W204's and offsets of wheels
Rating: Thread Rating: 14 votes, 4.64 average.
Old Sep 8, 2017 | 05:42 PM
  #1726
Alfadude's Avatar
2012 C300 4Matic
Is there any way you could reorient your pictures and re-post. Pretty hard to see what you are looking at when the pictures are all sideways.
Old Sep 8, 2017 | 05:49 PM
  #1727
truerogue76's Avatar
2013 C350 sport coupe
they look straight when i open them on my computer.... when i upload/post the forum rotates them..
i just signed up.. maybe someone can chime in and let me know what the trick is
Old Sep 9, 2017 | 11:18 AM
  #1728
Keemisdaddy's Avatar
Mercedes Benz C250 1.8L turbocharged
Fitment kings 🤓
[QUOTE=Code1ne;7132443]Those would fit and still wouldn't poke out. I ran 8.5 +15 front and 10 +38 rear before, the more wheel you poke out the more stretch you have to compensate for just an FYI. If you do 9.5 +45 you can run a 265 easily but I would get either 30 or 35 sidewall[/QUOTE
Awesome I have been looking for someone who run some decent specs, I'll be lowered on H&R SS will that tuck with 5MM spring rear pads after it settles? I really want to do a 19x9 +35 front 19x10 rear 20 but idk how if it will fit I do want to minimize the wheel stretch as much as possible.
Old Oct 2, 2017 | 04:25 AM
  #1729
om3ga's Avatar
w204
Hi all,
Is there any difference in car body width between amg package and avantgarde version?
I have w204 2010, avantgarde package (non-amg), currently considering two setups, will this setup fit without rubbing?
Currently stock suspension, however thinking about lowering it by -30mm.
Setup 1:
3SDM 0.01
Front: 18'' 8,5J ET45
Rear: 18'' 9,5J ET40
Setup 2:
Japan Racing JR18
Front: 18'' 8,5j ET 25-40 (40 is fine at front?)
Rear: 18'' 9,5j ET 20-43 (also 40 for rear?)
Tires probably the same size for both F: 225/35, R:255/35 (or even 40 if will fit)
Any advise appreciated, thanks.
Old Oct 8, 2017 | 02:49 PM
  #1730
97 GSX 97's Avatar
2014 C300 Sport
I’m looking at some 18x8.5 +35 and 18x9.5 +38 C63 wheels for winter beaters. Anyone running this size/offset while lowered on H+R Super Sports? I’m trying to figure out tire sizes, and also trying to avoid rolling the fenders.
Old Oct 29, 2017 | 07:35 AM
  #1731
avyonix's Avatar
C200 CGI, VW Passat B8, Ford Fiesta, Honda EJ8
Rays Volk Racing ZE40 wrapped in Michelin Pilot Sports 4. Front 18x8 225/40 ET50 Rear 18x8.5 255/35 ET44
Old Nov 3, 2017 | 12:28 AM
  #1732
Blk-ChromeC300's Avatar
2012 C300 Sport 4-MATIC
Can these wheels fit on my car without rubbing in the rear?
CLS63 19x8.5 40 5-112 66.6
CLS63 19x9.5 40 5-112 66.6
Hey guys, I have a 2012 C300 Sport 4matic sedan. I previously had nice 18" aftermarket AMG wheels on the car but the offset (which i don't know) was way to low in the rear and every little bump I hit, or If i had a passenger in the car, my rear tires would hit my rear fenders and made bad ware marks in my tires. I currently have 18" rims on the car right now and I want to go bigger and wider like my previous rims, but without the rubbing. The new rims Im looking at are CLS63 19" rims. I want to go 8.5" wide in the front, and 9.5" wide in the rear. They only offer the wheels in 40 offset, can i run these on my car without any rubbing if I stretch the tires? I have the stock Sport suspension. Let me know what you guys think, Thanks!
Old Nov 21, 2017 | 12:58 AM
  #1733
moohoun's Avatar
W204
This wheel it real one? Or copy one?
Originally Posted by fattysnax
Took a long time to decide but finally got new wheels.
18" BBS LM on Kumho Ecsta 4X
Front Wheels: 18x8 +32
Front Tires: 225/40/18
Rear Wheels: 18x9 +40
Rear Tires: 255/35/18
Attachment 379554
Attachment 379555
Attachment 379556
Attachment 379557
Old Nov 21, 2017 | 04:01 AM
  #1734
krisp_c300's Avatar
C300 W204
What Tire With:
19 x 8.5 / Rear - 19 x 10.0
Offset: Front - +35mm / Rear - +40mm
Old Dec 28, 2017 | 07:45 PM
  #1735
SBU1614's Avatar
2015 C63S Edition 1
18X8.5 all around with .35 ET for 2012 4-matic?
PLEASE HELP...
I ordered a set of wheels for my car - 2012 C300 4Matic - size 18/8.5 all around. The ad description said they would fit the C300 BUT the offset was for all E-class cars...
I called the seller and they ASSURED me REPEATEDLY that the description was just a typo, and the wheels would fit the C class without question...
The wheels arrived today, and my first clue there could be an issue was the fact the tag on the box with all the size info - had been removed for all 4 wheels...
When you flip the wheels over, you can see clear as day the offset is .35
I was under impression that my car could only fit
.40 - .50 offset...
I contacted the seller, and he insists that the wheels will fit my car regardless...
Will the wheels actually fit?
Or will they fit my car the same way an XXS man can fit into an XXL sweatshirt - it’s just going to look ****ing retarded?....
Please help.....
Old Dec 29, 2017 | 09:20 AM
  #1736
xEryx's Avatar
2019 E63s AMG
It will definitely not fit without rubbing.
Old Dec 29, 2017 | 12:49 PM
  #1737
SBU1614's Avatar
2015 C63S Edition 1
So part of me was thinking I’ll be ok...
my current srtup is as follows:
Front 18X8.5
Rear 18X9.5
the Rear does stick out slightly, and when I plug in the numbers with my current tire setup VS the lower profile setup I want to go with - willtheyfit.com says I’ll have even less poke than my current setup (which I can live with)...
Old Feb 17, 2018 | 04:10 PM
  #1738
bcraw902's Avatar
2013 Mercedes W204 C300 4Matic Sport
Hey there guys,
I'm looking for information on 2013 W204 C300 4Matic Sport 3.5L stock wheel sizing, including hub bore size. Also, if known, what is the biggest setup I can run at stock height. I'm interested in getting 20" wheels, with biggest possible fitment without rubbing, cutting, rolling.
Also curious as to the max fitment for wheels and tires in 19". The fourm has many people with different opinions and information.
From what I've picked up from the fourm, this is the biggest fitment.
20"
FRONT: 245/30/R20 ET44
REAR: 275/25/R20 ET55
19"
FRONT: 235/35/R19 ET45
REAR: 265/30/R19 ET48
I'm a novice to plus sized wheels. This will be my first stanced attempt.
Thanks for the help guys
-B
Old Feb 17, 2018 | 04:22 PM
  #1739
bcraw902's Avatar
I don't know how to delete this post...
Old Feb 22, 2018 | 05:48 PM
  #1740
caleb.nealey's Avatar
2013 C250
Originally Posted by Leo977
my details:
wheels 3sdm 0.01 concave
Front: 19x8.5 ET42 with Falken 452 225/35
Rear: 19x9.5 ET40 with Falken 452 235/35
did you have any rubbing issues?
I’m looking to do 19x8.5 F, and 19x9.5 R. I don’t want mine to rub
Old Feb 23, 2018 | 06:18 PM
  #1741
krisp_c300's Avatar
C300 W204
Ok guys just received some TSW Rallye Wheels as a gift the sizes are 19x8.5 & 19x9.5 ET40. Which tire size is best 235/35/19 & 265/30/19 or 225/35/19 & 255/30/19?
Old Feb 23, 2018 | 06:22 PM
  #1742
2013 C250
W204
I jut went to my shop today and finalized everything. I’m doing 225/25/19 on the front and 255/35/19 on the back. And the wheels I have are F19x8.5 and R19x9.5 - I will post pics once it is all finished.
Old Feb 24, 2018 | 12:46 AM
  #1743
krisp_c300's Avatar
C300 W204
225/25? Did you mean 225/35?
Old Feb 24, 2018 | 12:56 AM
  #1744
2013 C250
I’m sorry. Yes, I meant 225/35/19 on the front. And 255/35/19 on the rear.
Old Feb 25, 2018 | 11:32 PM
  #1745
krisp_c300's Avatar
C300 W204
Any News? I wanna Go with 235/35 if i can.
Old Feb 26, 2018 | 03:32 PM
  #1746
e8dingo's Avatar
2014 C250 Coupe
I have a 2014 C250 coupe and am looking at 19x8.5 Front and 19x9.5 Rear both with a 45 offset. Will they look good at that offset and what tires should I be looking at? Thanks!
Old Feb 28, 2018 | 09:15 AM
  #1747
brownin's Avatar
C250 Sport CDI ED125
I've recently started looking at making a few tweeks on the car, I'm all about the OEM+ look though, although I quite like a few aftermarket wheels but having seen these on an E class coupe recently, i think they would look the nuts on my c250 cdi sport.
I did a quick edit in gimp. no lowering but considering a light drop on springs.
question I have for you guru's is, would they rub/whirr or effect my ride quality?
specs:
Current: AMG 7 spoke standard alloys
Front Wheels: 8Jx18 ET50 (p/n AMG B66031494 - A20440198027X25)
Rear Wheels: 8.5Jx18 ET54 (p/n AMG B66031495 - A20440199027X25)
New: AMG 7 twin spoke e class
Front Wheels: 8.5Jx19 ET48 (p/n AMG B66031506 - A2124014502)
Rear Wheels: 9.5Jx19 ET48 (p/n AMG B66031507 - A2124014602)
I'm quite happy to fit some stretch if that's what is required (stretch is rarely bad looking anyway )
I looked on willtheyfit.com too but obviously its generic and they don't have considerations for the arches and strut positioning on my specific model.
Old Mar 3, 2018 | 10:23 AM
  #1748
maxnrelax's Avatar
2009 C300
My current setup 19x8.5 and 19x9.5 +45
Old Mar 3, 2018 | 10:35 AM
  #1749
e8dingo's Avatar
2014 C250 Coupe
Looks good, what kind of wheels? Have you considered spacers? I'm kind of torn on it, with ET45's it would look good with 5mm in the rear and 10mm up from I think, but not sure I want to go down the spacer road. Struggling to find wheels I like at that perfect offset though, and without breaking the bank. I guess it's a compromise.
Old Mar 3, 2018 | 10:48 AM
  #1750
maxnrelax's Avatar
2009 C300
Personally I've never ran spacers with any of my cars I've ever owned. With the correct offset you should be fine. +45 all around sits flush and I'am not running any springs.
I picked up this combo from a fellow member. They are Axis Verde.
You have already rated this thread Rating: Thread Rating: 14 votes, 4.64 average.
