Radio Doesnt Save the Previous Volume
the situation:
So sometimes, I dont bother turning off the COMAND before turning off the engine so I usually just turn down the radio volume and then pull out the key. The next time I start the car, the COMAND automatically starts up, but the volume is much louder than what I left it at.
It seems like there is a preset for this volume and it is actually quite loud. Anybody else have a problem with this?
the situation:
besides that I don't think it has a preset for the volume
the situation:
I could understand if the radio automatically tunes volume down if an extremely high setting was used when the car was previously used but this does not seem to be the issue here.
germany failed this design challenge for sure
it's always nice when your fiancee's parents get in the car to be unintentionally blasted with rap music upon start-up...
the situation:
I had a look at service bulletins and found nothing that could be related.
Do we now have three different cars, the normal one I would say that remembers the set audio level and then those that reset either to a comfortable audio volume or those that reset to an uncomfortably high level?
You actually mention an interesting detail. I thought everyone referred to the car being switched on and off (or off and on) but perhaps someone actually talked about switching the audio system off and on. Myself I thought this should not make any difference.
either way, its annoying.
Now that makes me want to try different things until then. I was actually thinking that maybe the issue had to do with certain source that we're playing from, e.g. audio CD, USB, radio, etc...But what's next?
On the Passat I was able to set the default volume. I was also able to set whether the radio should start at default volume or last setting. In addition , it would optionally adjust for road noise. It also had 2 sets of presets so that each driver could have their own set.
Mercedes is just poorly designed, it is that simple.
