26 PM
BAPHA's Avatar
W204 2008 C350
Diesel Benz, I guess I can measure this a little more accurately since I only have about 2GB on the CF card, currently. I might have misread but for some reason I was left with the impression that reading through PCMCIA with comparable volume was a bit slower compared to DVD...
Old Jan 28, 2011 | 03:36 PM
Bouken's Avatar
C200
Hi
I am tired to read all the posts. I bought an Sandisk PCMCIa adapter for Comand APS:
http://www.amazon.de/PCMCIA-Adapter-.../dp/B003IIWT46
+ 8 GB Ultra CompactFlash card.
I put mp3 files on in, and guess what see on the display?. no readable audio file.
Does anyone know what I can do to fix it?
Thanks !
Old Mar 11, 2011 | 01:06 AM
bludog's Avatar
2012 E350 4MATIC / 2017 GLS 450
Mine
I'm using a SanDisk 6 in 1 PC Card adapter ($35 on Amazon) with 4gig Kingston SDHC card. No problems with skipping or anything else.
Old Mar 19, 2012 | 11:33 AM
shaffrao's Avatar
c 220 se cdi
Hi Guys,
I bought PCMCIA 18 in 1 memory card adapter and puted in 32GB SD card.try to play the music MP3 or video AVI.Every time a message come "No Playable Files".How can i sort out this prob.My PCMCIA card can hold 32GB card.Please help me.The car is C220 SE cdi 2008 UK.
Many thanks
