About Faulty message 'check tail n brake lamp'
1 Post
C300 Sport LOADED
I don't know why but my car throws me faulty error sign.
It says 'check left tail and brake lamp' even thogh there is nothing wrong with left lamp.
How do I get rid of that message? I get it everytime I turn on the ignition.
Is this fuse issue?
I have no idea, do you have any idea?
Is this fuse issue?
2012 C63 AMG
Did you change any bulbs in the back? Something has to be burnt out, the error sign only comes up when it doesn't register any resistance from a bulb.
C300 Sport 6-spd
I also get that message periodically, and there is nothing wrong with any of my rear bulbs. To get rid of the message, simply press the "OK" button on the steering wheel.
I used to get that message, if you have p2 with the LED tail lights you actually have an LED burnt out, just take it to the dealer and have them replace the bulb and you are good to go. I never got the message again.
check the plug thats connected to both your tail lights.
I`ve seen a few that got melted.
Is this fuse issue?
Is this fuse issue?
2008 ML350 4matic
Sounds goofy, but check the left side bulb that has the "rear fog light" element in it. Could be just that bulb and you cant see it due to not illuminating that one specifically when you check them out...
C300 Sport 6-spd
I recently started getting the "check tail and brake lamp" message on a regular basis.......almost daily. So, I removed the housing that holds the bulbs and noticed that the tail/brake lamps were flickering when the engine was running.
I took the car to the dealership, and they mentioned that it is a known problem that the wiring harness is faulty in some vehicles. I now have an appointment to bring in the car to get the rear wiring harness replaced. The job should should take about 1/2 day.
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Bulb out functions
Is goofy. The left upper taillight filament and fog filament are one and the same. The taillight operates at a reduced voltage except when the rear fog is selected and then is at battery voltage, thus fully bright.
LEDs if out...
LED's are not replaceable one by one so the entire lamp assembly must be replaced.
Is this fuse issue?
Is this fuse issue?
Check the right tail lamps. When I got that message (both side in a month) it was the opposite lamp that was out. Guess it depends upon how you view "left and right"
C300 Sport 6-spd
There is no rear fog light on the right side of the car. (the warning message reads "check right tail and brake lamp").
The dealership has the problem under control and it will be fixed soon.
Anyway, thanks for your input.
C300 Sport 6-spd
Just an update..... The tail lights warning message has now been resolved.
The dealer replaced the wiring harness for the rear tail lamps, and the L/S tail lamp bulb holder.
MB w204 C300 Sport, Audi B7 A4 2.0TQ, Porsche Cayman 981
I know this is an older thread, but I just wanted to share that I had the same exact problem on my right rear tail light harness.
I get a warning that my right rear tail light bulb is out - but it really isn't.
When I went to inspect the bulbs, I noticed the electrical harness was melted into the light bulb panel.
Spoke to my SA and he said that he's seen quite a few 2008s with P2 that exhibited this problem.
They replaced everything under warranty...but I wonder if the problem will creep up again over time. Seems like a poorly designed harness or poorly designed LED control board.
It happened to me about two weeks ago. The SA said he was replacing bulbs and it would take a few minutes. When I came back- three employees were standing at my trunk. They "fixed it", but I don't think they replaced a harness. Since I'm getting close to warranty end, maybe I should take it back.
Damn. I'm out of warranty and just got this message too. All my lights are lit as well. Wonder what this will set me back
My lights were lit as well. I just got mine fixed they told me it was the circuit board. I'm not aware of the price bcuz luckily I'm still under warranty until november
2015 Mase Ghibli SQ4. 2013 Range Rover Supercharged
i got the same message b4. i checked n NOTHING wrong w the lamps. few days later, I checked again n the break lamp on the RIGHT side was dead.... but error say "on LEFT"???
2006 C230 6spd > C300 4Matic
I just had this happen to me, according to my mechanic. The car alerts you before the bulb actually goes out. The lights worked fine but when we pulled them out the bottoms looked burnt out. It's just an alert to let you know to change em, they don't necessarily have to be out.
Predictive warning lights that sense when failure will occur soon?
That guy has a case of "gonnahidemylackofknowlegewithbull****-itis". Although.....if its true.....MB just got a big leg up in the hotly contested tail light bulb sales race and all that costly R&D is about to pay off.
Same damn problem here.
'11 C350 '13 F150 lariat
as posted its not pre-emptive, its actually the cars system sensing resistance in the circuit that is not within the programmed range. I too had the problem on my 08 and it was the actual wiring harness at the bulb socket that was starting to melt. Its a know problem at every dealership. If your getting the message u can best beleive that one of your bulbs or harnesses or sockets is burnt, melted, or starting to go out
