Whats involved in a service a and b
09 C300S 4M
So it doesn't include (for the $495) a brake fluid change, how about an air filter change? I thought B was oil, brake, air filter. If not, then indeed its a total ripoff. All this "inspect" stuff - the tech just glances at each of those I am sure for 30 seconds and checks a box.
2008 C300 Sport 6MT X-Pipe
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
Depending on the mileage and duration, a Service "B" may include a brake fluid change, but this isn't included in the pricing. Typically, it's a oil service, air filters replacement, and inspections for safety, lights, brakes, wipers etc. The check suspension linkages, brakes pads and rotors for thickness and wear, brake and fuel lines for chaffing. In a nut shell, a very expensive oil change. That is why it pays to conduct that stuff yourself. If you don't have the mechanical skills, then an independant MB shop is the way to go. I perform all required maintenance myself. I learn new things each time, and I get the pleasure and sense of accomplishment doing it myself.
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
How much?
For that $200 charge for fluid, do you also get a kiss?
Service "B" is the same as service "A" plus replacement of the cabin air filter. Only real reason to replace the cabin air filter is if you do not get sufficient air flow from the air conditioner or smell odors. It has nothing to do with protecting your vehicle. Brake fluid change is usually a separate cost item. You may want to replace the cabin air filter yourself.
2018 E300 4MATIC Sedan
More details on Service A and Service B :
https://mbworld.org/forums/c-class-w...-180-days.html
https://mbworld.org/forums/c-class-w...know-what.html
Nick
Nick
(Sorry for jacking the thread, if I am. I didnt wanna start another)
I will be getting Service B1 soon (this week), and was wondering if I missed anything: I need them to fix the Bluetooth (much static), the power mirrors (for creeking), and the cabin filter (humid air smells terrible). Ive read about them and saw others posts. Anyone have other problems I may have forgot, bc I dont wanna go back (lol).
Thanks in advance,
Rob
Thanks in advance,
Rob
Costs
At my dealer, before the bottom fell out several years back and cars were selling well, it was costing $1,000,000 per month just to keep the doors open.
That explains the labor rate.
