W204's and offsets of wheels
Front 17X7.5 (47mm offset), tires are 225/40/17
Rear 17X8.5 (58mm offset), tires are 255/40/17
I'm thinking about buying a set of wheels from a member here but want to make sure they will fit without rubbing.
Front 19X8.5 (32mm offset), tires are 245/40/19
Rear 19X9.5 (41mm offset), tires are 275/35/19
From the looks of it, the wheels will stick out about an inch or so to the outside and about a 10th of an inch to the inside.
Any thoughts or suggestions?
I guess I'll keep looking.
Lowest ET fronts for 19's I would recommend is 42 and 44 for rear. Slight rubbing on dips depending on able of road but not major. This can be fixed with alignment and or skinnier tires. 225/35/19 - 255/30/19
Skinny Brand tires (means their sidewall shoulders are usually designed rounded which will give more clearance to our fenders)
Falken, Sumitomo and Nitto
Other brands usually have a more squared shoulder design.
You may as other guys opinion on this.
Small example of our monoblocks on an SL55 we did a while ago!
Here the customer wanted this exact look and fitment and we did just that! We can have a customer that wants an extra wide wheel, which will be used in a widebody conversion, we do it. Something more OEM looking, same thing.
/jaiscossie/20120626_132015.
