Rear View Mirror Bulb Changing
Old Oct 10, 2010 | 09:43 PM
smpatel's Avatar
CDI 220 Sport
Has anyone removed and replaced the light bulb in the rear view mirror? (map lights)
I've made an attempt to remove the casing, but it rather tight and have scuff marks on the edges!
Any tips? pic of removing the casing and getting to the bulb?
Old Oct 10, 2010 | 10:00 PM
ZeroSeVen's Avatar
Mercedes Benz C300 Sport
https://mbworld.org/forums/c-class-w...t-removal.html
Old Oct 10, 2010 | 10:10 PM
smpatel's Avatar
CDI 220 Sport
Thanks, however this doesn't show how to remove the bulbs in the rear view mirror.
Its the one that has the night light.
Old Nov 7, 2010 | 08:04 PM
smpatel's Avatar
CDI 220 Sport
Does anyone know how to do this? rather annoying that the map light don't work!
Old Nov 7, 2010 | 09:43 PM
Hzkasbarian's Avatar
2012 Mercedes c250
ive been trying to figure that out for some time now. i was just thinking about ripping that plastic plate off and then super gluing it back on.. i want to put some blue lights on.
Old Nov 8, 2010 | 01:09 AM
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
i was actually wondering about the ambient (orange) light
Im sure if someone cracks the map lights, the ambient light is straight forward.
Old Jun 21, 2011 | 03:22 AM
xpl0d3's Avatar
w204
hi,
I think its a little bit late but however maybe someone else need it to:
1. you have to remove the light cover
2. remove the baffle inside
3. remove the lamp that is trapped i've used a gripper to remove it be carfull don't push the gripper too hard
4.install the baffle
5.install the LED
6. test the function of the map light
7.install the cover
i'm sorry for my bad english
Old Feb 8, 2012 | 02:39 PM
Ultraman's Avatar
2019 E450 Coupe 4Matic; 2018 Audi Q5; 2019 Toyota Corolla Hatchback
Originally Posted by xpl0d3
hi,
5.install the LED
7.install the cover
Can you explain a little more how to remove the light cover? I assume it is the circular plastic len under the rear view mirror. I found there is a slot in there, do you have to turn clockwise or counter-clockwise to remove the plastic len?
Thanks.
Old Feb 8, 2012 | 08:12 PM
st2288's Avatar
85 380sl, 05 slk350, 11 c300 4matic, 04 Highlander
I changed my mood LED.. what a pain in the behind. you need to put the plastic frame around the front mirror housing. Use a flat blade screwdriver.
then you can see the led light assembly. They are all surface mount (SMD) type LED. I pulled out the mood led and replaced with a 3mm amber led (you need to solder back on).. A lot brighter but not overly...
Old Oct 29, 2012 | 09:35 PM
Adrian97c's Avatar
2010 Mercedes-Benz C-300, 2011 Kia Optima 2.0T(GDI)
Exclamation
I just saw a thread for C300 that has a video from precision LED showing how to change interior bulbs, I purchased there kit, but the video doesn't show how to change rearview mirror reading lights, which there kit comes with replacemt bulbs for them...ugh
http://youtu.be/-F4ooqoEyf8
Old Feb 8, 2013 | 01:03 AM
SaphGreyC63's Avatar
2012 C63 AMG Sedan
Does anyone have any updates on this?
Old Apr 16, 2013 | 11:45 AM
vipsa's Avatar
'09 C350
Let's spin this around. Does anyone have the part number for the stock LEDs in the mirror housing? Since they were made for the car, I would think they are much better made than the aftermarket ones available and possibly cheaper too.
Old Dec 15, 2013 | 08:38 AM
lws750818's Avatar
2024 C00 4Matic Sedan
Did you solve it?
I have a same problem with you.
Old Sep 9, 2016 | 11:33 PM
agoswick's Avatar
CLA45 AMG MY 15 (no mas), C63 MY 09, E63 Edition One MY 2018
Rear view mirror bulb replacement
I wanted to replace rear view mirror bulbs with blue LEDs. Took mirror assembly apart, removed circuit board from just above the clear plastic....and wow, led oem lights are built into the circuit boards. No changing of lights...Soooo, I took a blue sharpie and colored the plastic...pow!
Old Sep 9, 2016 | 11:37 PM
agoswick's Avatar
This is when I finally figured how to disassemble. There seems to be nothing on this anywhere. I was trying to remove clear plastic cover like all the rest of the interior lights.
Old Sep 9, 2016 | 11:39 PM
agoswick's Avatar
The piece her is the "circuit board". There are two tabs on the bottom corners that I pulled straight back. It slid fairly easy.
Old Sep 9, 2016 | 11:54 PM
Josh.A.Hussey's Avatar
2017 C43 AMG, 2010 C350 4Matic, 9 Motorcycles
The sharpie mod... Def. gonna be a classic!
Old Sep 9, 2016 | 11:58 PM
agoswick's Avatar
We'll see how it holds up����
