AZN Optics 5W5 Canbus LEDs
Old Nov 4, 2015 | 09:29 AM
  #951
cfarley27's Avatar
C300
Just bought your 4300 for my parking lights.
I am looking for a list of needed bulbs for interior for 2013 as well as which need to be canbus.
I saw you have no kit on your website, so I am wondering what is needed. Thanks!
Old Nov 4, 2015 | 12:47 PM
  #952
AZN Optics's Avatar
SPONSOR/MBworld Guru
Originally Posted by euroracer31
Late Follow Up. Got the LED bulbs installed. Customer service was top notch. Couple months in with no issues (error free) on side markers, eyelids, & license plate. They were a little tough to insert due to the soldering at the tip ends where the circuits were attached. Had to really squeeze them in with some elbow grease. However, overall great product.
Great to hear.
Yeah, the new design is a tighter fit, but real estate on the small bulb unit is really at a premium with all the components we tried packing into it. On the plus side, with the tighter fit, you won't have to worry about the bulb accidentally falling out.
Old Nov 4, 2015 | 12:48 PM
  #953
AZN Optics's Avatar
Do you have the sedan or coupe?
Old Nov 4, 2015 | 12:50 PM
  #954
cfarley27's Avatar
C300
Sorry I forgot to mention, sedan c300
Old Nov 4, 2015 | 02:01 PM
  #955
stgry1's Avatar
c300 Sport
Euroracer, did you have any issue with the license plate bulbs?? For the life of me, I can not get them to fit. They are approx. 1/16 of an inch to long and won't allow me to lock them in place. I did not want to have them making direct contact with the lens. I actually still have them in the bag...not sure if I will find another home for them or not.
Old Nov 4, 2015 | 02:27 PM
  #956
AZN Optics's Avatar
So here's your interior spec...
Footwell ambient: 1 set 194 wedge LEDs
Vanity mirror: 1 set 194 wedge LEDs
Door puddle: 2 sets 194 wedge LEDs
Front dome: 1 set 194 wedge LEDs
Rear dome: 1 unit 41mm festoon LED
Rear dome map: 1 set 194 wedge LEDs
Glove box: 1 unit 194 wedge LED
Trunk: 1 set 194 wedge LEDs
Let us know if you're interested in the full package or want to a la carte it and we can create a custom discounted package for you.
Really? We've done a few installs on the rear plates and were able to fit the bulb in without issue.
Old Nov 4, 2015 | 05:04 PM
  #957
cfarley27's Avatar
C300
Got the bulbs in but have been having a hard as heck time removing the stock parking light bulbs. Does anyone have any recommendations? I have needle nose pliers but I can barely get a hold of the bulb socket to pull out.
Old Nov 4, 2015 | 06:08 PM
  #958
AZN Optics's Avatar
Try twisting the socket a bit to try to loosen and dirt/debris that might be clogging the assembly. Angled needle nosed pliers are great. No matter what, don't pull by the wires no matter how tempting. You run the risk of stripping the wire if you do so.
Old Nov 11, 2015 | 06:03 PM
  #959
Skyline45's Avatar
2016 GLE450 AMG Coupe
Hey Ya'll, I just wanted to stop in here and give a shout out to AZN_Optics for all they're awesome support and customer service. Had an issue with some lights, and they were right on point with the needed support.
Keep up all the awesome work ya'll are doing! And Thank you again! I couldn't be more greatful
Old Nov 11, 2015 | 08:59 PM
  #960
stgry1's Avatar
c300 Sport
I have extra bulbs for sale if any of you need them. I decided not to do the interior lights after all. Brand new sealed. PM me
Old Nov 12, 2015 | 07:23 AM
  #961
cfarley27's Avatar
C300
Hi Azn,
I decided to keep the 4200k for my interior after driving a 2016 C300 I really like the natural look of that color temp on the interior.
Is there any way you can source a 4200k festoon though? I saw you only had 5000k.
Thanks!
Old Nov 12, 2015 | 11:14 AM
  #962
AZN Optics's Avatar
Hi Azn,
Thanks!
Let me see what I can do.
Old Nov 12, 2015 | 11:24 AM
  #963
AZN Optics's Avatar
Always here to watch out for my MBWorld peeps
Old Nov 16, 2015 | 07:22 AM
  #964
cfarley27's Avatar
C300
Any luck with that festoon
Old Nov 16, 2015 | 11:37 AM
  #965
AZN Optics's Avatar
Trying to source the right 4300K SMD chip that would work with our festoon design.
Old Nov 16, 2015 | 11:39 AM
  #966
cfarley27's Avatar
C300
Old Nov 16, 2015 | 10:23 PM
  #967
Six9mb3's Avatar
C 300
V5 eyelid failure.
All 4 do this? There's no circuitry to cut function based on heat. We have these in our shop 204 and haven't seen this happen. Check your install point. Do you have the clip sitting on the resistor? If so, it's possible the break in burn off solder while the resistor heats up interrupt the feed, which could cause the SAM to shut power. Is there error code thrown during this? You can try shifting your install point by inserting them further in past the base resistors.
Please keep me apprised on this. I'm going to do some testing on this too by shifting install contact point.
Sorry it took me soooo long to reply but as of now all but 1 are working. I removed them and reinstalled. I only notice error codes once every 20 or so starts such as check right parking lamp. Could have been install error but I'm not sure. I was thinking of going with v4.5 but wanted to check back with you first.
Old Nov 16, 2015 | 11:45 PM
  #968
AZN Optics's Avatar
They should either always throw codes or not at all as the LEDs are digital. Your situation sounds like underpowered socket. When you get the codes 1/20 times, is it really cold? Could be failing wire insulation. We could try a replacement unit though if you want to try. Shoot me a PM with mailing address.
Old Nov 17, 2015 | 06:26 PM
  #969
cfarley27's Avatar
C300
Are your interior and exterior LEDs the same? Tried putting in a set into my overhead console but they wouldn't fit.
Old Nov 17, 2015 | 06:35 PM
  #970
cfarley27's Avatar
C300
Just removed the socket, the new v5 do not fit.
Old Nov 17, 2015 | 07:21 PM
  #971
AZN Optics's Avatar
By overhead, you mean the dome light? front or rear? What year is your C class?
Old Nov 17, 2015 | 08:29 PM
  #972
cfarley27's Avatar
C300
Yes the dome light. Front. 2013.
Old Nov 17, 2015 | 08:39 PM
  #973
AZN Optics's Avatar
Hmm, wasn't aware there were any difference between you year and our 08 204 dome, but will investigate. In the mean time, shoot us an email (aznoptics@gmail.com) with your mailing address and we'll swap out the units you have for plasma panels which we know shouldn't have any clearance issues.
Old Nov 18, 2015 | 01:47 PM
  #974
vipsa's Avatar
'09 C350
So these latest 194, are they going to last longer than the earlier versions?
I have about 4 or 5 bulbs from early 2013 that are flickering or completely dead. They're all on the eyebrows/licence plate. Seems like it is heat related as both locations don't have much ventilation. Is it worth it to get the new version?
Old Nov 18, 2015 | 02:08 PM
  #975
AZN Optics's Avatar
Early 2013 should be our V2 model, maybe our V3. These new V5 design are much better. COB based diodes run cooler and are more reliable than previous gen SMDs. We also have built in constant current IC drives which are better at protecting the units from low to mid level surging. There are better surge protecting components out there that can handle higher level surging, but I'm constrained by space on such a small unit, but we believe what's on this chip represents the best available given the restrictions.
That said, we are never one to rest on our laurels and always looking to improve our products. Even though V5 were just recently released, we are experimenting with some new chip components CREE just recently released for a potential V6 model, but that'll be down the line.
