Are all engines in the 2012 C-Class using DFI?
Sorry if I am not up-to-date about the 2012 C-Class sedan. My wife is going to replacing her W204 C350 in a few months, and we are thinking of the new 2012 C-Class.
I read from the recent Autoweek (1-10-2011 issue) that there will be a 302hp 3.5L DFI engine in the lineup. There will also be a 1.8L biturbo I4 engine and another 3.5L V6 with 228hp, but the magazine didn't say if they are DFI as well.
Does anyone know if all these engines will be using DFI or traditional EFI?
Thanks for any insights,
With best regards,
(Edit: Thanks folks for the inputs. I think Autoweek had an error on its article about the 3.5L V6 228hp engine, it should be '3.0L' instead as you folks mentioned. Thanks.)
edit* after bit of research i now know
its where the fuel air mixture took place in combustion chamber and allow super lean a/f ratio and therefore better eco and higher hp
These DFI engines are not without problems (read: Audi). Because there is no fuel in the intake rail, the carbon deposits that come off the PCV system can deposit in the intake rail as there is no fuel to cleanse them like an EFI engine has. Either the engine has to have a very good PCV oil separation unit, or in some cases the car must carry a cleaner solution to inject into the intake rail. The other alternative of course, is that the intake fouls, especially if you make alot of short trips, and you take it to the dealer every 30K miles to have a special cleaner run through it (read: Audi).
Does anyone know what kind of system Mercedes is using for their DFI engines?
are those CGI anything close to DFI?
http://www.carblogindia.com/what-is-gdi/
I never heard of CGI? Besides the mockup computer graphics.
As our cars get more sophisticated electronically (and more efficient, powerful and fun to drive), it becomes more important to manage the life-blood - electricity. Batteries that are old or batteries that are poorly made will make big differences in the way a car runs. For example, fuel injectors that are built and set up to run on 12.5 volts will deliver the exact amount of fuel for the application. Let's say 11.3 milliseconds of fuel. If the electric power to the injector is 11.8 volts or 13.8 volts, the volume through the injector will be different. Poor performance. So, the alternator and battery become more important as the technology improves.
I know, I rambled - sorry.
But just google "audi dfi engine carbon buildup" and you will see what comes up, its not anecdotal. BMWs have issues too, notably gas that appears in the crankcase because the fuel pressure in the cylinder is so high.
I want to see what MB does on their DFI engine applications regarding technology to address these issues. A better oil separation unit for crankcase vapors is key.
Other companies are looking at these options:
1. higher combustion chamber temps to burn the coking from the intake valves
2. using sodium filled intake valves that run cooler and will not get coked
3. advancing the ignition to create higher combustion temps and pressures to burn the coke material
4. introduction of another injector in the intake manifold to spray water or methanol or mixture
5. shielding material for the intake valve
6. and so on.
As for gas in the oil (crankcase oil), OMG, change the oil sooner than 10,000 miles. The best way to combat this and get a definitive answer is to do an oil analysis when you change the oil. The analysis can tell you how much gas is in the oil. You "should" be able to get 7500 miles out of an oil change. However, I still change mine in the C300 at 5000 - regardless of what MB or anyone else tells me. My oil has next to no gas in it within 5000 miles. If I start to get elevated levels, then its time to sell the car as the piston rings are toast.
However, I completely agree that I want to see what MB does to combat it, even though we are only talking about coking of oil on the intake valves on very few cars.
Good discussion.
For those of you that were cross shopping with the BMW 335i, we made the right choice :
http://abcnews.go.com/TheLaw/bmw-adm...ry?id=11968495
Nick
Unless fixed ( I like the 4th concept listed by 930pilot ((I was just a 931 pilot)) ), a DFI gas engined car would be a good lease.
I did some more digging on the intake valve fouling and what is being done to help. It seems that most valve fouling problems happen at more than 25,000 miles (time to build up). A local shop in ATL taps a small nipple just after the butterfly where they introduce a can of BG or Seafoam while the engine is running between 2 - 4000 rpm. It cleans the valves quickly and safely. It's not ideal but if you have to do it every 20,000 miles, that's not catastrophic and probably good for the valve seats anyway. The older the engine gets, the more it fouls. Again, its not ideal, but your engine is not toast either. Emissions laws state this is the way crankcase venting will be handled, so there is no more venting to a charcoal canister (something I would personally install if I had a problem DFI car).
No flames please....
As a Porsche owner and PCA member, some bad news is that the newer DFI 997.2 models are experiencing HPFP failures now like BMW. Same slow start symptoms and dealers are replacing them. And some owners have had multiple replacements already.
It's still early to know if they designed effective enough oil separators for other issues to appear (and most P-car owners don't rack on a lot of miles.) But the flat engines have always been prone to intake oil contamination. The dealers still sell and recommend using BG44K. We'll have to see, as time will tell. But hopefully Porsche got it right; DFI does have a lot of positive features. And of course as DFI is more universally applied, the technology to avoid potential issues will improve.
I would guess any issues the early adopters like Audi and BMW had are fixed. Besides, if under warranty does not matter.
