W204's and offsets of wheels
Rating: Thread Rating: 14 votes, 4.64 average.
Old Feb 18, 2015 | 09:27 PM
  #1276
Becksan's Avatar
2018 E43
Originally Posted by aznmode
Thanks. I'm on stock now but might lower with HR sport. What's your rear?
UPDATE: I've decided to go with Toyo Proxes 4 Plus. 225/35F & 265/30R.
I'm 265/30 on the back
Old Feb 19, 2015 | 05:31 AM
  #1277
aznmode's Avatar
2010 c300
What offset for your rear?
Old Feb 19, 2015 | 07:36 AM
  #1278
Becksan's Avatar
2018 E43
19x9.5" ET42 (265/30/19) - tires are hankook Evo 2
Old Feb 19, 2015 | 01:47 PM
  #1279
aznmode's Avatar
2010 c300
Thanks! Looking good! I'm starting to wonder if I should switch to 235 up front now.
Old Feb 19, 2015 | 03:05 PM
  #1280
Becksan's Avatar
2018 E43
I would do 235/35 in the front if I were you. It's already skinny enough as 235 imo.
Old Feb 19, 2015 | 03:30 PM
  #1281
aznmode's Avatar
2010 c300
Thanks. I will see if the shop will do an exchange for me. Besides the stretched look. Do you see any other disadvantage with going with 255?
Man I did not realize that the Niche m149 is 34lbs front and 35lb rear. I'm suddenly having buyers remorse.
Old Feb 19, 2015 | 04:13 PM
  #1282
Becksan's Avatar
2018 E43
Nah, but I would say the lips on mine are already exposed enough with the ones I have.
If I get out in time I can take a picture so you can see the size of wall and how exposed they are.
Hehe that's some chubby boys you are throwing on 😁.
Old Feb 19, 2015 | 07:43 PM
  #1283
aznmode's Avatar
2010 c300
Hehe that's some chubby boys you are throwing on ��.
What I was thinking is with 255 the rims are less protected from potholes. Seems the more vertical the sidewall the more it can protect the rims.
Update: After looking at some pictures of 255 on 19x8.5, I've decided 235 looks better. 255 looks a bit too stretched and exposes the lips to much IMO. Thanks Becksan for your images you posted on here a few pages back. Helps a lot. 235 with 265 combo looks perfect. The dealer I'm buying from swears 225 will match 265 better.
Old Feb 20, 2015 | 10:12 AM
  #1284
Becksan's Avatar
2018 E43
Maybe he got an overflow of 225's 😁. The most common combination I have seen while searching wheels and tires are 235/35 & 265/30 for 19" 8.5" & 9.5". The 225 sounds like a stretch when looking at my front ones.
Top is my front & bottom is my rear so you can see the lip is exposed on mine with the 235 & 265
Old Feb 20, 2015 | 12:43 PM
  #1285
aznmode's Avatar
2010 c300
Maybe he got an overflow of 225's ��. The most common combination I have seen while searching wheels and tires are 235/35 & 265/30 for 19" 8.5" & 9.5". The 225 sounds like a stretch when looking at my front ones.
Thanks for the pics. I feel better about my decision.
Old Feb 20, 2015 | 12:47 PM
  #1286
lakers3120's Avatar
c300
Originally Posted by jimmythegreek
It will not rub ONLY if you run the right size tires BUT If you drop it you will have to buy special tires that are 300+ each only Nitto (i think) makes them in 20" in that size. Honestly hotelcrazy, theres only 3 W204's Ive seen that are on 20's and are tucked right, and look right. Its alot of rim for this car and then you HAVE to run 25 out back to clear and 30 up front, they are rubber bands bro. Pair that with a drop and you kill the driveability of the car, and I beleive from reading ur posts its ur girls car mainly, she may kill you. Im running 19s w 40offset up front 8.5 on 235/35/19 and 45offset out back w 10 rears on 275/30/19 and the ride is rough dropped a half inch all the way around. I wouldnt dream of going 20s, I had 18s on my last C dropped w sports and it was 35mm offset all around and I could only clear w 255/30/18 out back and it was rough, I bent 2 wheels on pot holes being stretched like that. How much r u looking to spend and what style? I got 3 sets of shoes 2 sets are 10 rears and black Im gonna sell the one set soon
I was thinking of getting niche Milan 20", I was told I can run a 20x10.5 +55 in the rear as long as i have a 285/25/20 tire. would this work on stock set up
Old Feb 20, 2015 | 03:59 PM
  #1287
Becksan's Avatar
2018 E43
Hehe anytime! Don't forgot to throw some pictures up when they are on!
Old Feb 21, 2015 | 10:55 AM
  #1288
dudeitsmattx's Avatar
2013 C250 Sport
Originally Posted by LexxHenderson
To start off with my car is 4matic. I see that you have been talking about getting the Rohana RC10 for your car. I have H&r super sports on my car and i am running the RC10's in a 8.5 all the way around. I have them wrapped in 255/35/19 tires. The back fit perfectly but the front rubs like crazy. I had to put the stock springs back on the front because of how bad it was. I have stock wheels on right now for the winter but plan to lower the front back down and put the rohana's back on come summer. what tire size would you recommend me going in order to get rid of the rubbing?
With 8.5' wide tire you should go with 235. Im having rims build now. 19x8.5 and 19x9.5 as for tire size I will be running 235/35/19 front and 255/30/19 rear.
Old Feb 21, 2015 | 12:23 PM
  #1289
tungsquared's Avatar
2008 Mercedes Benz C350 Sport
I am using 19x8.5 in the fronts and 19x10 in the rears.
Old Feb 23, 2015 | 11:46 PM
  #1290
aznmode's Avatar
2010 c300
Here are some shots.
Old Feb 24, 2015 | 12:37 AM
  #1291
azammin831's Avatar
c300
Originally Posted by sdsu.enciso
Just adding my contribution to the forum that was instrumental in helping me choose wheels and tires.
I am purposely posting a picture before installing springs; during my research, I could not find any pictures of wheels without suspension (for those out there wondering the same).
Thanks to the forum and TAG Motorsports.
F: 20X8.5 44ET 235/30/20
R: 20X10 55ET 275/25/20
Stock Suspension
What rims are these?
Old Feb 24, 2015 | 08:24 AM
  #1292
SwoodyC300's Avatar
Veteran: Army
2006 E55 AMG & 2008 c300 4matic
vossen cv2's
Old Feb 25, 2015 | 08:00 PM
  #1293
sara812's Avatar
2009 c300 4matic sport
i need to buy new rims for my 09 c300 4matic sport. tire sizes are:
front: 225 45r17
rear: 245 40r17
can i buy the same size wheels for them? or do i need to get seperate sizes for the front & back (and try to find all 4 matching)? what size(s) do i need?
would something like this work (set of 4)?:
https://www.rimslegend.com/drag-conc...-machined-17-8
or this?
http://www.tirerack.com/wheels/Wheel...All&sort=Price
Old Feb 25, 2015 | 08:11 PM
  #1294
Mr_yakuzabenz's Avatar
c350 4matic
20s
Old Feb 27, 2015 | 01:00 PM
  #1295
JimB93's Avatar
09 c300 4matic
has anyone ran varrstoen es2's? would 18.8.5 +38 and 18x9.5+38 fit on a 10 sport?
Old Feb 27, 2015 | 02:22 PM
  #1296
Motorin Mark's Avatar
2013 C250 Sedan
This is what 19x8.5" ET40 (235/35) & 19x9.5" ET42 (265/30) looks like. It's perfect for what I wanted. I'm on H&R Super Sports.
What brand of wheels are these and where did you get them please?
Old Feb 28, 2015 | 06:58 AM
  #1297
valter-abrantes's Avatar
mb w204 220cdi
i whant to buy some 18 rim... To 225 40 18 and 245 35 18... What offset can i were? And wide?
Old Feb 28, 2015 | 08:15 AM
  #1298
Becksan's Avatar
2018 E43
They are MRR Groundforce GF09 in Hypersilver. I got them from Need 4 Speed Motorsports.
Email Tiko - tiko@n4sm.com
Tell him Anders sent you and he'll take good care of you.
Old Mar 4, 2015 | 02:26 AM
  #1299
aznmode's Avatar
2010 c300
Got to test my set up today. Drove to downtown San Francisco from Sacramento today with 2 passengers, 1 big luggage, 1 carry on luggage, 3 back packs. Car was slammed and did not rub.
Posted my set up a few pages back but posting it here again.
19x8.5F et 42 with 235/35 tires
19x9.5R et 48 with 265/30 tires
Old Mar 4, 2015 | 07:47 AM
  #1300
FFM's Avatar
FFM
Audi R8
Can anyone confirm the width and offsets of the black/machine faced 7 split spoke wheels that come optional with the AMG sport models?
I've found conflicting info. May just have to see if the offsets are stamped on the inside of the wheel when I install my springs.
You have already rated this thread Rating: Thread Rating: 14 votes, 4.64 average.
