W204's and offsets of wheels
#978
#980
Last question I swear,
I made up my mind to go with AMG 836 replica wheels from power wheels pro;
19x8.5 (F) and 19x9.5 (R), offset 42mm all around.
Currently I have OEM wheels; 225/45/17 fronts and 245/40/17 rear
Rim sizes: 7.5x17 (F) and 8.5x17 (R), Offsets; 47-58.
Question is which tires to get, these are the options; 235-35-19 (F), 265-30-19 (R)
Second option ,which I would prefer if it would fit, is; 245-35-19 F and 275-30-19
With OEM wheels/tires I have about 15 mm extra tire extending over wheel on each side to protect it from the curb. With first setup describe above, I would have about 10 mm on each side. With second setup I would have about 15mm.
Question is would the wider tires fit, would they rub, would they extend past fender or be flush?
Thanks.
#981
I would go with 235/35 and 265/30 as these are closest to stock circumference,
its impossible to beforehand say how much the tire will extend as it depends on the rim shape and tire make.
#985
Does anyone think this set up will work on my 2009 C300? I am a bit skeptical myself about it but wanted to get a second opinion.
Lowered on H&R Super Sports
Front: 20x9 245/30/20 ET45
Rear: 20x10.5 285/25/20 ET44
I can change up the tire size but my main concern was if the wheels width and offsets would be possible
#986
2012 C300 4Matic Sport
#987
2013 Mercedes C200 // 2010 Mercedes E300
Hi sirs,
Can somebody advice if this AMG rims and tires from
E Class can fit my C Class W204 2013.
Front-8.5 x 18 ET 48, tire size 245/40.
Rear-9 x 18 ET 54, tire size 265/35.
#990
I just bought this combo. Got a killer deal even if the tires don't work out. My car is not lowered. Will I have a shot in hell getting these to work?
http://mercedespartspeople.com/produ...el%20-%20Black
#992
#995
215/35/19
235/35/19
Or
225/35/19
265/30/19
Car Will be lowered on 19x8.5 et35 / 19x9.5 et48 just to recap.
#996
https://mbworld.org/forums/c-class-w...cs-stance.html
#997
H&R SS + your wheel specs + 215 & 235 tires would look very similar to this car:
#998
Yeah after hours of research I ran into that car. He runs +35 all around. I've ran 235's on a 10 before and it wasn't that stretched at all. I think I'll go with the smaller setup for now just to be on the safe side. I really wish I could run the bigger set with no issues.
#1000
Looked into this but it's labor intensive, $100 per wheel and in the event of naturally occurring damage to a front upon replacement, quick replacement would not be an option. Good to point out though.
