W204's and offsets of wheels
Old Feb 3, 2014 | 08:44 PM
  #1001
Baker250's Avatar
C250
Love my new set up
Brabus VI
19x8.5 et:33 225/35/19
19x10 et:42 255/30/19
Lowered on H&R Super Sport Springs with 5mm pads in the rear
Old Feb 3, 2014 | 08:46 PM
  #1002
04boxster's Avatar
2014 C250, 2015 C63S E1
You sir have helped me make my final decision. Before I order, do you rub and do you have the fenders rolled?
Old Feb 3, 2014 | 11:49 PM
  #1003
RLpolo2014's Avatar
Toyota Tundra & C300
Newbie here and need help... will these fit a 2011 c300??
Front 18x8.5
Rear 18x9.5
Offset ET35
I'm hoping for 225/40/18 in the front and 245/35/18 in the rear...
Appreciate the help!!
Old Feb 4, 2014 | 12:09 AM
  #1004
teja1936's Avatar
2010 Calcite C300 with AMG Sports Package
I have just purchased (Jan 14) and am running the following:
Front 8" X 18" with ET 45 with Continental ‘ContiSport3’ 235/40/18 (F) and
Rear 9" X 18" with ET 54 with Continental ‘ContiSport3’ 265/35/18 (R)
Loaded up the car with the family and all our gear for a weeks holiday travelled 1200Kms with no 'rubbing' issues whatsoever.
Old Feb 4, 2014 | 12:49 AM
  #1005
Baker250's Avatar
C250
Yeah I used to rub but i cut the inner lining of the rear fender and shaved where the bumber and fender meet a bit and had pulled them a little, also im running -1.9 camber which helped stop the rubbing
Old Feb 7, 2014 | 03:24 PM
  #1006
RLpolo2014's Avatar
Front 18x8.5
Rear 18x9.5
Offset ET35
I just spoke to my buddy who is a manager at discount and he's telling me that he's not 100% that these tires won't rub. Is anybody else running this same setup??
Old Feb 12, 2014 | 06:02 PM
  #1007
04boxster's Avatar
This just worked. No rub.
19x8.5 et35 225/35/19
19x9.5 et48 255/30/19
Ordering hr SS now
Old Feb 13, 2014 | 12:50 PM
  #1008
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
Ordering hr SS now
you will rub up front with that setup on HR SS.....out back u can go as wide as 275, I am running +48 out back 19x9.5 275/30/19 and clear on custom springs........up front I slightly rub on +40 w 225/35/19.......this is with falken 452s all around
Old Feb 13, 2014 | 02:00 PM
  #1009
Baker250's Avatar
C250
Ordering hr SS now
A heads up, if plan on going with 5mm pads on the rear itll be lower in the back than the front. Cant wait to see how your set up will look
Old Feb 13, 2014 | 06:13 PM
  #1010
04boxster's Avatar
Not getting the pads. I like a slightly raked look. If it rubs in the front I'll just roll the fenders. Will post pics! I'm running a skinny 225 as well, those 452s run wide. I should be in good shape.
Old Feb 14, 2014 | 04:22 PM
  #1011
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
will a 255/35r18 will rub on stock sport height with a 8.5" 44 offset rear wheel?? not planning on lowering but might carry a full load once every 2 weeks.
Old Feb 20, 2014 | 07:37 PM
  #1012
portchop002's Avatar
08 C300 4Matic
what tire can I run on an 08 C300 4Matic?
F - 19x8.5 +37mm
R - 19x9.5 +37mm
Old Feb 20, 2014 | 09:42 PM
  #1013
Pictures of my new shoes
18x8.5 et 44 all around on michelin pilot MXM4 235/40 at front 255/35 at rear
Old Feb 20, 2014 | 10:17 PM
  #1014
dubber350's Avatar
C300
I am looking at TSW wheels for my 2008 C300 4 Matic Sport, the car is not lowered.
W204's and offsets of wheels-alloy-wheels-rims-tsw-mirabeau-5-lug-rear-silver-std-700.jpg
I would like them in 19x8 or 19x8.5 in the front and 19x9.5 in the rear, will they fit without rubbing?
What should I be looking for in an offset?
Old Feb 20, 2014 | 10:23 PM
  #1015
snickaren's Avatar
2012 C 220 Cdi Diamond white with AMG/Sport package
[ttp://mbworld.org/forums/members/shotgun_banjo-204483-albums-mb-5265-picture-c300-2-42728.jpg[/IMG][tp://mbworld.org/forums/members/shotgun_banjo-204483-albums-mb-5265-picture-c300-5-42729.jpg[/IMG][IMG]https://mbworld.org/forums/members/shotgun_banjo-204483-albums-mb-
Nice
Do you run on stock springs?
Old Feb 20, 2014 | 10:34 PM
  #1016
Thanks snickaren! stock springs only but car is a 4matic. 1/16 gas on tank so it will drop a tad little on the rear when filled with gas.
Old Feb 20, 2014 | 11:01 PM
  #1017
snickaren's Avatar
Hey all...
I'm thinking about these rims for my ride. http://www.bmautosport.co.uk/showroo...ath=53_325_330
Do you think they will work on stock springs? I'm going for 9,5 rear and my ride has the AMG/Sport package.
Which Et should you recomend for the front wheels?
Here's a link to the tyre package's they offer http://www.bmautosport.co.uk/showroo...ge-options.php
What would you recomend, I want staggered in the rear? (Me like it wide )
Tnx
Old Feb 20, 2014 | 11:06 PM
  #1018
snickaren's Avatar
Hmm is it slightly higher springs on the 4matic? Still look's great thouh
Old Feb 21, 2014 | 12:02 AM
  #1019
It the same as the RW drive version accept the front is a little bit lower because of the weight of the 4matic (I think) so it rakes a bit. When I have a full tank of gas I find the drop at the back perfect. I can barely fit my two fingers between the front fender and tire even on the stock 17" then at the back I will say 3ish fingers give or take. For the front wheels I say 44 is the best. You can go lower than 44 but you might have to run skinny tires.
Old Feb 21, 2014 | 01:43 PM
  #1020
xaran's Avatar
2012 C 250 Sport Sedan
Attachment 279625
Im running TSW Rivage in 8.5x18 48offset front with 225/40/18 Nitto Motivo and 9.5x18 54 offset rear with 245/35/18 Nitto motivo perfect fit
Old Feb 21, 2014 | 01:46 PM
  #1021
xaran's Avatar
Great looking wheels and very good fit!
Just for my education I have a question why did you go "square" with the wheel size but them staggered in the tire size? Since you cant rotate this set up why not stagger the wheels too?
Old Feb 21, 2014 | 11:49 PM
  #1022
I was planning on getting continental dws on 235/40r18 for all corners but when I was about to go to the tire store my friendly MB sales person called me and asked me if I am interested for a brand new take-off of michelins from an e-class that he just sold as the guy who bought the e-class also bought upsize rims+ tires as part of the deal. The fact that he is selling it to me for a jaw dropping $350 for all four is something an idiot won't take. Just one 255s cost $280+tax so basically I got almost all of the tires for peanuts.
Here are couple of shots of the ride after getting washed and half detailed. Now I just need to get those spoilers but can't decide which one.
Old Feb 22, 2014 | 03:48 AM
  #1023
vic viper's Avatar
S213
@shotgun banjo, why run 235/40 up front?
They are almost 2% larger than stock while your rears are a perfect match, you can tell by your pics that the front tires look bigger.
I would run 225/40
Old Feb 22, 2014 | 04:05 PM
  #1024
Maybe it is the camera angle but I barely notice the difference using my eyeballs. Actually it made the ride a tad softer maybe beacuse of the extra width of the tire and I like it better than the stock tires setup. Also if I ran 225 for me it will look too stretched on 8.5" rims and I kinda like the square look.
Old Feb 24, 2014 | 12:43 PM
  #1025
08 C300 4Matic
xAnyone running a 37 offset all around (F19x8.5 R19x9.5) ? I have a 4-Matic btw
You have already rated this thread Rating: Thread Rating: 14 votes, 4.64 average.
