HID low beams - compatibility
Old Feb 12, 2011 | 01:08 PM
jeres8860's Avatar
2008 C300
Hi,
my left low beam went out and I need to replace it. so I ordered Sylvania HID lights that ARE compatible with my 2008 c class. but I was wondering if I need a conversion kit or any other upgrades to get them to work in my car? I am replacing the original lights that came with the car and I don't have the xeon light upgrade just the standard lights that come with the car.
here is the link to the lights I bought. I hope they will fit, but if not I will get the regular halogen and cancel my order.
would really appreciate the help, thanks
http://www.amazon.com/Sylvania-66144...ar=1&carId=004
Old Feb 12, 2011 | 01:30 PM
Arjy's Avatar
2020 E63s Wagon, 2012 C63 AMG Coupe, 1989 560SL, 2023 911 Carrera T
im pretty sure theres no easy way to make those work in your car, without replacing the projectors entirely
if you want HIDs youd need an h7 hid kit, rather than actual d1s bulbs
Old Feb 12, 2011 | 01:55 PM
jeres8860's Avatar
2008 C300
ok, thought so, I just looked online and it said they were compatible with my car so I bought them but after looking some more, I started to realize that they are compatible ONLY if you got the xeon upgrade. thanks for help.
Old Feb 12, 2011 | 01:59 PM
jeres8860's Avatar
2008 C300
what are the best halogen lights one can buy that will work with the standard setup of the current model c class???
Old Feb 12, 2011 | 02:11 PM
sagar350z's Avatar
2012 C350 coupe
Im going to take a guess and say stock OEM ones u get from the dealer? I haven't used other halogen lights, and im going to upgrade to HIDs soon. I would say unless you like the light output and color of halogens you should consider HIDs.
Old Feb 12, 2011 | 02:15 PM
Sportstick's Avatar
Another round of ICE
I have been very happy with the improvement from stock with Phillips X-treme H7 bulbs.
http://www.amazon.com/Philips-X-trem...7538297&sr=8-1
Old Feb 12, 2011 | 02:40 PM
jeres8860's Avatar
2008 C300
yeah I was thinking either the Phillips X-treme H7 bulbs
found here: http://www.amazon.com/Philips-X-trem...7538297&sr=8-1
or the Philips H7 CystalVision Ultra Headlight Bulb
found here:
http://www.amazon.com/Philips-Cystal...2008&carId=006
any suggestions?
Old Feb 12, 2011 | 02:41 PM
jeres8860's Avatar
2008 C300
how much does it cost to upgrade to HIDs?
Old Feb 12, 2011 | 02:59 PM
Sportstick's Avatar
found here:
any suggestions?
It's interesting to note that on the manufacturer's website, Xtreme is promoted for light output, while Crystal's main benefit seems to be the color appearance of the lamp. I am much more interested in output performance than considering the color of the headlamp as a styling element. What is more important to you?
http://www.lighting.philips.com/us_e...30&id=&lang=en
Old Feb 12, 2011 | 08:27 PM
Samieee's Avatar
C
I've been interested in this bulb for awhile. How long have you used the set for? Can you give an estimate on the color temp? I bought 5000k LEDs for the eyelids and wonder if it would be a close match.
Old Feb 12, 2011 | 08:32 PM
nyca's Avatar
For the standard H7 replacement, the Philips or the GE Nighthawks. Stay away from the Sylvania H7s.
Old Feb 12, 2011 | 10:42 PM
Sportstick's Avatar
I've had them for 6-8 months with no problems. I'm sorry, but I don't have a basis for comparison or measurement for color temp...perhaps the manufacturer's web site has further info? That was not an issue for me.
Old Feb 12, 2011 | 11:19 PM
yongra's Avatar
They can cost anywhere from $100 and up. But, you need to be careful with the conversion kit.
First, standard halogen light had different projection than HID lights. So, they may not concentrate the beam properly. You may see more scattering with HID conversion kit on a halogen headlight projector. This is illegal to do on some states in US due to blinding on coming traffic.
Second is HID light kit requires the ballast for it to work. Which means you need to modify your light box and find the location for the ballast to be secured.
Third is Mercedes have electronics that monitors the head light bulbs. If the conversion kit you put in does not send the correct signal back to the ECU, you will get error message on your dash and the lights will not come on.
I have looked in several places and some do offer error-free system. I have not tried it myself. But, it seems lot of work for little more brightness on the head light. I know, it looks cool. But, I would get blighter H7 bulb which is mentioned on above postings.
If you decide to do it, good luck and have fun.
Old Feb 13, 2011 | 01:54 AM
ZeroSeVen's Avatar
Mercedes Benz C300 Sport
I have Philips Diamond Vision 5000K... Light output and range distance are good... It will also match AZN Optics LEDs if you decide to changed your eyelids to LEDs
I had them for almost 6 months now with no problem
Old Feb 14, 2011 | 10:08 AM
chris5949's Avatar
2008 C300 4MAT LX
ShxxT! and I just brought a Sylvania H7 from Autozone; $18 plus tax
Never know Amazon.com sell auto parts
Old Jul 29, 2012 | 12:36 PM
Erafique's Avatar
Mercedes c300
C300 2008 Low Beam flicker and turn off
Low beam on driving side of my car sometimes flicker for a second when car is turned on and then stop working. I have disconnected and reconnected the wire to bulb but it is still doing same. Is it some connection problem or do I need to replace the bulb.
It has H1D 35w Osram Xenarc 66147 bulb.
Old Jul 29, 2012 | 01:25 PM
Sommy's Avatar
C43
Has anyone had trouble removing the actual bulb from the housing? I can get the cap off, slide the housing out, but can not get the bulb to come out. I'm afraid I'm going to break it I'm pulling and twisting so hard.
What am I doing wrong? Is there a special twist or something?
Old Jul 29, 2012 | 03:22 PM
Domm's Avatar
'08 Mercedes C300
I've never attempted to change a bulb on the facelifting c class, but assuming its like other bulbs that aren't held by a clip, just twist counter-clockwise.
Old Jul 29, 2012 | 04:26 PM
JasonHu's Avatar
2012 C300 4MATIC, 2014 Tesla Model S P85
It's just a twist and pull.
