W204's and offsets of wheels
Rating: Thread Rating: 14 votes, 4.64 average.
Old Feb 6, 2013 | 06:51 PM
  #701
lovew204's Avatar
Mercedes C300 AMG
Originally Posted by kevink2
Quick question: Why didn't you ask about the fit, before you bought them?
I don't expect an answer like this. Anybody help?
Old Feb 7, 2013 | 02:42 PM
  #702
benzc316's Avatar
c230 2008
There is no difference in the rear, as the same rwd model's rear drive suspension is used in the 4MATIC.
But up front, the struts were moved on the 4MATIC to make room for the front half/drive shafts. So the front struts are different where they attach at the bottom. And because the exact spring location is different, the OEM springs are not the same, rwd vs 4MATIC ... different part numbers. Sooooooo
THE 4MATIC USES DIFFERENT FRONT SPRINGS AND STRUTS (bolt hole locations) vs THE RWD VERSION OF THE MODEL
It may be possible to put aftermarket front springs for a RWD on a 4MATIC, but the respected Engineers at H&R thought they were different enough to specify different springs, at a significant expense to them. These 4MATIC springs are only available in the Sport version. Eibach and Brabus do not offer any springs for the C300 4MATICS.
At one time I thought Eibach offered the lower drop "Sportline" springs for the RWD C300 W204, but now Eibach does not list them on their website, and I could not find a vendor selling them.
ok thanks for your help
ive order hr supersports, ill do the test
maybe ill keep the hr sport in front and put the supersport on the back and see how the car is handling.
variant v3 are too expensive for a car that ill may change in 1 year.
now
can someone help me with the tire size ill need
info on rims and car are given a few post ago
thanks
Old Feb 9, 2013 | 08:43 AM
  #703
pnoyworx's Avatar
10 E63, Sold -07 E63
You will be fine with those wheels, but I think you may run a 10mm spacer on the rear for it to sit closer to the fender. Don't forget the longer lugs. You will not rub. Minimal with out modification to our car is ET44 front and rear with rounded shoulder type wheels.
Originally Posted by lovew204
My car is C300 without 4matic
I need help. I ordered a set of rim 8,5 x 18 ET45 and my tires size
Front 235/40R18
Rear 255/35R18
I worry about rubbing. Do I need any wheel spacer for front or rear? Thank for all advices
Old Feb 9, 2013 | 01:45 PM
  #704
lovew204's Avatar
Mercedes C300 AMG
Thank you very much with your help! But when I checked with this site http://www.rimsntires.com/specs.jsp with this comparisions 245/40R17 ET58 (OEM) and 255/35R18 ET45. I received the advice:
- Suspension: 100% clear (leave even more room than OEM)
- Fenders: Package will stick out 18 mm (0.7'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
- Wheelwells: Will fill out the wheelwell by extra 4 mm. Almost no difference.
I am now a little bit confuse. If I use 10mm spacer maybe I'd have rubbing issue?
Old Feb 9, 2013 | 05:22 PM
  #705
pnoyworx's Avatar
I am running 19x8.5 fronts with a 42ET which is more aggressive than 45ET.
My rear is 19x9.5 with a 48ET with space to give. I only have a slight rub in the front but only on really bad dips. As you can see my rear rim is wider than yours and only .3mm difference. But you know sometimes each car varies, if your on stock height, you will be fine, it's when your lowered that fitment becomes critical.
Old Feb 10, 2013 | 02:10 AM
  #706
lovew204's Avatar
Mercedes C300 AMG
Thank you pnoyworx! I'll review later...
Old Feb 10, 2013 | 08:09 PM
  #707
CLASSYC300's Avatar
C300
I've ordered a set of jdm wheels
18x9 +19
18x10 +19
Tires : F 205/40 ; R 215/35
Any thoughts and opinions?
Old Feb 10, 2013 | 09:14 PM
  #708
Cleanbenz's Avatar
2010 E350
18x9 +19
18x10 +19
Yes, they aren't going to work easily if at all. That is some serious stretch and poke. My pic below is 18x9.5 ET 36 with a 215/40 tire, your wheel will poke 11.4mm more than this. You are in the territory of poking tread, not just sidewall. You may be saved by your 205/40 tire size but its cutting it super close.
W204's and offsets of wheels-ed2fcdbe-a4c3-4421-9163-06c45d158396-14189-00000b5a34fc0aa7.jpg
W204's and offsets of wheels-978ce92c-efd5-49bf-bef1-c45a2ebd7a31-14189-00000b59e0cf2916.jpg
Old Feb 10, 2013 | 09:20 PM
  #709
Cleanbenz's Avatar
2010 E350
Don't get me wrong! I'm a huge fan of stretch and poke I just know the limits of our fenders and they need lots of work to get that aggressive. I'm hoping it works for you though.
Old Feb 11, 2013 | 07:00 PM
  #710
CLASSYC300's Avatar
C300
[quote=Cleanbenz;5540272]Yes, they aren't going to work easily if at all. That is some serious stretch and poke. My pic below is 18x9.5 ET 36 with a 215/40 tire, your wheel will poke 11.4mm more than this. You are in the territory of poking tread, not just sidewall. You may be saved by your 205/40 tire size but its cutting it super close.
Cutting it super close is exactly where I want to be at, also forgot to mention that I'm also on air . Any other words you Mind to throw at me? How about the rears bro?
Old Feb 11, 2013 | 07:15 PM
  #711
CLASSYC300's Avatar
C300
Im also running front camber plates
Old Feb 11, 2013 | 08:05 PM
  #712
Cleanbenz's Avatar
2010 E350
[quote=CLASSYC300;5541550]
Rears are the same deal, in that pic I was running a 18x9.5 ET 24 with 215/40 tire. Poke will still be 11.4 mm more than what I how in that pic. Camber plates up front are a huge plus as I am looking at running them to get some negative camber for clearance aswell. They could make all the difference. I just test fitted my new wheels today and I decided to go a not more conservative because I've already pulled the fenders with rubbing from the setup in the pics. Here is the new fronts: 18x8.5 ET 35
W204's and offsets of wheels-f73cb68d-4a04-4ac4-9988-60e297ab3904-410-000000191b18c107_zpsc2c082a1.jpg
W204's and offsets of wheels-88108167-bb8c-420e-a8c3-00493116c45f-410-0000001913f5ed39_zps0a9478bb.jpg
Rears: 18x9.5 ET 35
W204's and offsets of wheels-fe254f89-7490-4a48-bedc-e24b1ad7dc8b-410-00000019e67e6671_zps5fdd3c0c.jpg
W204's and offsets of wheels-d9777c20-beed-4065-9682-20ee46b4a875-410-00000019dc6e31f6_zpsde800473.jpg
Old Feb 12, 2013 | 08:26 AM
  #713
CLASSYC300's Avatar
C300
Ÿøū are really getting somewhere! Keep me posted ! Looks beautiful! I'll test fit mines and post as well ASAP. I hope my wheels come in This week so I could throw my car into wekfest Hawaii this weekend !
Old Feb 15, 2013 | 12:20 AM
  #714
EuRo_C300's Avatar
2103 Cls550 | C300 MT For Sale
Question
Need quick advice, I have Hankook V12 Front 235/35/19 and Rear 265/30/19 . I want to lower it with H&R super sport springs. What rims offsets should i get for the setup? Thanks
Old Feb 15, 2013 | 08:40 AM
  #715
lovew204's Avatar
Mercedes C300 AMG
Thank you guy! I've just installed my new set of rims today. They are perfectly fitted. Here is the detail if someone need:
Front 235/40R18 on 8,5 x 18 ET 45
Rear 255/35R18 on 8,5 x 18 ET 45
Old Feb 15, 2013 | 09:36 AM
  #716
lovew204's Avatar
Mercedes C300 AMG
Old Feb 15, 2013 | 09:38 AM
  #717
lovew204's Avatar
Mercedes C300 AMG
Old Feb 15, 2013 | 09:41 AM
  #718
lovew204's Avatar
Mercedes C300 AMG
Old Feb 15, 2013 | 12:07 PM
  #719
kevink2's Avatar
2004 Mazda6, 1993 RX7
Looks good ! OEM springs?
Any change in road feel, vs the old 17" set ? I figured quicker response to steering inputs, but perhaps a little rougher on rough roads, vs previous 17" wheels/tires.
Old Feb 15, 2013 | 01:34 PM
  #720
lbmazdaspeed's Avatar
2009 c300 4matic P1
Do you have any closer shots of the rear wheels?? How close is it to the fender??
Old Feb 15, 2013 | 07:18 PM
  #721
lovew204's Avatar
Mercedes C300 AMG
Here you are
It is a little closer to the fender than stock wheels but it looks much better!
Old Feb 15, 2013 | 07:29 PM
  #722
lovew204's Avatar
Mercedes C300 AMG
Yeah I keep OEM springs. You'll feel a little rougher but more response...
At first here is 2 best summer tires, I don't know which one is better. But finally, I chose Goodyear Eagle F1 Asymmetric 2 with no regret!
Old Feb 16, 2013 | 11:16 AM
  #723
pnoyworx's Avatar
YAY, glad it worked out for you! Looking good! What's next?
Old Feb 16, 2013 | 04:09 PM
  #724
lovew204's Avatar
Mercedes C300 AMG
Thanks! Still thinking for next mod. Maybe Eibach Antiroll Bar and 2012 Led tail lights...but don't know how to coding SAM?!?!
Old Feb 17, 2013 | 07:43 AM
  #725
pnoyworx's Avatar
Your out of state right? Yeah sorry I do not know how to help you there, except if your willing to ship your SAM here to Washington, someone does it on the side, I'm sure you have read the thread on it. But that would mean shipping cost and down time for you. Sorry I can't point your to a better direction. BUT beefing up the suspension will definitely give you back some good feeling when your driving spiritedly.
You have already rated this thread Rating: Thread Rating: 14 votes, 4.64 average.
