W204's and offsets of wheels
Rating: Thread Rating: 14 votes, 4.64 average.
Old Jul 17, 2011 | 12:18 PM
  #226
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
If you end up on coilovers with a +55 offset in a 10" rear w a 275/30/19 you WILL clear. Not sure if you know but most coilovers are adjustable and dont drop super low, I like them personally. You would clear jsut fine w sports as well in that offset, just be careful with tire brands. If your going with a fat running tire maybe 265 is way to go to be safe. Falkens or sumitomos, or nittos will clear, they run skinny. match a 235/35/19 to the 8.5 front and you will barely have any stretch, just a nice tapered sidewall, thats what im running right now same rim size and tires in falken 452s, Im liking these falkens right now for a great midrange tire, excellent wet and dry grip, decent sidewall stiffness. I had lots of rim shops and manufacturers tell me u cant fit this and that and I just test fit for real instead and most times if you know what ur talking about it fits. I have the luxury of my own work shop tho so its a lil easier to take chances on my end
Old Jul 17, 2011 | 12:34 PM
  #227
StormTrooperZo's Avatar
2011 W204 C300 mm pano
general tire just released the as-3 in a 265/30/19 I was thinking about
Old Jul 20, 2011 | 12:28 AM
  #228
itsLoonie's Avatar
2012 E350 RWD
What you guys think? Maxed out on my H&R coilovers.
F: 18x8 +38
R: 18x9 +38
Still deciding on tire size but I'm thinking of something like 215/35 up front and 235/35 or 30 in the rear. Maybe I'll stick to 245 in the rear, but from what I've read here I would clear the fender but might rub on the inner plastic of the wheel well.
Old Jul 20, 2011 | 11:16 AM
  #229
Matt_Eurojerks's Avatar
w204 C300
That rear setup looks suspect with a 245.
Old Jul 20, 2011 | 01:58 PM
  #230
FAneek's Avatar
08 MB C350
will this work?
18x8.5 ET40
18x9.5 ET40
EDIT!!!!
im good to go with this set up
Old Jul 21, 2011 | 04:46 AM
  #231
henrymug's Avatar
W204 350
any idea if the 18inch factory AMG wheel of the C63 will fit the C350
http://image.baidu.com/i?ct=50331648...4025&W800&H600
Old Jul 21, 2011 | 04:59 AM
  #232
JCOnizuka's Avatar
C350 4matic Obsidian Black
Hi guys... I was wondering if members can give me some opinion... would a 19x9 ET38 up front with a 235/35/19 Conti DW work? On the rear, if I was to get a 19x10 with tire size 265/30/19 also conti dw, what offsets should my rear be? I will be putting on H&R sports springs.. Appreciate, your response guys.
Old Jul 21, 2011 | 10:13 AM
  #233
play's Avatar
W204 C200K | W208 CLK230K |
front 19x8 ET 40 225/35-R19
Old Jul 21, 2011 | 10:16 AM
  #234
play's Avatar
19x8+9 ET 40 no rubbing at all
Old Jul 21, 2011 | 09:12 PM
  #235
JCOnizuka's Avatar
New specs
Hi everyone. LOVE this thread about w204 offsets. Keep it coming.
Please ignore my previous post due to wrong specs info. Right now Im pretty sure I have the right one. The specs are:
Front 19x8.5 ET +36 RIMS 7.0" Inner w/1.5" Outer 235/35/19 Conti DW
Rear 19x9.5 ET +38 RIMS 7.0" Inner w/2.5" Outer 265/30/19 Conti DW
I already have a set of H&R Sports Springs (not SS) for 4matic.
My question are, will this setup fit on my car? What do you guys think? Will it rub? Do you think I need to roll my fender? Thank you so much
Old Jul 21, 2011 | 09:21 PM
  #236
Those will definitely rub, they will rub w stock ride height so ur no good especially with sports. Ur prob ok w +38 up front, but not w contis, u gotta go narrow tire 225/35/19 to be safe and out back u need +45 to clear w 255/30/19. thats a guarantee clear w sports, I ran that and just made it, 265 rubbed on mine
Old Jul 21, 2011 | 09:23 PM
  #237
F: 18x8 +38
R: 18x9 +38
ur gonna rub out back loonie for sure if you drop lower than sports ride height, front your OK, out back u need a +40 or higher, w a 9" rear, and go 30 for sure out back, 35 up front
Old Jul 24, 2011 | 08:29 PM
  #238
itsLoonie's Avatar
2012 E350 RWD
What if some slight camber was added. Think it would clear?
Old Jul 25, 2011 | 05:47 PM
  #239
if you go skinny tire it might clear inside. U will clear the lip I beleive, but u will rub a little inside fabric on bottom outs. On my 08 I could never drive w passengers in back cause it would rub on larger bumps, but I never really do so didnt matter to me. If you do the size and offsets u posted, you could do 215/35 up front and 245/30 out back and be ok IF ITS A SKINNY tire, basically a tire without a bead protector on it. Ive recommended falken 452's and sumitomo HTRZ3's cause I have wheels w both and they run skinny and very good tires, the falkens a little pricier but great wet/dry performance
Old Jul 31, 2011 | 05:39 AM
  #240
darren parker's Avatar
c350 sport
Originally Posted by Dj Toobs
19X8.5 - 45 offset
19X9.5 - 50 offset
Hi looking to do the same set up on my c350.being used for the family car so dont want any rubbing. Yours looks awesome. what spings are you on and have you had any rubbing.
Old Aug 8, 2011 | 10:02 AM
  #241
w204 C300
Originally Posted by c3nthusiast
Wheels: Mandrus Stuttgarts 20x8.5" 42 ET and 20x10 54 ET.
Tires: Falken 452 225/35-20 and 255/30-20
Springs: Eibach Pro Springs on stocks
Posting this here for another user.
Old Aug 14, 2011 | 05:19 AM
  #242
c350 sport
Angry rubbing
Help! Have lowered my c350 30mm on eibachs and fitted 19 " wheels.
Front 8.5j ET 43 with 235-35 tyre.
Back 9.5j ET 46 with 265-30 tyre.
When i have people in the back its rubbing the wheel arch on bends and dips in the road.
Any help would be great.
Old Aug 15, 2011 | 12:29 AM
  #243
Mixedfruits's Avatar
E63 Black on Black
So ill be picking rims soon, What should I look at? I am running H&R SuperSports. My final look would be a flush look with very little to none wheel gap. Any suggestions? How would I go about for this look find wheels first? then tires? or what? much help would be nice thanks.
BTW know noting about wheels or tires
Old Aug 15, 2011 | 12:41 AM
  #244
xXHotelCrazyXx's Avatar
2008 W204 Sport
First what is your honest budget?
Old Aug 15, 2011 | 12:43 AM
  #245
E63 Black on Black
/\ nvm thanks gona look for coils first haha
Old Aug 15, 2011 | 12:44 AM
  #246
2008 W204 Sport
Good call
Old Aug 15, 2011 | 12:46 AM
  #247
E63 Black on Black
yeah screw cutting it thought I could pull it off like benzobro
Old Aug 15, 2011 | 12:49 AM
  #248
2008 W204 Sport
Coilovers are the best way to go if you really want to go low
Old Aug 15, 2011 | 12:51 AM
  #249
wnunez89's Avatar
c350coupe, Gencoupe R-spec
I think even with coils on the lowest setting you dont get the "slammed" look, from what I can remember mike "azn" posted pics of his car on the lowest setting with his h&r's
Old Aug 15, 2011 | 12:54 AM
  #250
E63 Black on Black
yeah so im debating on what to do now zzzzzz grrr
You have already rated this thread Rating: Thread Rating: 14 votes, 4.64 average.
