PhotoChopped LED DRL Design, Keep Fog Lights
BMW's signature ''Corona Rings'' are again illuminated to function as the daytime running lights. When equipped with the optional Xenon headlights, the Corona Rings and daytime running lights are illuminated by bright white LEDs.
only issue would be daytime visibility, but at night it would look fantastic if done correctly
Does anyone kknow if the fog light mesh is separate from the center mesh? I believe I saw a picture showing that it was. This should mean a retrofit to the 2011 would be possible. Then you could just use the original fog light power and a possible reprogram?
But, I saw a thread on here where someone replaced their center plastic mesh with a steel or aluminum mesh to make it more rock resistant... they painted it and shaped it perfectly, looked great.
