Cna you post some pictures DYI in grille removal?
Old Oct 11, 2010 | 07:33 PM
wanchu83's Avatar
C300 Sport LOADED
I tried to remove the grille. I opened the hood, located the center round notch. I am stuck here. I tired to pull out the notch(after turn 12 and 6o' clock), I couldn't get it out. I broke off little bit of the plastic. I heard someone said we don't have to pull out the notch, and I am interested to know how.
Even after I remove the circle notch, I don't see how I could remove the 4 notch at each corners. Where to stick the flat driver and which way do I pull/push?
I think pictured DYI could help out alot. Can any great person make this in Picture DYI? I want to but I don't know how to remove the grille. I have starless grille sitting on ground, and want to see how it looks.
Old Oct 11, 2010 | 07:55 PM
Blazeitup123's Avatar
W205 c400 sport
just pull the inside of the cover up and out. pops right off.
Old Oct 11, 2010 | 09:31 PM
ShaunPatrick's Avatar
2008 W204 C300 Sport
I had the same issue, after about 30 minutes and some very sore fingers, I took some pliers and broke it off. I hear you don't need to completely remove it, but if you break it, a new one is only $3 at the dealer. There is a PDF grille removal on the forum that shows where the notches are and is pretty helpful.
Old Oct 11, 2010 | 09:55 PM
wanchu83's Avatar
C300 Sport LOADED
Ok, I need to buy new notch becuase I broke some, I will try to pull the top cover up and out of the car. We will see how it goes in 3 hours(when I get home).
Old Oct 11, 2010 | 10:07 PM
This should take you to the thread with the PDF. Good luck, post pics when you're done!
https://mbworld.org/forums/c-class-w...ections-7.html
Old Oct 14, 2010 | 12:10 AM
wanchu83's Avatar
C300 Sport LOADED
i don't know where the clip are and how to take out. here are some pictures please point it out and let me know how to pull out.
dealer doesn't have the instruction for the top part(they had pdf for taking grille out, after the top part is off)
Thank you guys.
Old Oct 15, 2010 | 04:51 PM
wanchu83's Avatar
C300 Sport LOADED
bump. Any one? know where the clip are and how to pull out?
Or do i not need to pull the radiator cover?
please put arrow on picture to explain for me.
Old Oct 15, 2010 | 05:37 PM
ninja4hire's Avatar
2008 c300 Sport
Hope this helps. you can also look at this guide https://mbworld.org/forums/3035282-post153.html
Attached Thumbnails Cna you post some pictures DYI in grille removal?-w204.jpg
Old Oct 15, 2010 | 06:13 PM
wanchu83's Avatar
C300 Sport LOADED
Ok that helped. I did it. my thing was dirty, but it worked. But one thing. the grille I purchased is great fit and great looks, but they have weak I mean REALLY Weak vertical support plastic. They are really thin. I broke one off(didn't break completely, tho). Anyway, I will figure something out to glue it or make support more thicker. I will try to overlay it with CF also. Thank you guys. counldn't have done it with out you.
