W204's and offsets of wheels
Old Jun 26, 2015 | 01:40 AM
  #1476
Young_Euro's Avatar
C250 Sedan sport
Just ordered:
Front 19x8.5 et32 --- 225/35/19 slight stretch?
Rear 19x9.5 et40 --- 245/35/19 slight stretch?
Lowered on H&R SS... Anyone have rub issues with this set up?
Old Jun 30, 2015 | 01:18 PM
  #1477
Demvang's Avatar
2011 C300 4Matic Sport
I'm thinking about getting these 18" wheels. Are they the right ones for 2011 C300? TIA
http://www.ebay.com/itm/231314019709?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Jun 30, 2015 | 02:40 PM
  #1478
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
Originally Posted by Young_Euro
Just ordered:
Those tires sizes are too small for the rims imo.
Old Jun 30, 2015 | 05:00 PM
  #1479
dudeitsmattx's Avatar
2013 C250 Sport
Just ordered:
You might have minor rub issues. And those tire sizes are in spec for 8.5" and 9.5" wheels. To better your chance of no rubbing you should go with 215/35 and 235/35 it is a very very minor stretch that cant really be noticed.
Old Jun 30, 2015 | 05:03 PM
  #1480
2013 C250 Sport
Originally Posted by ripratama
Hello folks,
Greetings from Jakarta, Indonesia. I recently acquired a Classic-trim C200 Kompressor and would like to upsize the wheels with either of these specs:
Front 18" x 8" ET35
Rear 18" x 9" ET35
Or
Front 18" x 8.5" ET35
Rear 18" x 9.5" ET35
Planned tyres are 225/40 and 255/35 fronts and rears respectively.
Will both specs clear the fenders? There may be 3 persons in the back on some occassions. Not planning to lower it; however may change the spring pads if the gap becomes too large.
Thanks for your help.
The only size that would not be ideal is the 9.5" ET35. As for 8" ET35 would be fine and the 9" ET35 would be also.
I run 19x8.5" ET35 and 19x9.5" ET40 they are the max you want to run for these widths.
Old Jul 4, 2015 | 09:22 PM
  #1481
Johnyape's Avatar
MB 200CDI Avantgarde -08
Hi! I got stock 200cdi with stock suspension. I am looking for 18" wheels and tyres.
Front:
18x8 (or 18x9)
ET options: 35/42/45
Rear:
18x9
ET options: 35/38/42/45
I already got two 225/40 hankook tyres. (front)
255/35 rear?
Later I'm runnig with -30mm H&R springs...
I want wheels close to fender without rub/rolled fenders. Thnx!
Old Jul 6, 2015 | 09:42 AM
  #1482
ripratama's Avatar
C180 W202
Thanks dudeitsmattx, I ended up with 8" ET35 all around without any issue. Will post some pics when they are ready.
Old Jul 16, 2015 | 04:02 PM
  #1483
qazstar's Avatar
c class 220cdi
Guys sorry I'm new and can't work out how to add a new post
need to Find someone who has put brabus monoblock iv on a w204 ?
Old Aug 4, 2015 | 11:42 PM
  #1484
andreb's Avatar
my11 c250 cdi avantgarde
just picked up this bad boy, looking at putting rims..
current has the stock sports suspension and 18" amg wheels setup. 255 rears and 225 fronts, i would like to keep the staggered fit.
im interested in setting it up on 20s or 19s, trying to figure out the best option as i want it looking tough, and 20s are tough. especially concave or dished. or the 19s options is the mesh style amgs from c63 my15'
i do need to drive it daily, so im happy to bump out the inside of the gards or negative camber a little so its still suitable. in this case it sounds like 19s as bigger tread means more kms.
i am looking at dropping it a little bit on some kind of concave wheel, see attached image below:
any recommendations on setups with offset info would be greatly appreciated as i still want my rims to fit in nicely and not stick out.
thanks in advance..new mb owner.
Old Aug 9, 2015 | 08:54 PM
  #1485
blitzkrieg69's Avatar
2012 C250 Sport
So, I found a killer deal locally on a set of used wheels from a '12 S550.
http://www.wheelsandcaps.com/Mercede...ekQaAn2g8P8HAQ
http://www.wheelsandcaps.com/c-2283-...oy-wheels.aspx
The seller says they're ET42, front AND rear, although both sources I've found say 43. Are these going to poke on my '12 c250 sport?
Oh, and suspension is currently stock, and will probably remain that way.
Old Aug 9, 2015 | 09:47 PM
  #1486
2013 C250 Sport
It says they are 8.5" in width. So ET42 or ET43 will be just fine.
Old Aug 9, 2015 | 09:54 PM
  #1487
2012 C250 Sport
The fronts are 8.5, but the rears are 9.5 and also et43. That's why I'm concerned. I'm not at all into poke or stretch
Old Aug 9, 2015 | 10:37 PM
  #1488
phenom3030's Avatar
2013 C300 4MATIC Sport sedan
9.5" rear at et42/43 should be fine. I'd think it would look really good.
Old Aug 9, 2015 | 10:50 PM
  #1489
2013 C250 Sport
Yeah 9.5" rear ET42/ET43 will be fine. I run 9.5" rear ET40
Old Aug 11, 2015 | 05:24 AM
  #1490
samhkh's Avatar
C180K
Hi Guys
planning to put on these on my 2008 w204 c180
front 19x8.5
rear 19x9.5
offset=38~40
(dealer had higher offset of 40++)
gonna fit them with front - 235 35 19 and rear - 265 30 19
planning to install h&r spring too.
so the rear will have a concave feel while the front is flat look (staggered??)
will my car have problem with these setup?
will there be rubbing?
Old Aug 11, 2015 | 09:11 AM
  #1491
2013 C250 Sport
no you will be fine
Old Aug 11, 2015 | 09:49 AM
  #1492
samhkh's Avatar
C180K
Thanks dudeitsmattx~!
Just got confirmation from dealer, they have 2 different offset for the wheels.
either ET30 or ET43
ET30 sound impossible for my ride, the wheels will be "poking" dangerously outward, given my design.
Correct me if I'm wrong
I guess with the wheel size mentioned, it shd look good with ET43 on my ride.
Cheers!
Old Aug 11, 2015 | 02:08 PM
  #1493
2013 C250 Sport
Yeah ET30 will sick out from the fenders. If that is not the look you want go with the higher offsets
Old Aug 12, 2015 | 12:57 AM
  #1494
2012 C250 Sport
I posted a page back with questions about some 19" wheels I found locally and fitment, but when I asked the seller if I could take them to a local tire shop to check if they're straight, he stopped answering, so that's off the table. This has led me to a dilemna, 18's or 19's.
This is a daily driver for me, and I have no intention of doing any racing or stunt driving in it, lol. My wheel upgrade will be for cosmetic appearance only. That said, I think I've narrowed it down to 18's with HR ss springs and 18's, or 19's and no drop. I've seen many of both on here, and I'm happy with the appearance of both. I do, however, want to keep the ride as comfy as possible. So my question is, to those who have tried both, which option would give me the more comfortable ride, the 19's and stock suspension, or the 18's with a drop? Please don't offer advice if you haven't tried both options, but thanks in advance for any responses.
Old Aug 12, 2015 | 09:36 AM
  #1495
2013 C250 Sport
You will have a smoother ride with 18's since you will be running a bigger tire size in height. 19's are not a bad ride quality, just not as good as 18's. As for the springs H&R makes great products and is very near the ride quality of stock.
Old Aug 15, 2015 | 03:37 AM
  #1496
Naverino's Avatar
2013 C63 w/PP, 2014 ML63 AMG w/PP
Hey guys here's my w204 2014 c350 4matic with stock sport suspension.
Here are the specs:
Michelin PSS tires
Front - 235/35/19 et45
Rear - 265/30/19 et45
I want to lower the car but my front sits pretty low as it is just want to rear to sit maybe with H&R SS but not sure if I will rub maybe H&R sports? Also do I need new rear pads?
New at lowering and am confused as hell after reading and seeing all the combinations out there in all the posts.
Old Aug 18, 2015 | 10:45 AM
  #1497
Badmeat's Avatar
'09 Calcite White C63
I need some quick advice...I'm planning to go with the following setup:
19x8.5 +40 with 245/35/19 RE-11
19x10 +55 with 275/30/19 RE-11
My C63 is lowered on PSS10 suspension, front fenders rolled, rears are stock.
Will it rub?
Old Aug 18, 2015 | 12:18 PM
  #1498
Girard@ACGautomotive's Avatar
a car
Will it rub?
You should be more than ok.
How do you like the PSS10's? I assume they are for the regular C-Class correct?
Old Aug 18, 2015 | 04:57 PM
  #1499
Badmeat's Avatar
I believe they are. I really like them, but haven't messed with any of the adjustments yet.
Old Aug 29, 2015 | 10:17 PM
  #1500
2012 C250 Sport
Has anyone seen these S550 wheels on a W204 before? They are 43 offset, so they should fit, right?
http://phoenix.craigslist.org/wvl/pts/5163647770.html
Clearly the tires won't be of any help to me, just curious if I will have fitment issues or how it might look on the c 250
Also just saw these:
https://mbworld.org/forums/wheels-ti...r-springs.html
I just happen to be making a trip to SoCal next week anyway, and I would rather buy from another mbworld member. From what I've been reading, it looks like the rears will work at stock height, but those fronts look like they would be an awfully tight fit? Would I need to go to a 235 or even 225 in the fronts with these wheels?
Sorry if I seem all over the place, I'm just looking for a reasonably priced way to get some new shoes on my new ride.
You have already rated this thread Rating: Thread Rating: 14 votes, 4.64 average.
