Transmissions Failure (7 Speed Auto)
The lead mechanic went for a test drive with me and initially though it was also a drive shaft issue. He said that he had another W204 come in recently that was making the same noise. The noise was due to the heat-shield material (a felt like material) coming loose and hitting the drive shaft. Said it was a 15min fix if that was the problem. He also stated that this was a common thing he has seen on the w203, but the not on the w204 yet.
They put the car on the lift and after a half hour they came back and said thats not the problem. So we rescheduled for this morning so they could look into it further and so I would have a loaner vehicle.
Anyways, they just called me a little bit ago and it appear that the transmission had failed. I didn't get a lot of details from the service writer, but he said they will have to replace the tranny. The good thing is that it is covered under warranty. I'll get more deals but he said two component inside the tranny ceased together. The weird thing is that the car ran perfectly fine.
I caught this issue right before my regular warranty was up so I though I'd post it incase someone else was having the same issue. I think this case is pretty rare/extreme but a new transmission not under warranty can cost you a fortune, so if you hear/see the same symptoms, I'd have the dealer check it out.
Here's some info of the symptons. I'll post more about the exact cause of the issue when I find out more later.
Model: 2008 C300 4MATIC
Transmission: 7G TRONIC 722.9
Miles: 47,000 miles
Symptons: High Pitch Metal-to-Metal Squeal from under the vehicle. Sounds is speed based, not RPM and is constant. The noise is only noticeable with the window UP and music off.
You got in just under the warentee? That's great news. Just for reference see if you can find out what the price would have been if you had to pay for it. You are getting a brand new one, not a refirbished one right?
Kind regards,
Rick
See here:
https://mbworld.org/forums/c-class-w...ghlight=gentle
See attached thread "I may have broken something" for audio clip.
I wish TheDarkSide would return and fill in some missing information. A "hit & run" post leaves many questions unanswered.
Wayne
When I pulled away I heard a noise, my 1st thoughts were Oh hell, gearbox. As I get to speed the noise went away, say 1KM, and stay away while travelling and through stop-starts. The afternoon I parked the car again, cup of coffie, as I pulled away same noise, same things.
Only that night in bed, it strike me it could be the front engine fan running at full speed because car was parked. I always look at temp gauge and remember seeing it just a tiny bit higher than usual when noise was heard.Usually I left the car after parked longer unattended.
I left it at that seeing my symptoms. Hope I am not wrong.
Not sure if it's related, I have had to deal with a higher-pitched whistle-like noise at ~70 KM/h when letting off the gas pedal for almost three years since the ODO: 28km mark! From reading the posts here, some suspected/confirmed that it was from the transmission. I was hoping to wait till the transmission service which I'm currently 7K away from to mention the problem. However, the whistle disappeared all of a sudden after service A2 last week. They did reprogram the transmission control during the service, but I doubt that had anything to do with it. I have tried to listen for other types of noises in the event that the original problem has progressed into a worse form, but so far so good.
Folks , my issue was thankfully the tires. got them rotated back this morning and all is well. Good luck!!
My concern is warranty after the repair. I thought all dealers, all vehicles must provide a 12 month 12,000 mile guarantee on any service or repair work wether its covered under general warranty or not?
Loud enough to hear with the windows UP and music OFF.
Seems more obvious when I lift off the throttle around 60 mph.
Not sure how long this is going to take for my repair. Anyone have answers on warranty after the repair??
I do not have the details on the exact models, years affected nor do i recall the details of how the compromised tranny fluid causes transmissions to fail. However, i do trust the tech who told me this and MB is aware of the issue.
Perhaps Glyn or someone else could explain this failure mode? Would there be a TSB on this?
