Tire size recommendation
Old Mar 28, 2010 | 07:29 PM
Pristine's Avatar
2014 E350 4Matic
I bought a new set of wheels that are 18"/8.5"/45 ET front and back.
I'm planning to put 245/40/18 tires all around. But I've noticed that most people here have 235 in the front. Would there be any rubbing issues or would the tire stick out if I go with 245 in front?
Old Mar 28, 2010 | 08:34 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
Yeah - 245 = fender rub...
I run 235's and have random rub on deep dips
Old Mar 28, 2010 | 08:48 PM
Pristine's Avatar
2014 E350 4Matic
OK, thanks for letting me know.
I'll stick with 235 front and back then.
Old Mar 29, 2010 | 08:09 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
why dont you run a 255 rear? that's what i've got - tracks a bit better now
Old Mar 29, 2010 | 08:47 PM
kevink2's Avatar
2004 Mazda6, 1993 RX7
Using same size, non-directional tires allows cross rotation, for minimal noise and best tread wear.
Old Mar 29, 2010 | 10:11 PM
Pristine's Avatar
2014 E350 4Matic
Yes, that's why I'm going with 235 all around.
Also, since both front and rears are 8.5, the shape of tires might look funny if i use wider tires in back and narrower in front.
I hope 235 don't cause any rubbing issues on the fronts though.
Old Mar 30, 2010 | 06:09 PM
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
I've only had my 235 fronts rub when I back out of the driveway and have the wheels cranked close to all the way. It's a minor rub that has never left anything visible on the tires or the fender lip.
Old Mar 31, 2010 | 05:45 AM
Pristine's Avatar
2014 E350 4Matic
That's good to know. It might be an issue with me because I have to back out of my driveway with wheels turned all the way since I have a narrow street.
I may have a bigger problem since I have 8.5" wheels in front compared to 8" that you have. I think I should consider 225 front and 235 back then. Would 225 be OK for 8.5" wheel?
Old Apr 29, 2010 | 05:34 AM
Pristine's Avatar
2014 E350 4Matic
After talking to TireRack they recommend going with 225/40 all around to be on the safe side and avoid any rubbing especially in front since it is a 8.5" wheel. I'd would prefer to get 235 for looks, but I'd rather avoid any issues with rubbing.
I hope that doesn't look too weak in the back because i currently have 245 in the back.
Let me know if anyone has suggestions.
