W204's and offsets of wheels
SILVER
BBS CH 19X8.5 ET45 FRONT AND 19X9.5 ET45 REARS.
OR
MATT BLACK
BBS CH 19X8X5 ET 45 ALL ROUND
I'm more leaning towards the Matt black as I want a black on black look. Only problem is, the black set don't come 9.5 staggered rear.
What would you guys do?
SILVER
OR
MATT BLACK
I had ch's on my jetta, best wheels ever. Curious to see how they look on your car when you get them.
Just thinking that if I go 8.5 all round. The rears won't look as concave as 9.5.
I think I will go for the bbs ch r blacks.
Can't let a bargain slip.
Will post pix once I install.
and what off set should i get that is a little bit in the fender?
Got_thang's car: 19x9.5 et 25 offset front 19x11 et 30 rear
https://mbworld.org/forums/c-class-w...-day-work.html
and
https://mbworld.org/forums/4692511-post105.html
Front 19X8.5 (42mm offset), tires are 235/35/19
Rear 19X9.5 (40mm offset), tires are 235/35/19
Any thoughts or suggestions?
Model : UO06
Front Size : 20X8.5 Front Offset : +35
Rear Size : 20X10 Rear Offset : +38
HUB SIZE : 72.6
and a tire shop told me to run
Front : 245/30/20
Rear: 255/35/20
I am also planning to run H&R super sport springs...
Can anyone confirm that this will work out?
ET that fit front with minimal rub should be +44 and same for the rear.
The tires your running is taller than factory so your speedo will be off, and will be slight stretch in the rear. For the rear your ET should be in the +50
your fronts should be no lower than +44.
I will have to double check if they changed in the 09's.... anyone know?
Model : UO06
HUB SIZE : 72.6
Front : 245/30/20
Rear: 255/35/20
I'm afraid that will rub onto the back.
It might be better?
Front 19X8.5 (42mm offset), tires are 225/35/19
Also check out tyrestretch.com for a bunch of examples in their library.
Front:
REAR:
I'm looking to buy a set of wheels for the winter and found these but I'm not sure if it fits...
They are original Mercedes wheels, 17x7.5 et37.
Will these fit my 2012 C300? I am running on H&R SS springs...
Thanks in advance.
I've read almost every pages of this thread and I don't feel less confused than before I started haha!
I have chosen a nice set of wheels for my RWD C-350. They are 19's (8.5 +45 front and 9.5 + 48 rear).
I have a stock suspension but thinking to go with coil overs this next spring (pretty positive I'll do it).
I have read people using 225/35/19 fronts and 255/30/19 rears. Doesn't this make the fronts higher than the rears? it seems weird to me..
Q-1 Anyone reckons it would make a better fit using 215/35/19 in front?
Q-2 Would it be possible to go a little wider on the rear like 265/30/19?
Thanks for the answers!
Regards,
JM
Regards,
JM
What about 235/35/19 front and 265/30/19 rear?
Anyone has ever tried that combination? Would there be any inconvenients using that combinations?
Cheers,
JM
http://www.ebay.com/itm/130641147616...84.m1423.l2649
One thing is sure: They are really cheap. But I like the look since my car is black I think it would make a nice match. Different than the originals, more aggressive look but still has a Mercedes kind of looking. I'm sure they'd look awesome on my car with a lowered suspension :-)
Thought I might share the link, even though everyone has different taste let me know what you think!
I am using that setup 235/35 265/30 on mine. Your only problem now will be your ET and what brand tires you are using. I have a little rubbing up front on dips, but I'm lowered 24inches wheel arch to ground all around w/ a -.08 camber all around.
JM
The picture below is my Mazda6 GT sitting on 18's, both front and back tires are 225/45/18 without any offset. Rear fender was rolled to allow the larger tire, the front was ok as it accepted the larger tire and rims.
Another side view
