W204's and offsets of wheels
Wheels are the Vertini RF1.1's
Tires are PSS 235/35/19, 265/30/19
Thanks for any help you can give..
Mike
But the wheels are with 285 ! I need just to know if i should be change the tires or i can use it ? And concerned the front with 245 ? You think it can be rub ?
Anyone can help?
I have a C300 W204 2009 Sport edition with staggered wheels from factory with offset front ET 47 8.5" and rear ET 58 9.5"
Tires in front 225 45 17 and rear 245 40 17.
What should be the best fit in tires size, wheels and offset on 17" non staggered?
can I put 4 wheels 17" offset 35 8" width, with tires front 225 45 17 and rear 245 40 17?
Sorry if already covered, but I didn't see it in the thread.
Thanks!
I consider going up to 19"s as well but I'm afraid I might end up regreting it even through it looks great. On 17s now, thinking of loss of comfort, increased road noise and perhaps lower gas Milage. Do or don't? Advice appreciated.
FYI for all the guys and gals here... the H&R super sport spring is not that aggressively low.
- I'm thinking of purchasing tires with 245/35/19 front and 275/30/19 rear, any chance of rubbing issue with stock spring? I don't have any plans of lowering my car for now as I use this for my daily driving and hauling 2 adults at the back.
- Is 245 and 275 is a proper ratio between front and rear to avoid damaging the axle or parts of drive train?
- If say I plan to lower it using H&R SS, any possibility of rubbing?
- Can I still use the stock lugs nuts? Or do I have to get a longer lugs and what size?
Any response and suggestion would be much appreciated.
As far as the stock lugs nuts it all depends on the wheels really.
I spoke to one of n4sm rep and asked them if I can use my stock lugs for forgestar cf10 and he said I need to buy an extended lug nuts? Any comments on this.
