Nav Help/Question
Lets say i have an 08 c300 without nav, and want to add it in after purchasing the car. has anyone done this? or gotten a quote from the dealer? or can we buy the parts from the dealer and install them ourselves?
let me know, thanks.
Garmin + Arkon mount.
http://www.amazon.com/Arkon-GN047-Re...2469504&sr=1-1
Fits the right A/C vent of the center stack perfectly, when you need it. Makes the whole thing a couple of hundred dollars for a great Garmin Nuvi vs. some price, over a thousand...I don't remember exactly, to retrofit an MB nav system that isn't that great anyway.
Found the link you want....apparently $2000 for parts if you follow his DIY instructions.
https://mbworld.org/forums/c-class-w...pensation.html
https://mbworld.org/forums/c-class-w...-pictures.html
Nick
I'm not sure I understand........
I've never had that problem with our Garmin Nuvi, in fact, it's somehow able to maintain our correct position even going through a tunnel near here, which is about the same length as the Brooklyn Battery Tunnel in your area. I watch the car icon make progress on the screen and it matches when we exit. But, what camera are you referring to? There is no camera in my nav.
Wow....sorry to hear that....Garmin Nuvi 765T has never had a hiccup and came with maps for US and Europe, so we can take it when we travel and rent a car. Same price. With the Arkon mount on the right A/C vent, it lays right up against the instrument panel and oddly almost seems built-in. I actually planned to do this and rejected the MB built-in nav because I just couldn't see 5 times the value ($500 vs. $2500!). Turns out to have no downside I can find
the thing was like 500 bucks too, complete waste. My g/f hates hers as well.
I do know that the route our E Class will suggest depends on which way it is parked in our garage (or wherever we are starting from). If we parked front in, so that its pointing north, it will give one set of directions to a given destination. When backed in, it gives different directions to the same place. It turns out the algorithm built into their system is averse to u turns and would rather send us on a different route to avoid them, even though we're just parked!!
