Valentine One w. Concealed Display.
I would think there has to be a way to access the rear of the ashtray from either behind the headunit or behind those side panels somehow. Have you tried removing the ashtray and looking at what's behind it?
Regarding the foam, I could probably find a piece of black plastic that you could cut with a dremel and get it shaped perfectly to fit in there and hide the padding while exposed the unit. Sounds like fun!
BTW, sort of off topic but, have you seen Mid City Engineering's V1 module? Almost as slick as the "rear view mirror V1" at a fraction of the cost. Obviously still have to have your V1 showing somewhere so it's not a completely concealed option but it's fully integrated in to the dashboard display and audio system.
Also, does your windshield have the IR filter built into it? Not sure if all MB products do. If it does, is that where the non IR filter "hole" is? Behind the mirror?
Here's a video
