W204's and offsets of wheels
I was wondering if I could run a 9 in front at et50. It is the same poke. I am more concerned about inner clearance.
H&R SS
hey guys, I'm looking at getting these, preferably in 19's and was wondering what offset ect I'm going to need to run. They come in ET35, ET42, and ET40.
I'm wanting to be flush with the fender (stock suspension for now but looking at bags or coils down the road), and I want to run a bit of a stretched tire to expose the lip. what size of tire and wheel offset should I be looking at?, I have a 4matic so do I have to run staggered sizes?
thanks for the help
I read a lot of posts in this thread and seems like most people would recommend running 255/30/19 in the rear but given there are only a handful of tires to choose from, I might have to run 265/30/19 instead.
I am just wondering if this setup below will have any rubbing issues on stock suspension or any problem with the 4matic:
Front: 19x8.5 +42 235/35/19
Rear: 19x9.5 +42 265/30/19
If this will give me issues, I might just run 19x8.5 all around with 235s
Okay, I threw them on and I don't have any issues with rubbing at full turn or anything. Though I'm looking at a set of H&R Super Sports, and not sure if they will rub like crazy due to the poke.
Anyone with experience of running front 18x8 ET30 (235/40) & rear 18x9 ET39 (245/40) on Super sports?
Super sports is a mild drop IMO. 225/40 front is more ideal
Yeah took it by my mechanic the other day, it'll be tight, but worst case I'll get a set of 225 for the front. I ordered the H&R SS + 5mm Spring pads, so now it's just the waiting game for Wednesday to see if the front is gonna rub or not.
Front: 19x8.5 ET32 215/35/19
Rear: 19x9.5 ET35 235/35/19
Front: 19x8.5" +30 (225/35/19)
Rear: 19x9.5" +33 (255/30/19)
Pretty similar setup, pretty risky, but with the right tweaks it should be perfect. Going for a completely flush look with some SLIGHT stance. I'll post pics when done.
ill be running 19x9 all around et39. I like where your going with this
After doing research (thanks to this thread) I am looking at the following setup:
18x8.0 ET45 tire size 225/40/18
18x9.0 ET45 tire size 255/35/18
CAR: 2012 C250 Sport (factory ride height)
Now, is this too conservative? It seems to be more aggressive than the stockers, but am I now being too cautious?
My goal is to have trouble free fitment. I used to have more aggressive fitments on my previous cars and the rubbing/scrapping was something I could not get used to.
BTW, kudos to all on this site who've done some awesome work on their 204's.
Thanks!
Thanks!
19x8.5 et35
19x9.5 et40
225/35/19
255/30/19
I'm lowered on H&R SS and this setup does not rub and is extremely flush. You're good from there at least.
I've read through (most of) this thread and I've seen some great looking cars.
I've got my car lowered with Eibach pro and I'm looking at replacing the stock wheels. My stock 17's sit ridiculously deep in the wheel wells so I'd like to fix that when getting new wheels & tires.
I have one concern, though: How does a lower ET influence the handling of the car? Does anyone have any experience with changing just ET (same tire size) and what impact (if any) did that have on the handling & stability of the car?
In theory, I would expect the ET value of the front wheels to have an influence on the steering behaviour and steering wheel feedback because you change the position of the wheel relative to the swivel point of the steering.
This explains it better than I can:
http://www.miata.net/garage/offset.htm
-PJ
-PJ
One thing is for certain, ride quality will suffer. I personally though, actually prefer a more "connected" feel. But so far as a BMW (having owned 4). Diameter will also come down to taste.
